Question about Microsoft Windows XP Home Edition
When attempting to open add/remove programs in the control panel, I receive this message: "Parser Message Value creation failed " at line 242" - I'm running Windows XP Home Edition - Thanks
  • 122 Answers
Http://www.errornerd.com/error.php?seed=Parse-Error&td=srch
there is a free parser error repair download at this sight that will fix your problem
Posted on May 17, 2009
"parser error: value creation failed
To get rid of this error you can switch back to a Microsoft Theme or go to /WINDOWS/Resources/Themes/ and rename the shell folder to the name of the visual style shown in the appearance tab.
If that doesn't help and it should, more info here: http://www.jsifaq.com/subo/tip7400/rh7458.htm
This is problem with C:\WINDOWS\System32\Shellstyle.dll
Copy the shellstyle.dll file from a working machine of same service pack level to your System32 folder..
Feb 05, 2011 | Microsoft Computers & Internet
Whenever i click the add/remove icon,value creation failed at line 451displays
try downloading a program called CCleaner at http://www.piriform.com/. This program is great for cleaning your computer and includes an Uninstall Tool to remove programs that you no longer use or want.
Sep 05, 2010 | Microsoft Windows XP Professional
Describe your parser message RCINT failure string
Hmmmm, I meet too, Now I'm searching how to fix?
May 03, 2010 | Computers & Internet
Adobe Flash Player Failed to Install
Try turning off any security **** as antivirus for duration of installation
Apr 03, 2010 | Computers & Internet
Cannot open outlook window - had it open checking e-mail and computer 'jammed up' and would not do anything - shut down and restarted - tried to open outlook and window flashed open (white) and immediately...
You could try and repair office by going into add/remove programs if it's XP, or programs and features if its vista.
Both are found in control panel.
Find your office 2003 line in add/remove programs, click uninstall, and you should get a repair option. YOu will probably need the disk to repair it.
Aug 11, 2009 | Microsoft Office Outlook 2007: Windows
Error msg: the application failed to initialize properly(0x000000
Option #1
1) Back up the registry on an affected system.
2) Open the registry on the Agent system by entering regedit from a run prompt.
3) Navigate to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SysPlant.
4) Open the Start DWORD.
5) Change the value to 4 to disable the drivers.
6) Reboot the system to commit the changes.
Option #2
1) Navigate to Control Panel and Add/Remove Programs for XP or Programs and Features for Vista.
2) Scroll down to Symantec Endpoint Protection and hit Change or Modify.
3) Choose Modify from the Symantec menu.
4) Uninstall Application and Device Control from the menu.
5) Restart your computer.
6) Attempt to reinstall Google Chrome.
Jun 17, 2009 | Google Chrome
Value creation failed at line 521
Hello there.
This error is usually the effect of a custom theme having problems. To verify this please do the following:
1. Open Control Panel.
2. Open the Display applet.
3. Select the Themes tab.
4. In the Theme drop-down box, select Windows XP.
5. Press Apply and OK.
Hope this helps.
Apr 13, 2008 | Microsoft Windows XP Home Edition
How do i uninstall microsoft active x control on my pc?
Internet Explorer 3.0, 3.01, and 3.02 loadTOCNode(2, 'moreinformation'); 1. Click Start, point to Settings, click Control Panel, double-click Add/Remove Programs, and then click the Install/Uninstall tab. 2. If the ActiveX control you want to remove appears in the list of installed programs, click the ActiveX control, click Add/Remove, and then follow the instructions on the screen. If the ActiveX control does not appear in the list of installed programs, continue with the next step. 3. Click Start, click Run, type the following line in the Open box, and then click OK: regsvr32 drive:\windows\occache\filename.ocx /uNOTE: drive is the drive letter on which the Windows folder is located, windows is the name of the folder in which Windows is installed, and filename.ocx is the ActiveX control you want to remove.
NOTE: If you do not know the file name of the ActiveX control (.ocx) you want to remove, you may be able to determine the file name by viewing the Hypertext Markup Language (HTML) source of a Web page that installs or uses the ActiveX control. To view the HTML source of a Web page, right-click an empty area of the Web page, and then click View Source. 4. In Windows Explorer or Windows NT Explorer, click the .ocx file in the Windows\Occache folder, and then click Delete on the File menu.Occache is the name of the folder where ActiveX controls are installed in all versions of Internet Explorer 3.x. The Regsvr32.exe file is installed by Internet Explorer and can be used to register and remove registry entries for ActiveX controls.
