Question about GARDENA Water Timer #31169-4
How to hook up my water timer - GARDENA Water Timer #31169-4
You answered the question on how to and I followed it and it worked-
thank you again for your quick help
Posted on May 18, 2009
Is timer the problem
I would think whatever is hooked up to the timer is bad. Not the timer itself. Disconnect/unplug the pool pump from the timer and see if the timer trips the breaker.
Dec 04, 2013 | Intermatic 220v T104p Swimming Pool Pump...
Melnor water timer
Melnor is major water timer company, and not off-brand. However, water timers last a couple years, or less, sometimes they last long time but that is not often.
If not drained completely of water, they will break when water freezes.
Copy following link to identify all water timers on market today:
http://waterheatertimer.org/Woods-timers-and-manuals.html#sprinkler
Most timers have 1 year limited warranty for defects in workmanship.
Jun 05, 2013 | Hardware & Accessories
I have a Nelson Smartzone EZ and I think I have a ground wire disconnected/missing. Not sure where or how to hook it up, or get a replacement. Where can I find a manual of how to hook this back up?
Copy following link for possible identification of your timer, and instruction manual:
May 03, 2012 | Nelson L R 56610 Electronic Water Timer
I have a 196-036 timer. Stored it inside during the winter. Hooked it up yesterday, everything works, (info panel), but it will not allow water to disribute. Tried manual and auto programing. Any ideas?
Most issues of this sort with these timers is water pressure holding the valve shut. Reduce the flow from the spigot and try again. If the timer still does not operate properly I would suggest removing the timer from your water system and manually activate the valve. Listen for the solenoid to click open, this can be fairly faint so it may take a few tries to definitely tell if it is operating. If the solenoid will not operate it would be best to replace the unit.
Mar 22, 2011 | VIA Garden
My EH40 is not supplying power to the water heater. I hooked the power line in to posts 1 and 2 and I hooked the load out to posts 4 and 6. When I use my power checker it reads no power to posts 3,4,5,...
I have an EH 40 sitting in front of me right now.
http://waterheatertimer.org/How-to-wire-EH40-hot-water-heater-timer.html
The link above shows correct 240V water heater timer wiring for EH40
Link below shows an overview picture of EH 40 connected to 240V water heater
http://waterheatertimer.org/images/EH40-water-heater-circuit-5.jpg
http://waterheatertimer.org/240-v-water-heater-circuit.html
EH40 has a 240V clock.
Terminals 1 and 2 send power to the 240V clock
Power to the clock terminals do not pass through timer to any other terminal
How to wire EH40 for 240V
240V line has 2 hot wires from breaker box.
Lets call these wires Hot1 and Hot2
These wire are interchangeable on 240V circuit
Hot1 connects to terminal 1 with a jumper to terminal 3 (or connect to 3 and jumper to 1)
Hot2 connects to terminal 2 with a jumper to terminal 5 (or connect to 5 and jumper to 2)
240V circuit has 2 wires going to the Load
Let's call these Load1 and Load2
These wires are interchangeable on 240V circuit
Load1 connects to terminal 4
Load2 connects to terminal 6
If the timer is still not working, go back to the breaker and test if it is delivering 240V to the circuit.
If breaker is bad on one leg, then the circuit can test with live power, but the 240V appliance will not work.
240V circuit requires both legs of 240V before circuit is complete.
Oct 24, 2010 | Intermatic EH40 - Electronic Water Heater...
Just got a new hot water heater, the other one was 40 gal...this one is 50 gal...I got a bigger one because it seemed like I was running out of hot water...now I am still running out of hot water when only...
Typically, a timer is not used with a hot water heater unless someone planned on being away from the dwelling frequently and didn't want to run the heater.
Another possibility would be that the heater shares a circuit with something and can't be on at the same time.
Anyway, excepting the above, it's ok to not use the timer - the heater should have a thermostat to regulate the water temperature. The "normal" setting should be high enough.
Mar 14, 2010 | Intermatic Electric Water Heater Timer...
GARDENA  Water Timer #31169-4 Logo
177 people viewed this question
Top GARDENA Hardware & Accessories Experts
Gene Haynes
Tom Chichester
Bill Boyd
Are you a GARDENA Hardware and Accessory Expert? Answer questions, earn points and help others
