Question about HP f2105 21" LCD Monitor
How can i open the body or case to repair of hp
How can i open the body or case to repair of hp vp15 lcd monitor
  • Dan Todd May 11, 2010
    Unless you are well versed in working on these monitors, I highly advise you take it to a repair shop. Best Buy had one.
    Sergeant:
    Champion:
  • 225 Answers
Please check first if your LCD monitor is still under Warranty period, if yes, then I recommend to bring the unit to authorized service center to properly diagnose & fix the problem, because if you open it yourself & probably broken its seal then the Warranty will be Void & other problem/s that may arise / found will no longer be covered by their free service / part replacement.
If no longer covered by a Warranty, then you can open it by yourself, by turning (counterclockwise) its lock screws to open its back cover & check the circuit board parts / connections if loose/broken/defective. regards
Posted on May 20, 2009
@eeugenio24: do you know how to read? the question was how to open it!!!!!!!!!
does anybody here know something? or are they just trying to be an expert just by posting crappy stuff!!!
Posted on Aug 19, 2010
2 Suggested Answers
SOURCE: How can i open the body or case to repair of hp
well being as how i just did this five minutes ago I can help:) The back of the monitor has a thin panel like a sideways 8 or a bean shape...this pops off then you have to take out the screws holding on the base once you get that off you can lay the monitor flat <carefully> and pop the outer black frame off <every so often along the seam you will see little gaps stick a thin flathead in if it's to tight for you carefully not to scratch or break it is plastic!> then you will see the metal case and find the screws on the sides and your there! Good luck!
Posted on Sep 10, 2009
Hello, I opened the LCD monitor to right angles
The most likely cause for this is a damaged or defective flexible ribbon cable that connects the LCD to the camera body and can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
Sep 01, 2011 | JVC GR-D870 Mini DV Camcorder
How to open the outer body of ho l1706 lcd monitor
They are not meant to be user serviced and are frequently glued. Take out every screw you can find and start prying.
Sep 06, 2010 | HP L1706 17" LCD Monitor
Hey please tell me the way to open an LCD l1906 ... i have remove all the 8 screws but cant open it :S
inc_power, Please go to YOUTUBE and watch some video clips of how the professionals do it. Try this. "lcd monitor disassembly" and "lcd monitor repair" for starters. Be careful and do not use sharp cutting instruments to pry with or you may be making a trip to the local hospital ER to have doctor sew up the gushing wound you have inflicted upon your body. Parting the rear cover from the front "bezel" is the "key" to getting inside unit. 12fixlouie
Jul 20, 2010 | HP L1906 19" LCD Monitor
Please tell me about monitor going to sleep
The monitor goes into standby mode if it does not see the video signal from the PC or there are problem inside the monitor. Try it with other PC first, also check the pins on the VGA cable. If it still does not work, you will have to open it up. First place to check will be th caps (leaking/bulging top) in the power supply first, for this 2001 model year, I will not be surprised if it has bad caps.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jun 01, 2010 | HP Pavilion vp15 Monitor
How to open the LCD Casing for Samsung 740N?
htommie, Watch some video clips at YOUTUBE under "LCD monitor disassembly" and or "LCD monitor repair" to see if you really want to do that. The hardest part is "PARTING" the rear plastic cover from the front "BEZEL". You also might find some info at www.ccl-la.com run by another FIXYA guy with nickname "buddymc" Hope this helps. 12fixlouie
Jan 28, 2010 | HP Pavilion F1503 15" LCD Flat Panel...
May 18, 2009 | HP f2105 21" LCD Monitor
My lcd hp vp15 monitor cannot power on,when i push power swich it then power swich flashing but screen does not anything screen is black.please help me
Its a problem with the monitors power supply ,you will have to take it to an HP support center and ask for a quote.
if it's under warranty then you won't pay to fix it.
May 06, 2009 | HP f2105 21" LCD Monitor
We have a HP vp15 monitor. Recently we have not had any sound.
Monitor control buttons are located on the front panel of the monitor on the lower right. Make sure that you connect the built-in monitor speakers to the computer, using the audio cable (green connector). The connection on the monitor is located on the back of the monitor. On that monitor I believe the volume button is the second one (from left tot right) on the lower right. Also you may want to check your systems volume on your computer by left clicking one time on the little speaker on the lower right of your screen by the clock.
Hope this helps
-Curtis
Rate It!
Jan 29, 2009 | HP Pavilion vp15 Monitor
Monitor flickered and then... smoke!
Hi Konsuma, You can open the monitor case and look to see what is damaged and order a new circuit board if needed. Check with www.lcdrepair.net parts and/or Repair.
Oct 09, 2007 | HP Pavilion F1703 17" LCD Monitor
HP f2105 21" LCD Monitor Logo
281 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
