Question about Intel Computers & Internet
I/o error. press any key to restart
After I resettled the motherboard and HDD into the new tower and started running it, I received the following message: ''Reboot & select proper Boot device or Insert Boot Media in selected Boot device'' On the old tower before the resettling everything was ok. Then I cheked all the connections, but the problem still stayed. On the other computer HDD works well. Then I installed new version of XP from the dvd-rom, but during the installation, after the setup files were copied to HDD, and the computer restarted, I received the following message: ''I/O error. press any key to reboot''. What do I do next? How can I fix it? Thanks in advance!
  • danil_misha2 May 17, 2009
    ThanQ! but pins on the right positions, BIOS see HDD
  • danil_misha2 May 21, 2009
    Thank You! I replaced the HDD and everything worked well!
  • 585 Answers
The jumper on the hard drive may be on the wrong pins for this motherboard. If it's on MA try CS and vice-versa.
Posted on May 17, 2009
  • Bruce Volkers
    Bruce Volkers May 17, 2009
    You are getting the message because the bios is unable to read any data from the hard drive. If I understand you to say that another hard drive will work fine in this system, then the error is in this hard drive. Try running through the install again, paying close attention as you delete and re-create all partitions in preparation for the install. That should clear it up.
My machine sharp MX 3100N is giving the error code U2-05, what steps should i use to solve it
This error refers to a discrepancy between the HDD & the machine. If the hard drive has not been swapped out & nothing has changed on the machine then try resetting the copier to see if that rectifies it.
To reset the machine you will need to enter simulation mode.
First, make sure the copier is in COPY mode.
Then press the following 4 keys in quick succession: # * C *
You should then have a screen showing simulation mode.
Then enter 16 & press either of the copy keys (black or colour).
This should then display U2 ERROR RESET.
Press EXECUTE, YES then press the CA key.
The machine will exit simulation mode & restart.
If after restart the machine displays U2 again then you will probably have a HDD fault. Unfortunately, the HDD would have to be replaced by an authorised dealer as new Firmware would have to be reload to allow the machine to recognise a new HDD.
Hope this helps.
Dave.
Jan 19, 2017 | SHARP MX-3100N
At first my computer cant detect my Maxtor HDD. but when i connect the sata port as a slave , it can detect the HDD. but after that it is showing " Disk but failure...." or " Disk read...
Restart the system and then press delete key when the computer start up then set the first boot to CD/DVD ROM then press F10 (save) and follow the instruction "press any key to boot from CD/DVD ROM after that First try to repair and if it's not satisfy. Please to format your Hard Disk
Hope it'll be helpful to you
All the Best!
Jun 30, 2011 | Gigabyte GA-945GM-S2 (0818313003065)...
Switch on computer tower and screen. Screen brings up LG logo and 'Activating power saving' then the screen shuts down. The tower continues to load Windows etc but I can't see a thing as the screen is...
For that when you power up the computer press F8 key then enter in safe mode then go to start menu->run type in run "chkdsk /r" without "" then restart computer then it fix errors .
If still not able to see windows then again press F8 then enter in enabler vga mode then go to display property and change screen resolution to 1024*768 then apply and ok then check.
If still same then you need windows disk boot computer with that disk.
When you power up the computer press F1 or F2 or "del" key then enter in bios then go to boot menu and set first boot device as cd/dvd rom then save settings and exit then it boot with that disk.
Follow the procedure and enter in recovery console then type "chkdsk /r" then it fix errors on harddrive then after completion restart it again boot and this time choose "repair previous windows" then it repairs it then you can use windows again.
Let me know if you need further assistance.
Thanks for using FixYa.
Feb 22, 2010 | Computers & Internet
Error loading C:program~1Mywebs~1ar.binm3plugin.dll how to fix this?
Please click on Start, Click on Run and type the following in the open box and click OK
msconfig
Vista: In the Start Search field, type msconfig , and press Enter . The System Configuration window opens.
Or
Press and hold Windows logo key on keyboard and press R. It will open Run Window. Type the following in the open box and click OK
MSconfig
Please click on Startup tab
Remove the check mark from entries related to Mywebsearch OR M3PLUGIN.DLL
Then click on Apply, Close and Please click on Exit without restart.
When the system restarts, you will see a message about System Configuration Utility. Click in the box for "Do not Show this message" and then click on OK.
Courtesy en.kioskea.net
Nov 14, 2009 | Intel Motherboard
OS won't start on Sony VGC-RB60G
To resolve this problem, start your computer in Safe mode, remove the display adapter, rename the .inf files that are associated with the display adapter drivers, restart your computer in Normal mode, and then update your display adapter drivers. The following steps describe this procedure in more detail:
  1. Start Windows in Safe mode. To do so:
    1. Restart the computer, and then press F8 while the computer starts.
    2. On the Windows Advanced Options Menu that appears, use the ARROW keys to select Safe Mode, and then press ENTER.
    3. Use the ARROW keys to select the operating system to start, and then press ENTER to start Windows XP in Safe mode.
  2. In the message that states that Windows is running in Safe mode, click Yes.
  3. Click Start, click Run, type msinfo32 in the Open box, and then click OK.
  4. Under System Summary, expand Components, and then click Display.
  5. In the right pane, note the information that corresponds to the INF File item, for example, Nv4.inf, Oem0.inf, or Atim128.inf.
