Question about Samsung Refrigerators
When i plug in my fridge freezer it trips all the kitchen circuits
  • 159 Answers
It can be the defrosting element try to disconnect the defrosting element first and if it still trips the power the motor are down to earth means it was struck by lightning
Posted on May 22, 2009
Keeps popping DMI immediately when it is plugged in its a refridgerator
Refrigerators need to be plugged into a regular outlet without anything else plugged in. DMI's, GFI's, or GFCI's are designed to trip at the slightest increase in amp draw. When the compressor turns on the outlet senses the spike and trips the curcuit. So to fix the fridge plug it into another outlet that is not part of the dmi circuit.
Nov 02, 2016 | Frigidaire Kitchen Ranges
Find out why my freezer is shorting
Is your FREEZER is plugged into a wall socket which is protected by an EARTH LEAKAGE UNIT or RCD [Residual Current Device] ???
Most manufacturers advise NOT to have this type of appliance connected through an RCD as the start load required when the COMPRESSOR "kicks in" is quite large [especially in larger fridge/freezer units] AND will quite often TRIP your RCD. These appliances are better connected to a separate electrical circuit if at all possible and not protected by an RCD.
Sep 20, 2014 | Refrigerators
Fridge freezer tripping rcd
Ensure it fully dries out before trying it again. Water in the electrics will throw your trip instantly. If it's dry now, and you are having the same problem. check the electrics for a short circuit or earth fault. Usually a compressor earth fault is to blame.
Apr 21, 2014 | Refrigerators
Hi, I have a Kenmore top freezer refrigerator model number 363.79567990. The freezer stopped working and I found out that I had to press the "Reset" button on the outlet while it was unplugged...
It sounds like you've plugged your fridge into a GFI (ground fault interrupter) outlet.
The National Electrical Code (NEC) article 210.8 A (6) says in dwelling units, only those outlets in a kitchen (I'm assuming your fridge is in the kitchen - right?) "where the receptacles are installed to serve the countertop surfaces" must be provide ground fault protection aka "GFI outlet". Unless your town, city, county or state has laws that supersede the NEC, you should have the outlet changed to a standard, grounded outlet to prevent the nuisance tripping you are experiencing when the cooling compressor is trying to start. A refrigerator is not a counter surface appliance, and therefore does not require GFI protection.
The other outlets are fed from this outlet, so when you connect the fridge to another outlet on the circuit, the same GFI plug trips again. When you replace the GFI plug with a "regular one, the GFI plug should be installed in another outlet to provide the GFI protection needed in the kitchen - as described in the NEC above. If you are not familiar with how to do this, please, call a licensed electrician to do this very important job for you. Be safe & be smart.
I hope this helps!
Nov 01, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore Refridgerator freezer pops GFCI outlets
most gfci are 15 amp draws
its quite possible your refer needs 19 or more to start
i would reccommend getting the unit of gfci plug
Oct 12, 2009 | Refrigerators
When I plug my freezer to an outlet not gfi protected it works fine, but when I plug it into an outlet that is gfi protected it pops the breaker. I dont understand why.
All fridge and freezers should be plugged into an NON-GFCI protected outlet, since the inital start of the compressor can cause the GFCI to detect a millivolt surge, when the compressor starts, causing the GFCI to trip.
If this is in a kitchen, you should change out the outlet to a non-GFCI outlet BUT only to a single outlet that only has the freezer plugged into.
If it's in a basement, garage, or some other place with a GFCI outlet, you can change out that one outlet to a standard single outlet device of which ONLY the freezer will be plugged into and remain code compliant. You will need to make sure that any other outlets served by that current GFCI outlet stay protected, by installing the GFCI you swap out, and put it in place of the NEXT outlet in the circuit.
By doing that, you will have the first outlet that was the GFCI, now a single outlet NON-GFCI serving the freezer, but the next outlet in the branch circuit gets a GFCI outlet, thus protecting the rest of the circuit, in compliance with the NEC (National Electric Code)
If you need further help with this, please comment back and I'll check back later and provide you more detailed info. Of course, be sure to turn off the breaker to this circuit before making any changes to the outlets, etc.
Hope you find this Very Helpful and best regards!
Aug 21, 2009 | GE Freezers
Everytime I plug in the power cord, it trips the breaker.
Refrigerators are not designed to run on a GFCI. Try a heavy duty extension cord to the fridge from a outlet that is not GFCI protected. If it still trips you probably have a short circuit in the compressor.
May 13, 2009 | GE GTS22KBP Top Freezer Refrigerator
Fridge freezer shorting out electrics
The cause of this situation could simply be an overloaded circuit. Homes are built with dedicated circuit for fridge only now because of this. If you notice power outage in other rooms or other appliances in kitchen then the circuit affected,I.E. other outlets affected need the load lightened. If it is a dedicated circuit then could be faulty breaker or possibly altered wiring could be cause.These have to be ruled out before you will know for sure. If it isn,t dedicated outlet for fridge only, just plugging in a light could overload loaded circuit.
Apr 21, 2009 | Refrigerators
Fridge/freezer trips plugs when turned on
If it trips the breaker would recommend checking the compressor for burn out unless you know for sure the elements have direct short causing this to happen. I think the compressor may have a short, start relay,or start capacitor is defective. Let me know what you find. Could be a bad breaker or too many things on same circuit, send model and make number so I can help you better, Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
Apr 14, 2009 | Refrigerators
Refrigerators Logo
197 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
