Question about Canon imageCLASS 2300 All-In-One Laser Printer
Intermittent e100 code that goes away when rebooting. does this code point torward a specific part malfunction and if so what is the part number.
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 9 Answers
Replace the laser unit
Posted on May 26, 2009
Who to remove E100
Hi, without knowing specific model number, it's difficult to say.
Best guess would be the laser, try powering off for 10mins.
Or if you know how to get to laser shuttle, try and force the laser out into the center of the tracking cradle, then power off for a few minutes and try.
Aug 07, 2014 | Canon PIXMA Office Equipment & Supplies
What are the symptoms of a bad throttle position sensor (TPS).
There are a number of things. The car may idle to fast or too slow. The car may have momentary hesitation (jumps/fades) when driving. Most will eventually set a Check Engine code that will point to the TPS. the hesitation one may not though. That usually occurs when you have long commutes at steady speeds. This causes excessive wear of the TPS in one area and can cause intermittent dropouts. If you suspect this, try driving at steady speed 5-10 mpg SLOWER than usual and if the problem goes away that is probably the cause.
Nov 08, 2013 | Cars & Trucks
Error Code: E100 0000 Printer error. Turn off the printer, and then turn it back on again after a moment. If the same error occurs, turn off the printer, then contact the store where you purchased th
It is possible a reboot may correct the issue, but current indications are the error indicates a bricked console. You may go back through the retailer you purchased the console from in order to quickly receive a new console right away rather than going through Microsoft, which will repair the console over the course of a few weeks. This is the recommended course of action, though not the only one, as Microsoft's return times do promise to be hastened.
For more help visit cbrtechsolutions
Feb 02, 2013 | Canon LBP6000 Laser Printer
My 2001 525td starts and drives ok but intermittently it wont go above 3000 rpm,if you stop and switch it off it goes ok again for a short while
HI, your car is most likely going into limp mode. The number one cause of this computer shut down restriction- is a Mass-Air Flow sensor malfunction. Fuel trims become erratic and the engine computer puts a order in to limit performance until the original problem is resolved. The fact that you can get performance back after shutting down car and restarting is that the computer is rebooting and most likely the sensor is now functioning properly and or has not set the number of faults required for limp mode. What I would do is have someone with a scanner look for DTC's or engine problem codes, and remember the following: Lean or Rich fuel trims detected bank 1 bank 2 (is a Mass Air flow problem)Replace Mass Air flow sensor assembly. Accelerator position high or low and or erratic is most likely (Pedal sensor) Replace Pedal assembly. Good Luck.
May 18, 2011 | 2007 BMW 525xi Sedan
9@how to fix dtc p1178 and p1118 on a 2002 hyundai xg350
I live in Australia & have a Hyundai Grandeur XG 3LT V6 2002 model (US equivalent is Hyundai XG300).
Fault codes are P1118 (ETS motor fault) & P1178 (ETS motor battery voltage open). An intermittent fault.
The first code denotes general area of the fault & the second code denotes the specific fault.
So the specific fault is that the ETS-PCM computer is not receiving 12V on pin 2 with ignition on.
'Check engine' light remains on & car is in 'limp home mode' with very little power & poor performance.
I had purchased the Hyundai service manual online (ebook about $8) for the US model. Could not find any
manual for the Australian model. On page FLA-52 found the block diagram for the whole ETS system.
I am a retired electrical engineer so now it became easier for me to find the fault.
There are 2 computers behind the center console. PCM & ETS-PCM.
Pin 2 of the ETS-PCM should have 12V present when ignition is on.
In fault mode 12V was not present. This 12V is supplied from ETS 15A fuse (fuse box under dashboard)
via a relay (i will call this relay the ETS relay). The 15A fuse was OK but the 12V was only
intermittently being passed through the relay points. Relay is located near ignition switch on a
sub panel which has about 6 relays on it. ETS relay was at right bottom corner of sub panel.
Yellow wire feeds the 12V (which is always present even with ign. switch off) to the relay points.
White wire is the output wire from the relay points which feeds 12V to pin 2 of the ETS-PCM computer.
