Question about Sony FD Trinitron WEGA KV-27HS420 27" TV
Our Sony TV remote control won't work because the function 'tv' light stays lit.
  • 2 more comments
  • margareth504 May 17, 2009
    It has new batteries. Any other suggestions?
  • margareth504 May 18, 2009
    This remote (RM-Y135) came with this TV, several years old. When batteries are inserted, the function 'TV' light comes on and will not go off, preventing any other buttons from working.
  • fougzki May 11, 2010
    Ok if your set correspond with the title itself (KV-27hs420) here's the link for your remote.
    Link for its manual;
    http://www.retrevo.com/support/Sony-KV-2...
    click view all then goto REMOTE CONTROL or if you have the manual try to read.
    If it is not like that before. Or if its remote is some kind of programmable one. Try to reinsert battery or new battery is actually not good. Try to reinput its code. Or you gonna have already to replace it.
Get new batteries
Posted on May 17, 2009
I have one of the old big screen tvs the hitachi rear view screen projector tvs I am trying to find a universal remote that would work perfect on it as we bought it from someone and didn't have a...
Generally universal remote controls won't work for all functions to any TV like its original remote do. Some functions may not differ, that is, if you try to up the volume, the tV's volume will go down, and so on. The most we can do is to try with other setup codes for the tV brand with the remote control, and synchronize it, check the functions, and accept a code which will give you most of TV's functions alright. I hereby attaches setup codes for Hitachi brand TV' both 3 digit and 4 digits. Try them, and see which code suits to your TV the most.
Three digit codes for Hitachi are: 001/ 004/ 009/ 013/ 059/ 061/ 079/ 088/ 091/ 137/ 139/ 140/ 141/ 142/ 143/ 144/ 145/ 146/ 179/ 210
Four digit codes are: 0088 0059 0142 0060 0072 0004 0009 0091 0001 0012 0061 0137 0139 0141 0179 0227
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search
If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1000 posts to different brand TVs now. Pull up older posts there.
Oct 22, 2012 | Televison & Video
Need remote control code for sony trinitron KV-28LS35U
Hello
Here are some setup codes for Sony TV. Select one which will have maximum functionality. Check with all of them, and select one which can operated maximum function with tV. It is a trial process. If one stup code won't allow to some functions, try an other one, till you get maximum functions can be controlled with.
0128 0013 0002 0071 0380
002/ 006/ 071/ 128
Direct Code Entry
Feb 15, 2012 | Televison & Video
Whats the code for a Sony t.v
Codes for the Innovage Jumbo for Sony TVs are: 002, 006, 071, 128
Manual code entry instructions:
1. Switch on the TV
2. Point the remote at the TV and hold the "CODE SEARCH" button until the small red light illuminates and stays lit.
3. Press the "TV" button the remote
4. Use the number keys on the remote to enter the first code from the list above 0 0 2
The red light will flash each time you press a number key and will switch off after you enter the final number.
5. Press the ON/OFF button on the remote. If the TV switches off, switch it back on and test some of the other buttons to make sure they work and contol the correct functions.
If the device does not switch off or many of the buttons don't work (or control the wrong function), repeat the above process from step 2.
Please note: not all universal remotes will work with all TVs
If you have tried all of the above codes and still cannot get your remote to work with your TV, please post back for further assistance.
Regards,
BElectric
Dec 22, 2010 | Innovage Jumbo Remote Control
Remote control doesn't work. Small red light stays lit.
First check the remote control with a similar TV.
By keeping a MW radio receiver you can check the functioning of the remote by pressing the keys. Radio will give garble sound!
If remote is OK , TV has to be checked.
Apr 05, 2010 | Casablanca Fan Versa Touch2 W-72 Remote...
Jumbo Control Code
The codes for this remote are different depending on whether you are trying to control a Sony TV or a Sony DVD player. Please post again with more information, or use the auto-search function of this remote.
To have the remote try each TV code it knows one at a time, follow these steps:
  1. Turn on your TV.
  2. Press and hold the CODE SEARCH button for at least 3 seconds until the red LED lights up and stays lit.
  3. Press the TV button on the remote so that the LED blinks once and then remains solid red.
  4. Press the ON/OFF button slowly and repeatedly until the TV turns off. The LED will blink once each time you press the ON/OFF button.
  5. Once the TV turns off, press the ENTER button to store the code and the LED will turn off.
To program the remote for your VCR, repeat this process starting with turning the VCR on, then follow the steps substituting the VCR button for the TV button.
I hope that helps.
Nov 18, 2009 | Innovage Jumbo Remote Control
Need to how to set remote philips TV an DirecTv
there are several. try each one seperate.
1. press and hold setup button until the red light stays on.
2. press and release the desired mode button (example t. v.) the light will blink and then stay on.
3. enter one of the 4digit codes.
note: if the code is valid the light will turn off if it flashes it is an invalid code.
4. with the device on press the channel up and down. if the remote only controls some of the functions try another code.
these steps will set up the first device and then to set up the second device just repeat the steps choosing the other device and the code for it.
CODES: for the tv: 0514,1174,0062,0204,0184,0208,0205,0206,0207,0004,0189,0183,0019,0200,0081,1149,1154,0288,0456,0003,0008,0068,0075,0086,0087,0141
for the direct tv: 1049,1766,1767,1768,0622,0632,0629,0623,0576,0586,0616,0613,0630,0634,0636,0638,0641,0652,0653,0657,0659,0607,0619,0537,0538,0539
If none of the the codes work try following these steps:
1.manually turn on the t.v.
2.press and hold the setup button.
3. press and release the tv button the light will blink once and then stay on.
4.press the channel button repeatedly up to 300 times until the device changes channels. the light will blink and then stay lit.
5. press and release the mute button to store the code the light will go off.
Aug 28, 2009 | Philips Magnavox Learning Universal Remote
RC codes for ge-24914-d to control sony Trinitron TV KV-27S42.
the codes for sony are 0128, 0013, 0002, 0071, 0380, or 0152
1) Make sure the tv is on.
2) Press and hold the set up button till the red light on the left hand corner stays on.
3) Then press tv then release quickly so that the red light flashes once. (its pretty quick so pay attention).
4) Then enter one of the four digit codes and the red light will turn off.
5) Then press channel up.
If it goes up u have the right code. If not start from the begining (holding the setup button down) and do the same steps for each of the codes, one of them should work if not u have to do a code search. Follow steps #1, 2, 3, and 5 but on step 5 press it repeatedly (for up to 300 times and it says that on the instruction manual) until the device can be controled. The red light blinks then stays lit
6) press and release mute to install the code. The light will go off.
Jun 27, 2009 | GE JASRM24912 Remote Control
Lost remote control functions
Hi, The remote lost the code and needs reprogrammed, there are 8 code choices for a sanyo tv. Manually turn on the tv. On the remote, press the code search key till it lights, press the tv key, it will blink then stay lit. Aim the remote at the tv, keep it pointed at the tv and press the on/off key ONCE. When the tv turns off press enter. If you wait more than 3 seconds it will scan to the next code. So if you try it the first time and not all of the functions work correctly is when you would let it scan to the next one. Good Luck! Please rate my response.
Feb 08, 2009 | RCA RCR412B Remote Control
Sony FD Trinitron WEGA KV-27HS420 27" TV Logo
137 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
