Hey!
my blender circuit breaker was tripping off n off until the blender stopped working.
do i have to change the breaker or its the blender that's affected
If the power light is on and the motor is not running the circuit board that starts the motor is defective. You could try to bypass the control board and apply power directly to the motor to verify the motor is ok and no blown fuse or circuit breaker. then you get to replace the circuit board or isolate a failing component on the circuit board.
Yes that is strange, if you let it cool down and try it again with pushing the re-set button and still does not work, try plugging it into a different outlet. Find something in your place that you know outlet is working, lamp, toaster you know. If does work in another out let, then you of course griped that breaker. Then check your breaker box to see what breaker is tripped, and switch it back on, might just of had a power surge based on putting on reverse. If that don't work, I suppose possibly something in motor or switch went out. Please let me know, if it works, I will take a banana smoothie LOL
there is a voltage regulator inside the circuit board , this might have got wet some how . this circuit controls 1-10 speed from a touch of a button . will have to disassemble unit , Auth personal should check this , unless you know electronics
There is a great guy on Gerrard street in Toronto, who can fix mixer grinders and has parts also like breaker/reset switch etc.
The store is called Appliances 220, Ph # 416-778-9908.
Hope this helps.
As long as you know the plug still had power. Make sure it wasn't a GFI that was tripped. Something inside the unit must have either lost contact or burned up. Did you smell anything burning electrically?
* The contacts in the switches fried
* The motor itself fried
* The controller section fried
If you saw smoke, something fried... probably cheaper to simply replace the unit. Even if it still worked, it's a 120V electric appliance used with liquids, and I wouldn't trust it... I'd hate to hear that your blender started a kitchen fire.
i had the same problem after only one month, took in back to walmart and they would do nothing. i love the big heavy glass jar on this model so i baught another on thinking i broke it some how and guess what, the second one stopped after one and a half months. called around and no one would do anything for me, company sucks, i took the bottom cover off the blender to expose the problem and there is a problem with the curcuit board and built in breaker. i ripped out all the speed buttons and curcuit board and just wired in a on/off switch to the motor. works great again. i still had a extra broken blender so i took a old chain saw i had and turned that one into a gas powered blender. problem solved, any questions please feel free to ask.
Have you tried greasing it near the blade. I read in my instruction book that sometimes they seize if they aren't used often. They also suggest trying to soak the wand in a pot of hot water for a minute or two and then trying to use it in the water. Hope this helps
