Question about Flotec Plumbing
We have a Flotec # FPSC4550A and the floater seems to be working correctely but even if it floats up and should turn it self on we now have to go down and ''shake'' it a bit in order to get it to go on. We've tried cleaning the parts we see. Is the switch broken or not as sensitive as it should be??
4 Suggested Answers
  • 351 Answers
SOURCE: Flotec Float switch did not automatically shut off,enginburn out
Hi Lamont .. I would first check test the float switch and make sure that it is faulty, set it up in a tub of water and manually move the float switch. see if it cycles on and off. sometimes the float will get hung up on its support or on the edges of the sump pit. If the float switch is faulty then YES it can be replaced,. try a building supply store like home depot or the pl;ace where you got the switch originally.
Please Vote !!
Posted on Jun 02, 2010
Testimonial: "Great suggestion. Appreciate the quick response."
  • 24 Answers
SOURCE: I have a Flotec pump model #FPSC4550A that will
Sounds like the contact inside the float is stuck. It can be corroded and not letting the circuit open and that will keep the pump running.
If it had been fine but just started doing this, that is what I'd check. If someone could have accidentally wired it incorrectly when they were trying to fix it, perhaps they accidentally bypassed the float switch and have it "running hot" all the time.
Posted on Feb 08, 2011
kirkx
  • 2019 Answers
SOURCE: we have a fpsc4550A
The switch is at the top, and the float is supposed to push on the switch.
If there is anything between them, or the switch is stuck, it may not work right.
Push up on the switch manually with a piece of wood (don't like to use fingers with electricity and water), to see if you can operate it with more force.
If you can, then lift float to see if it is heavier than it should be, perhaps from leak or accumulated algae weight or something?
http://www.pumpagents.com/FlotecPumps/FPSC4550A.html
Posted on Feb 26, 2011
How do I get the sump pump floater to work?
Is the floater on a dongle cord or does the floater slide up an down on a shaft? Are you saying the floater won't float? It seems if you can raise the floater up which contains the switch and it works, it should work when liquid makes the float rise. Is the sump placed low enough in the liquid to ensure the float will rise high enough to turn on?
Apr 30, 2014 | Plumbing
We have a fpsc4550A sump pump and it turns on but will not shut off the float seems to go up and down with the water level
Feb 26, 2011 | Flotec Plumbing
I have a Flotec pump model #FPSC4550A that will not stop running even though the float falls down. Any ideas?
Feb 04, 2011 | Flotec Automatic Sump Pump Float Switch
What is the out put pressure of Flotex FPSC4550A-11
These are a high volume pump, but they produce only about 10 psi of pressure...
heatman101
Sep 03, 2010 | Flotec 3.4 Hp Floodmate Submersible Sump...
Please Vote !!
Jun 01, 2010 | Flotec 13 Hp Automatic Submersible Sump...
Toto toilet is constantly running, even though the tank is full
it sounds like it might be the floater ball in the toilet you can adjust the tension on it usually with a screwdriver.... if you look from the top down you should see a screw on the top of the arm that holds the floater adjust the tension and hopefully this will work
Jan 20, 2010 | Toto Drake ADA Compliant Toilet with...
Pump not kick in
the float has a mercury switch and that is what will make it turn on and off.  this ball sounds like it is not working correctly.  you will have to replace it.  just the ball
Jun 22, 2009 | Flotec 1/4 Horsepower Sink Pump System
Flotec Sump Pump Tethered Float - Float seems faulty. Easy fix?
it sounds like it could be a bad float switch but most of the time the water isn't high enough for the pump to turn on. it takes alot of water to turn on a tethered float. the other pumps they sell at lowes with a real float (like the one in the toilet) are adjustable and also replicable. .
Apr 11, 2009 | Flotec Simer//Omni 2957 Submersible Sump...
Pump not stopping
If you have to bang the float to stop the the float switch is not working correctly.. you may have somthing holdig it up or the switch itshelf is failed...
Sep 24, 2008 | Bosch 24 in. SGS43C12 Classixx...
Plumbing Logo
290 people viewed this question
Top Flotec Plumbing Experts
Boyet Soriano
Boyet Soriano
Mike Carew
Are you a Flotec Plumbing Expert? Answer questions, earn points and help others
