Question about Garmin Nuvi 200w 250w 260w 580 660 670 680 Carrying Case
My 200 w was working fine the last time I used it. This time when I turned it on it asked me to press a series of dots and then select the country etc. Now it says "no detailed maps found to support routing" I tried to reset it but the same message comes up.
  • 1,183 Answers
HI,
Kindly refer to the link below , you would have to donwload and install a file from your computer to the Nuvi 200, to fix the problem
http://www.fixya.com/support/t382588-garmin_nuvi_200_says_no_detailed_maps
Alternatively you can call Garmin support over the phone and they can help you step by step over the phone aswell in case you donnot follow the instructions on the above link
Monday – Friday: 8 AM – 6 PM Central Time (closed holidays)
US: 913-397-8200
US Toll Free: 1-800-800-1020
Canada: 1-866-429-9296
Thanks
proton
Posted on May 17, 2009
How to setup english language in lexmark X5690..when I involved computer cable It's shock me..how to solution this problem...my country name Bangladesh
Step Action 1
Power off the machine, holding the power button down for four seconds. 2
Press and hold BACK and START and then press the power button again. 3
Continue to hold the buttons for approximately 20 seconds, then release them. 4
The Initial Setup menu will appear.
Use the arrow buttons to select the required language and then press OK to confirm your choice. 5
The Country Select Menu will appear.
Use the arrow buttons to select the required country and then press OK to confirm your choice.
NOTE: date, time and fax data need to be entered after the country is selected on the X5600 and X6600 Series All-In-One.
Jan 04, 2018 | Lexmark Office Equipment & Supplies
What is wrong with the screen when it says to Touch Dot?
You can just use a plastic pen or anything with a nib to press it, instead of using your finger. After pressing 5 to 6 times it should work
Jul 16, 2014 | Garmin Nuvi 200 205 250 255 260 W
When I turn on my nuvi 200 it says press dot. When I press the dot it just moves around the screen to different location.
To calibrate the touchscreen on your nuvi 200 series follow the steps below:
  1. Have the unit turned OFF and unplugged from power.
  2. Slide the power switch to the ON position and hold for about 45 seconds.
  3. A message will display on the screen: Press Dot.
  4. Once this message displays, release the Power button.
  5. Press in the center of the Dot.
  6. Keep pressing in the center of the Dot as it moves around the screen.
  7. Once this is complete, there will be a message: Calibration Complete.
  8. Touch Ok and the unit will restart.
The touchscreen will now be recalibrated.
*Note if unit is running software version 6.00 or newer you will want to follow steps from below.
To calibrate the touchscreen on your nuvi 205 series follow the steps below:
  2. Place your finger in the top left hand corner of the touch screen and apply pressure.
  3. Slide the power switch to the ON position. Once unit powers on release the power button.
  4. Hold pressure in left corner until the Press dot message appears.
  5. Once this message displays, remove your finger from the screen.
  6. Press in the center of the Dot.
  7. Keep pressing in the center of the Dot as it moves around the screen.
  8. Once this is complete, there will be a message: Calibration Complete.
  9. Touch Ok and the unit will restart.
//changed this line from 'solution1description.innerHTML' to use getElementById //to prevent FF warnings. They both appeared to work, but this is cleaner. solution = document.getElementById('solution1description').innerHTML; Last modified on: 09/30/2010
Oct 23, 2010 | Garmin nuvi 205 GPS Receiver
Maps disapeared from my garmin for no reason!
go into settings, then map, then map info see if box is ticked if not tick it, then return to where to and see if countrys name appears the select country
Dec 04, 2009 | Garmin nuvi 205 GPS Receiver
My Garmin nuvi 200w behaves erratically until it has been turned on and warmed up for around 10 minutes. Before this time the touch screen may not work or when pressed respond as if pressed at another...
First make sure the batteries are good and at normal room temperature.
Second, based on your question your touch screen is bad or needs calibrating....
Then
Try to recalibrate your screen:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} To recalibrate the touchscreen on your nuvi 200 series follow the steps below:
To recalibrate the touchscreen on your nuvi 205 series follow the steps below:
Sep 23, 2009 | Garmin nuvi 200W GPS Receiver
The screen on my Garmin Nuvi 200W won't respond. I tried the recalibration but the screen doesn't respond when I touch the dot. I also tried a hard reset and that didn't help either. Help please!
There is more than one calibration procedure, but for the 200 it is:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} To recalibrate the touchscreen on your nuvi 200 follow the steps below:
If this doesn't work you have two choices
Buy a new one
Or
Send your in for repair. Go here for this option
http://www8.garmin.com/support/outofwarranty.html
Aug 23, 2009 | Garmin nuvi 200W GPS Receiver
Need Toyota radio security code
Oribeeboy is spot on for a 100 series Landcruiser - last 3 VIN numbers.
Let's say the last 3 VIN Nos were 264
Turn the ignition key so that the radio displays "SEC"
then: press "TUNE"and press No1 button on the radio at same time
then: press No1 button 2 times
then: press No2 button 6 times
then press No3 button 4 times
Finally hold the "SCAN" button to confirm the code. The radio will then turn itself off. You can then turn it on in the normal way.
(Hopefully!)
Mar 16, 2009 | 1997 Toyota Camry
Technika pro LCD TV/DVD 15.4 HD Digital
if its the model i think it is the lcd15-m3 then go into d.menu (about 6 buttons up from the bottom left) then using the arrows next to the same button go down to the last option which should be setup or settings and press ok.
then go down to instalation (again the last option) and press ok
then down to first time instalation (again last option)
Select yes and press ok, this will bring you up to your original setup page
(menus are the same in most models but almost positive that the model you have is the m3
Jan 19, 2009 | Sampo PME-50X7 50 in. HD-Ready Plasma...
I'm getting inaccurate letter entry on the letters I type. For example, when I type a B an M appears - I'm noticing it on the bottom row of letters at this time. Solution?
Are you sure you pressed the correct location on your screen???
If so, you may need to calibrate the screen.
Do this:
Dec 26, 2008 | Garmin nuvi 260W GPS Receiver
I just turned my Garmin nuvi 200 on for the first time, and it came up for what country, and picked the wrong country, I want The USA for my country, and wright now its showing some other language. ...
What you want to do is a factory reset to clear the user data.
1. Turn the unit off.
2. Place your finger in the lower-right corner of the screen.
3. Keep your finger there and turn on the unit.
You will be asked if you want to erase all user data. Select yes. Your Nuvi will restart and ask you the country information again.
- Jim
SHARCNET-USA
Dec 14, 2008 | Garmin GPS
Garmin Nuvi 200w 250w 260w 580 660 670 680 Carrying Case  Logo
108 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
