Question about Loewe Concept L32 Platinum 32 in. LCD TV
Tv to heavy to move,cannot get behind, need to know the location of the skart lead so i can plug a dvd player into it.
My television is mounted on the wall and i cannot get behind it but i want to find the skart lead,there is a panel on the right side of the television which i cannot open is this the location of the skart lead,i have no instruction because the tv came with the house when i moved in.
    Problem Solver:
  • 9 Answers
All Loewe connectors are underneath set. Look from the bottom.
Posted on Jun 07, 2009
DVD is playing but no sound is coming out. Where do you put the video cords from the player to the TV. We have an older Sharp tv
What is the model of your DVD Player? and does your old Sharp TV have jack plugs in the back to accept audio leads.
Normally you would connect a Scart lead from the DVD player to the back of your Sharp TV.
If your Sharp TV is so old that it does not have a Scart Socket then you may have to use an RF lead running from the RF out Socket from your DVD player to your Sharp TV!
Jun 22, 2011 | Televison & Video
Trouble trying to connect my dvd player and set it up to my new 42 " L cd lost instructions!
You will need to determine if your DVD player is HDMI or Scart. If you connect it via a scart lead, then it should automatically turn on when you power it up, if not it will be located on your tv under the appropriate source/input label, ie AV1/AV2, or SCART.
If you are using a HDMI lead, then you will have to turn it over yourself, as HDMI does not support switching control. To do this, locate the input button on your remote (sometimes labled source) and press it until you can select the correct HDMI input using either the directional buttons, or by repeatedly pressing the input button.
Hope this helps
TV_Doctor
Jan 03, 2011 | Hitachi 42HDS69 42 in. Plasma Television
Need to know how to hook up a Toshiba DVD player to a TV
To hook up a toshiba DVD player to a television, you need to get the prongs, that you will use to hook them up.
You have a prong with red and white tip, locate the audio out on the DVD and plug in one of the prong in it then locate the audio in on the television, then you plug the other prong in the video out of the DVD player also you plug it in the video in of the television.
That is all you need to do, then you ensure you have your television on the AV mode to enjoy the DVD player on it.
Take care and good luck
Oct 22, 2010 | Toshiba SD-2109 DVD Player
Seems like a really dumb question....my tv is mounted and I can not seem to find the rca jack area to plug in a dvd player or video game system. Where is this area at on the television, is it hidden...
Try look on the right side of the tv frame bazel.Should have all the manual control there.Also have AV RCA jack area or HDMI hubs for HD cables connections.
Oct 08, 2010 | Vizio P50HDTV10A 50 in. Plasma HDTV
Have a Magnavox (31YA--??) DVD/CD recorder/player which due to moving and busy, I have NEVER installed; and have at the same time lost the manual. HAVE PLENTY of cords to match colored terminals; but "S"...
The S-Video "holes" the tv and the dvd player each have a S-Video.Hook it up with a one black video cable to the S-video to the hole in the tv and the other side to the S-Video in the dvd player.U have a RCA cable have 2 plugs lead each sides have 2 connections one RED,one White lead connections. Plug that RCA cable 2 connections in INPUT holes in the Tv ,and the other sides 2 connections one WHITE,ONE RED to the DVD player for sound.
Apr 03, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
INSIGNIA LCD NOT WORKING
check skart lead connections,and check that the tv is on the right channel,ie av1,av2 ,or skart 1or 2
Jul 30, 2009 | Insignia NS-L26Q-10A 26 in. LCD TV
Poor picture quality on cable input
Try swapping some cables around, like the skart lead from the dvd(if scart) for the cable one, if the picture problem swaps with the lead then thats the problem. If it doesn't try settings on the cable and tv, if the cable is sending nvbs signals and the tv is set to pal then this can also occur.
Jun 30, 2009 | Dell W2306C 23 in. HD-Ready LCD Television
Connecting TV, Sky box & DVD player
If it's just an DVD Player, the easist way is just run a skart lead from the player out socket to the spare skart (ext2) on the TV. Then choose ext2 on your TV remote.
Jan 06, 2008 | Alesis MasterLink ML-9600
Connecting a dvd player to a BUSH Bush BTV180T 14in TV/VCR Combi
if there is a scart connection on your bush tv then
you can use your panasonic dvd player on it, trust me
just look all over the remote carefully for an AV button, or failing that press channel up or down whilst the DVD is powered up and playing a disc and you will have solved it
hope this helps mate
Nov 05, 2007 | Bush DVD142RC 14 in. TV/DVD Combo
Loewe Concept L32 Platinum 32 in. LCD TV Logo
101 people viewed this question
Top Loewe Televison & Video Experts
Jerry Umali
Grantec 2000
Level 1 Expert
Are you a Loewe Televison and Video Expert? Answer questions, earn points and help others
