Question about Sony PlayStation 2 (PS2) Console
PCSX2 Problem I have PCSX2 0.9.6 softwave, I setting the Configure, and run all Test, it's OK. Memcards is setting and OK. Other setting is OK. DirectX is update new version and OK. DVD is input to PC. But when I run: File - Run CD/DVD, I see the word is: " An unhandled or unrecoverable exception occurred, with the message: The GS plugin failed to open/initialize. Pcsx2 will now close. More details may be available via the emuLog.txt file" And the PCSX2 close, I can not play it, please tell me how to do?Thanks so much !
You just download the newest version of direct x and the bios
Posted on Jul 11, 2009
I can't run my webcam on Skype.
Before you can use your webcam in any chat program you have to configure it to that program
Test your webcam here to make sure it broadcasts ok - Hit 'Allow' in the top window and check your cam in the left hand panel.
http://www.testmycam.com/
Not working ? - troubleshoot your drivers and software - get your cam working before moving on
Working OK ?
CONFIGURE TO SKYPE
Connect webcam
Its good practice to disconnect and re-connect your webcam before you start (To reboot the webcam software) - if you have been using it elsewhere the SKYPE software may have difficulty in locating it, even if you exited the previous program correctly.
The reason being, the webcam software can remain hooked-up to a program and needs to be rebooted.
Mine, I just unplug it from the USB and plug it back in to reboot the software.
If yours is integral with the computer you will have to re-start the computer, use a keyboard shortcut or disable / enable the webcam from the Device Manager.
Start Skype.
On the 'Tools' menu, click 'Options'.
In the navigation pane of the Skype 'Options' window, click 'Audio Settings'
Run down the list setting your defaults
Select your webcam as the default microphone.
Make a free test call
Click 'Save'
In the navigation pane of the Skype Options window, click Video Settings.
This will launch your webcam
Adjust quality of picture in 'Settings'
Check the correct webcam is shown as default
Click Save
Test your webcam by making a Skype test call.
For more information about how to configure Skype Messenger, please visit the following Skype Web site:
http://support.skype.com (http://support.skype.com)
May 27, 2010 | Envision Monitors V-CAM Webcam
Hi ihave an acer aspire 5600 .My webcam works with other aplications but not on skype and msn.Could you please help me?
working OK ?
CONFIGURE TO SKYPE
Connect webcam
Start Skype.
Click 'Save'
Click Save
WINDOWS LIVE MESSENGER ( MSN)
Having proved your cam is working ,you can configure it to WLM (MSN)
CONFIGURE SOFTWARE to MSN
Its good practice to disconnect and re-connect your webcam before you start - if you have been using it elsewhere the MSN software may have difficulty in locating it, even if you exited the previous program correctly.
Open MSN
Click 'Open Menu'
From 'Tools; navigate to, and click, 'Audio and Video setup'
Set your speakers
Click 'Test' - if OK, move on.
Set your mic as default
Use the slider to set volume and test.
Click 'Next'
This takes you to the video setup
Your webcam should be broadcasting - (if not - make sure the webcam is set as default - restart MSN)
Use 'Webcam Settings'to fine tune the picture.
Click 'Finish'
Feb 09, 2010 | Logitech Quickcam Chat Webcam
How do i install sound on a longitech webcam?
The webcam mic uses your computer sound system all you can do is to configure your mic to the program you wish to chat in.
Typical audio set up
Laptop with mic x webcam with mic x Vista x Yahoo Messenger
If you have an earlier OS, you may have to access your hardware from the Control Panel.
TEST SPEAKERS
Right click on speaker icon in System Tray
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
To set required (webcam) mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click OK
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
CONFIGURE TO MESSENGER
Open messenger - on top toolbar. Left click ( > ) Messenger > Preferences > Connection - Select 'no proxies' or 'connect direct to the internet' depending on the version of messenger you have
make sure your internet connection and country are correct in the lower two boxes > Apply > OK
Click ( > ) Messenger > Preferences > Calling and Audio
Set mic and speakers to show Default equipment
Run call up assistant to test audio equipment > Apply > OK
Jan 23, 2010 | Logitech 961462-0403 Webcam
I installed Skype and my webcam has audio but no video
Hello...
All you need is to install the driver on windows.
Once installed correctly on windows, now you can configure it in skpye.
Tips to configure it in skype:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Start Skype.
Click 'Save'
Click Save
ok
try this...
Jan 22, 2010 | Logitech Webcam
How to registered skype
working OK ?
CONFIGURE TO SKYPE
Connect webcam
Start Skype.
Click 'Save'
Click Save
Jan 17, 2010 | Microsoft LifeCam VX-1000 Webcam
Skype video and dowloaded videos are green
Sounds like your software is looking at a video card and not your webcam. Run through the setup again
working OK ?
CONFIGURE TO SKYPE
Connect webcam
Start Skype.
Click 'Save'
Click Save
Jan 13, 2010 | Logitech Quickcam Chat Webcam
Can't get video to show up on Skype
OK try to download latest version of skype:
available at : http://www.skype.com/intl/en/download/skype/windows/?c=101
After the download you can configure like this:
1.Start Skype.
2.On the 'Tools' menu, click 'Options'.
3.In the navigation pane of the Skype 'Options' window, click 'Audio Settings'
4.Run down the list setting your defaults
5.Select your webcam as the default microphone.
6.Make a free test call
7.Click 'Save'
8.In the navigation pane of the Skype Options window, click Video Settings.
9.This will launch your webcam
10.Adjust quality of picture in 'Settings'
11.Check the correct webcam is shown as default
12.Click Save
13.Test your webcam by making a Skype test call.
If you need more information about how to configure Skype please visit the following Skype Web site:
ok
Regards
Uttam
Jan 12, 2010 | Macally IceCam Personal Web Camera
Using the original software for 2000, pc con cam will not show pic using Sjype with xp on thinkpad
Check if your software is OK - go to this site and hit 'Allow' in top window.
If your webcam broadcasts in the left hand panel configure your webcam to Skype
If your webcam has a built-in mic
Open Skype > Options > Audio set up - run through check list > Save
Make test call from inbox using Echo/sound test.
Webcam
Options > Video set-up - run through check list - fine tune quality of picture using settings > Save
Make a test call to check settings
Oct 09, 2009 | IBM Webcam
PCSX2 Problem
if your computer does not support pcxs2 then he give an error.
or
correct the config graphic first tab with your graphic card geforce3300 is best.
May 29, 2009 | Sony PlayStation 2 (PS2) Console
I am unable to clear the memory card
First open the PCSX folder then you should see another folder inside of it called memcards. Open the memcards folder and make sure there is nothing inside of it. If there is ANYTHING inside of it, delete all the data.
Next open PCSX2 or PCSX2T (whichever you were using) and go to Config then Memcards. You'll see two memory card windows. One will say Memory Card 1 one will say Memory Card 2. You'll see three buttons below for each memory card. If there is ANYTHING in the large white windows (wich there should not be if you followed my previous directions) delete it by clicking whatever is in the white window and click the Format MCD button. Do this untill there is nothing in the Memory Card 1 window and Nothing in the Memory Card 2 window. If there was nothing in those white windows when you first opened it then you're fine, click OK and try to play your game again.
Jul 14, 2008 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
3,115 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
