Question about Kenmore Washing Machines
Replacing rubber seal on Kenmore Elite He3
Hi, I noticed my Kenmore elite washer leaking during the cycle. I checked around and found the rubber seal between the front door and machine shredded. Seemed like that was the source of problem. Ordered new seal and clamp but replacing it has been a challenge! Is there an easier way to install new seal? I am just trying to stick it underneath the white border around the edges and that's the tricky part. Once I can get the seal secure, I can clamp it tight. There is not a whole lot of room to make sure that it goes around smoothly. Is there a better/ easier way to do this? I have the same repair replacement challenge on a Kenmore Elite het5 front load. A sears repairman replaced the old seal that had ripped with a new one but it is not installed properly with water is leaking worse than before. I was able to pull the ring clamp with my hands. I reported to sears but another week before they can return. I can do thois job with some instruction. Any help?
2 Suggested Answers
  • 878 Answers
SOURCE: Replacing rubber seal on Kenmore Elite He3
Gowalia, it's going to be a fight without removing the front panel. This is the easiest and not that hard. Remove the top, by removing the 3 screws in the rear. The top will slide off toward the back. Next remove the control panel. Remove the 2 screws on each end on top. Remove the detergent drawer. Remove the torq screws behind the detergent drawer. The control panel will now snap off, pulling from the top and lifting up. Once freed, remove the control panel ribbon cable from the side of the main board. Now remove the screws holding the door switch mechanism in place. Remove the spring that holds the outer part of the boot from the front panel. Now remove the 4 quarter inch screws that hold the front panel and door on the front. Now you can install the new boot with ease. I know it sounds like a lot, but it is not that bad. Just reverse the process when the boot is on the tub. Make sure to have the mark on the boot ^ lined up with the mark on the tub on top. Catriver.
Posted on Sep 06, 2007
Kenmore elite He3 leaking water into tub
Outstanding diagnosis. You are correct to assume a water inlet problem and, "yes", this can be a common problem. If you live in area that has hard water, or if you use well water, sediment, rust and calcified deposits can clog the small diaphragms inside the valve causing them not to close properly and leak by. You can attempt to clean the valve by removing it and submerging it in a 50/50 solution of distilled vinegar and hot water for about 30 minutes, Sometimes this can dissolve any clogs and restore the valve to full operate. However, if this does not work, you will need to replace the valve.
The following link explains the steps required to replace the valve if you need directions:
I have included web resources to search for replacement parts.
If you have any questions about this repair, please post back and let me know. I hope this helps you.
May 29, 2010 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
My Elite He3 washer leaks horribly out the door.
the door could be bent out of alignent but its just as likley to be the rubber door seal,, and that is no easy job to change but its not impossible if i were you i would play it safe and have the repair man look at it,,,
saves all the greef from the wife if it gos wrong on you
Oct 26, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore 'elite' HE3 front loading washer
I have the same problem. Nothing works fcfor the mildew. i have bleached it, used simple green and used baking soda. That washer is the biggest piece ever!! Good Luck!
Jul 06, 2009 | Kenmore Elite 45986 Front Load Washer
Leaking water during spin cycle
Likely the tub seal is failed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 28, 2009 | Kenmore Washing Machines
Help! Mt Kenmore Elite Quietpak2 HE3 keeps
F/06 Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
  • Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  • Check the Drive Motor
  • Check the MCU
  • Check the Wire Harness
Mar 10, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore HE3 will not HOLD water, drips out into the pedestal
check to see if there are any rips in the door seal,then take the bottom of the washer off you will see 3 screws holding it on. see if the water is coming out of the pump that is right behind the panel that you took off.
Dec 30, 2008 | Kenmore Elite 45986 Front Load Washer
Leaking Kenmore elite he3 washing machine
removethe lower acess panel 3 screws across the bottom , run the cycle and watch to see where exctly the leak is coming from it should be quite apparent
Mar 09, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore Elite Fronloader Water Problem
the water inlet solenoid valve has debris stuck inside of it, thereby not allowing complete "off" mode. best to remove it and clean the water path thoroughly. valve is found by tracing the inlet water hose.
Jun 03, 2007 | Kenmore 46462 Front Load Washer
Open Questions:
Washing Machines Logo
396 people viewed this question
Sal De
 Brian Main
Brian Main
