Question about Mitsubishi VS-50607 50" Rear Projection Television
Mistu VS-50607 Error Code 2-4
What needs to be done to fix this problem. Thanks!
    Genius:
  • 1,153 Answers
C411 and C412 can be the problem, for more info ctechnicians.com
Posted on Dec 25, 2007
What do I need to fix my mitsubishi TV that has a 2-4 error code (vertical protect)???
I had three tv's VS-50607,VS-50605, same problem.I called Mitsubishi and got no help.Took me two years to find because the sets were not acting up when I was there.Last set was out completly with 2-4 code. Found problem to be cold solder connection of DY (Yokes) on vertical .I bent the tip on my Weller gun and used a mirror and soldered. It was a sure repair.I went back to the first set,and soldered and it repaired it!,The second set got junked out before I could get to it.
Sep 18, 2011 | Mitsubishi VS-50607 50" Rear Projection...
Hello - I have a Mitsubishi VS-50607 - which turns off as soon as it goes on. I held the Menu & Input button - which keeps giving me a 2-3 code. In the past, when this is happened, I would just...
It cvould be t5he processor could have some garbage in it and you need to unplug it fro 40Min, to do a complete reset on the processor. Also if it turns all one color before shutting down, then that color Sceen voltyage needs turn down.
Aug 28, 2011 | Mitsubishi VS-50607 50" Rear Projection...
Vs-50607 turns off by itself it might come on after about 8hrs
if you hold menu and input on the front panel it will blink a code to tell you
where the error likely is. hold the buttons for 5 seconds and you'll get a 2
digit error, like 1 2 = no error..
“12” ... indicates no error has occured.
“21” ... X-Ray Protect circuit.
“22” ... Short Protect circuit.
“23” ... Horizontal Deflection failure.
“24” ... Vertical Deflection failure.
let me know what you find.. it will determine area of failure
Jan 08, 2009 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi 50607
22 is the code for short protection. Which means the set has shot down due to one of the components being shorted. My quess would be at least a 3 to 4 hundred dollar repair maybe more depending on the shops integrity.
May 09, 2008 | Mitsubishi VS-50607 50" Rear Projection...
Error code 2-2
Check for open fuses F9A04 and 05 if these are open then - and + 24v line to the convergence is suspect. For more info ctechnicians.com
Nov 17, 2007 | Mitsubishi VS-50607 50" Rear Projection...
VS 50607 50 inch
Deflection Protect is the problem. You can check C411 and C412 on main board to see if bad. More info ctechnicians.com
The VS 50607 won't turn on.
I'm not sure of the fix, but my manual says the 2-3 error code is due to Horizontal Deflection Failure. Hope this helps. I just uploaded my service manual, it should be available in 24 hours pending fixya's approval.
Oct 30, 2007 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi VS50607 Self Diagnosis 2-3
  1. Turn on your TV. If he TV request your secret code press QV and 9 at the same time.
  2. Press menu to view the main menu.
  3. Use up or down key to select "Chip Parent Lock" and press enter.
  4. The on screen display wil ask for your current passcode. Press QV and 9 at the same time.
  5. The on-screen display will now ask you to enter a new code.
  6. To cancel the passcode permanenly, press menu or home.
  7. To change to a new passcode, use the number buttons to enter a new code, then press enter.
  8. You must use the remote control included with thisTV. You cannot use a universal remote.
Oct 21, 2007 | Mitsubishi VS-50607 50" Rear Projection...
Help with self-diagnosis/repair
Hey there, do you have the service manual? I can't help you with the specific technical stuff, but the manual says, 2-2 error code: Short Protect circuit.
Oct 08, 2007 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi VS-50607 50" Rear Projection Television Logo
98 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