Internet Explorer 4.x or Later (All Platforms) loadTOCNode(2, 'moreinformation'); Internet Explorer 4.x or later, include the Occache.dll file, which is used to enumerate, update, and safely uninstall ActiveX controls using a "shell folder." 1. Click Start, point to Settings, click Control Panel, double-click Add/Remove Programs, and then click the Install/Uninstall tab. 2. If the ActiveX control you want to remove appears in the list of installed programs, click the ActiveX control, click Add/Remove, and then follow the instructions on the screen. If the ActiveX control does not appear in the list of installed programs, continue with the next step. 3. In Windows Explorer or Windows NT Explorer, double-click the Windows\Downloaded Program Files folder or the Winnt\Downloaded Program Files folder, right-click the ActiveX control you want to remove, and then click Remove. 4. When you are prompted to remove the ActiveX control, click Yes.IMPORTANT: The following ActiveX controls should not be removed if you are running Internet Explorer 4.0: • DirectAnimation Java Classes • Internet Explorer Classes for Java • Microsoft XML Parser for Java • Win32 ClassesInternet Explorer 5.0 or later does not require these components in the Downloaded Program Files files.
Error Messages Removing ActiveX Controls loadTOCNode(2, 'moreinformation'); When you attempt to remove an ActiveX control using an Occache shell folder, you may receive one of the following messages: • Share Violation These program files are currently being used by one or more programs. Please close some programs, and try again. You may need to restart Windows. • Component Removal About to remove a Windows system DLL: (<path\filename>). Okay to delete?Share Violation:
This message occurs if the ActiveX control you are trying to remove is currently loaded in memory by Internet Explorer or the Active Desktop component.
To resolve this error message, follow these steps: 1. Close all open Internet Explorer windows. 2. Disable the Active Desktop. To do so, right-click an empty area on the desktop, point to Active Desktop, and then click View As Web Page to clear the check mark. 3. Remove the ActiveX control by following the steps in the "Internet Explorer 4.0 or Later" section earlier in this article.
NOTE: You may need to restart Windows before you remove the ActiveX Control.Component Removal:
This message occurs only in versions of Internet Explorer 4 prior to 4.01 Service Pack 1 (SP1) when the ActiveX control you are removing installed files into a folder other than a registered Occache folder (for example, Windows\System or Winnt\System32). Occache cannot always determine if those files are shared by their programs.
If you are certain the file or files displayed in the message are not being used by Windows or another program, click Yes. Otherwise, click No.
NOTE: In Internet Explorer 4.01 SP1 and later, Occache does not remove (or prompt you to remove) dependent files outside of a registered Occache folder.
Support for Multiple Occache Folders loadTOCNode(2, 'moreinformation'); Internet Explorer 4.0 and later supports multiple Occache folders. The list of Occache folders is located in the following registry key: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Internet Settings\ActiveX CacheBy default, Internet Explorer 4.0 and later uses the Windows\Downloaded Program Files or Winnt\Downloaded Program Files folder. If you upgraded from Internet Explorer 3.x, both an Occache and Downloaded Program Files folder may exist. In this case, all new ActiveX controls are installed in the Downloaded Program Files folder, but previously installed ActiveX controls still work in the Occache folder. When you open the Occache or Downloaded Program Files folder in Windows Explorer, Windows NT Explorer, or My Computer, all ActiveX controls are displayed regardless of the folder in which the ActiveX control's files are located. In this case, the following string values appear in the registry key: "0"="C:\\WINDOWS\\OCCACHE" "1"="C:\\WINDOWS\\Downloaded Program Files" For additional information about ActiveX controls, please see the following article in the Microsoft Knowledge Base: 154544 (http://support.microsoft.com/kb/154544/EN-US/) Description of ActiveX Technologies For information about how Internet Explorer downloads ActiveX controls if a conflict occurs (for example, if the file already exists), please see the following article in the Microsoft Knowledge Base:
HOPE THIS HELPS
Good Luck
Feb 07, 2008 | Intel Motherboard
Microsoft Windows XP Home Edition Logo
217 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