  6. Quit the System Information utility.
  7. Click Start, right-click My Computer, and then click Properties.
  8. Click the Hardware tab, and then click Device Manager.
  9. Expand Display adapters, right-click the display adapter, and then click Uninstall.
  10. Click OK.
  11. Click Start, click Run, type cmd, and then click OK.
  12. In the Command Prompt window, type the following commands, and then press ENTER after each line: ren %systemroot%\inf\INF file name from Step 5.inf *inf.old
    ren %systemroot%\inf\INF file name from Step 5.pnf *pnf.old
  13. Close all open windows, and then restart the computer in the typical manner.
  14. Log on to Windows by using an account that has administrative privileges, and then wait for Windows to detect new hardware.
  15. When the Found New Hardware Wizard starts, click Cancel.
    If you receive a stop error after you remove the updated display drivers, restart the computer and use the Last Known Good Configuration option. To do this, restart the computer, and then press the F8 key while the computer starts. On the Windows Advanced Options Menu that appears, use the ARROW keys to select Last Known Good Configuration, and then press ENTER.
    If you receive a "System Has Recovered from a Serious Error" message when Windows starts, restart the computer again. This error message does not recur.
Oct 06, 2009 | Sony VAIO RB60G (VGCRB60G) PC Desktop
Windows xp will not load
Ah, the "Blue Screen Of Death".
Solution as follows:
  10. Click OK.
  16. Obtain and install the latest drivers for your display adapter.For information about how to contact your computer manufacturer, visit the following Microsoft Web site:
Mar 11, 2009 | Lenovo 3000 N200 Notebook
I am new to building pc's and I've just bought a asus p5ql motherboard, 4gb ram, intel processor and a hd. I have it all together. Green light on board, fans spin, etc. I get the Asus start up screen and...
Just follow these simple steps:
1. Make sure you have all the discs included in your package.
2. After you power-up, strike del key to go to bios/system.
3. In boot selection, select DVD/CD ROM to boot first, HDD second and other if you wish..
4. Press ctrl+alt+delete to restart.
5. After pressing the tree (3), insert your CD/DVD installer to the drive..
6. Follow the instruction...
Good luck and have a nice day!
Feb 16, 2009 | ASUS P5QL-E Motherboard, LGA775, Intel P43...
''Unable to read from disk or disk error, press ctrl+alt+del to...
Try new hard drive. Its faster than messing with all this.
Dec 23, 2008 | Abit KN8 SLi Motherboard
Error loading C:\program~1\Mywebs~1\bar\1.bin\m3plugin.dll
I followed these steps and haven't had any issues since:
1. Go to START menu
2. Select RUN
3. Type MSCONFIG and click OK (or press ENTER)
This will bring up your System Configuration Utility window.
4. Select the STARTUP tab.
5. Find M3PLUGIN, untick it, select APPLY and then OK
This will bring a popup dialogue box stating the following:
"You must restart your computer for some of the changes
made by System Configuration to take effect."
6. Select RESTART.
When your computer restarts, you should no longer receive that message.
Jun 30, 2008 | Intel Motherboard
UNABLE TO REACH DESKTOP
loadTOCNode(1, 'symptoms');-------------------------------------SYMPTOMS:------------------------------------
When you restart your computer after you install Windows XP Service Pack 1 (SP1), your computer may generate the following Stop error message:
STOP: 0x00000050 (0x8872A990, 0x00000001, 0x804F35D7, 0x00000000)
PAGE_FAULT_IN_NON-PAGED_AREA
----------------------------------------CAUSE:-----------------------------------------
loadTOCNode(1, 'cause'); This problem may occur if there is a conflict between Windows XP SP1 and the display adapter drivers that are currently installed.
------------------------------------SOLUTION :---------------------------------------
loadTOCNode(1, 'resolution'); To resolve this problem, start your computer in Safe mode, remove the display adapter, rename the .inf files that are associated with the display adapter drivers, restart your computer in Normal mode, and then update your display adapter drivers. The following steps describe this procedure in more detail: 1. Start Windows in Safe mode. To do so: a. Restart the computer, and then press F8 while the computer starts. b. On the Windows Advanced Options Menu that appears, use the ARROW keys to select Safe Mode, and then press ENTER. c. Use the ARROW keys to select the operating system to start, and then press ENTER to start Windows XP in Safe mode. 2. In the message that states that Windows is running in Safe mode, click Yes. 3. Click Start, click Run, type msinfo32 in the Open box, and then click OK. 4. Under System Summary, expand Components, and then click Display. 5. In the right pane, note the information that corresponds to the INF File item, for example, Nv4.inf, Oem0.inf, or Atim128.inf. 6. Quit the System Information utility. 7. Click Start, right-click My Computer, and then click Properties. 8. Click the Hardware tab, and then click Device Manager. 9. Expand Display adapters, right-click the display adapter, and then click Uninstall. 10. Click OK. 11. Click Start, click Run, type cmd, and then click OK. 12. In the Command Prompt window, type the following commands, and then press ENTER after each line: ren %systemroot%\inf\INF file name from Step 5.inf *inf.old
ren %systemroot%\inf\INF file name from Step 5.pnf *pnf.old 13. Close all open windows, and then restart the computer in the typical manner. 14. Log on to Windows by using an account that has administrative privileges, and then wait for Windows to detect new hardware. 15. When the Found New Hardware Wizard starts, click Cancel.
If you receive a "System Has Recovered from a Serious Error" message when Windows starts, restart the computer again. This error message does not recur.16.Obtain and install the latest drivers for your display adapter.For information about how to contact computer hardware manufacturers, click the appropriate article number in the following list to view the article in the Microsoft Knowledge Base:
Low feed backs hurt my ratings and I am tring to help you with your problem,so let me know that the information i given you is helpfull or not.
Thanks
Dilip Bagdi - (Technical Associate)
May 07, 2008 | Compaq Armada 1700 Notebook
Computers & Internet Logo
980 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