Measure if 12V is present at white wire when ign. switch is turned on (no need to start engine)
I only had the 12V present intermittently. So pulled out the ETS relay - tested contacts with
ohmmeter & found to be only making contact intermittently when relay lever depressed
- removed relay case by grinding away one corner of the case - cleaned the relay points with fine sandpaper.
replaced the relay case & taped with black insulating tape to keep out dust. Tested relay with ohmmeter & points
now OK. Fault is now cleared & car is operating normally.
Also had previously purchased on Ebay a Can OBD11 scanner for $15 which read the fault codes OK.
Hope this helps other people with similar problem.
Mar 15, 2011 | Hyundai Motor 2003 XG350
I have a 1999 cadillac deville with the ABS and traction control lights on. I had the codes checked and its coming up c1233 which is right wheel speed circuit open or shorted. I have had the wheel...
Diagnostic Aids
• It is very important that a thorough inspection of the wiring and connectors be performed. Failure to carefully and fully inspect wiring and connectors may result in misdiagnosis, causing part replacement with reappearance of the malfunction.
• An intermittent malfunction can be caused by poor connections, broken insulation, or a wire that is broken inside the insulation.
• If an intermittent malfunction exists, refer to Intermittents and Poor Connections Diagnosis in Wiring Systems.
Do you know how to do automotive electrical wiring trouble shooting ? Use a DVOM - digital volt ohm meter ? How to use a wiring diagram to pin point testing spots in a electrical circuit ? Testing before replacing parts is key !
May 28, 2017 | 1999 Cadillac DeVille
I have 3 different amps each with pretty much the same problem: One channel intermittently goes out. Power cycling sometimes recovers it temporarily. Also when I play with the input level (on the source...
I recently had a similar problem with a Technics amp having an intermittent low or no sound from the left channel. This was traced to intermittent contacts in the speaker protection relay and this may be a good place for you to start looking. Check for dry joints on the relay pc board terminals. The relays can be removed, dismantled and the contacts cleaned with a fine file and contact cleaner.
Mar 28, 2010 | Audio Players & Recorders
95 tahoe, service engine soon light comes on & shift points off
Well you should have it scanned for codes.Se what is realy going on.I hear that autozone does it for frre.I'm sure that other parts houses do it as well.
Jan 24, 2010 | 1995 Chevrolet Tahoe
Can somebody help me what this mean? Error Code: E100 0001- E100 0002 it is a canon LBP5000
Symptom
  • E061-0001 (Potential ON)
  • E061-0002 (Potential OFF)
  • E100-0001
  • E227-0004
Cause
  • The pin is broken on the Primary Fan 2 Duct. The Laser Shutter is activated by the pin on the Primary Fan Duct Assembly. The linkage is pinched not allowing the laser shutter to be fully actuated (may also indicate E227-0004). Faulty Laser Scanner Assembly.
  • Defective DC Controller PCB Assembly.
Action
  1. Check the shutter operation and the pin on the Primary Fan Duct Assembly. If the pin is broken replace the Primary Fan 2 Duct (iR6570 : FC6-3540-000 / iR5075 : FL2-5834-000) or the Primary Fan Duct Assembly (iR6570 : FM2-3074-000 / iR5075 : FM2-9694-000). If the Laser Scanner Assembly (iR6570 : FM2-3670-000 / iR5075 : FM2-9832-000) has been replaced and error codes E100-0001/ E227-0004 are intermittently indicated, proceed to the next step.
  2. Remove the Primary Fan Duct Assembly (this assembly has a pin on it that activates the laser shutter).
  3. Remove and reinstall the Laser Scanner Assembly.
  4. Install the Primary Fan Duct Assembly. This should free the linkage allowing the laser shutter to be fully actuated.
  5. Finally a DC Con clear resolved both of the intermittent issues (E100-0001/ E227-0004).
May 28, 2009 | Office Equipment & Supplies
Canon imageCLASS 2300 All-In-One Laser Printer Logo
91 people viewed this question
old marine
old marine
