I can only get 2 speakers to work - the L and R speakers - I don't know how to tune in the central and other 2 speakers :-) I don't have the instruction manual
  • 1 more comment
  • louisebrown May 18, 2009
    It is a Kenwood KRF- V5100D amplifier with KS - 2200HT speakers and a SW-40HT subwoofer. Thankyou for any help you can give me :-)
  • louisebrown May 19, 2009
    Thanbkyou very much for taking the time to help me :-) Much appreciated
  • Paul Hutchinson May 11, 2010
    Make and model????
  • 909 Answers
Http://www.kenwood.eu/products/home/separates/avcc/KRF-V5100D/
goto the above link and follow the steps for setup,test and use as shown on the instructions, after checking all the connections for the speakers.
I used to set up home theater kits for a living and often found that a wire or two was clipped in on the insulation rather than the wire.
Posted on May 18, 2009
My left speaker is not working and it isn't the cable connection. It has been checked and the plug is in all-the-way.
You could just have a loose wire inside the speaker but sometimes one speaker will just go to speaker heaven. Sorry I can't give a better answer and I don't know that brand so I don't know if you can open up the speaker easily to see if there is a loose connection. Now, sometimes the plugs can just wear out too which can be replaced if it is a great set of speakers but again, back to the lack of knowledge about that brand and how hard it is to work on.
May 22, 2012 | JBL Audio Players & Recorders
If you are using this inside your home with central air running do you have to vent it to an outside window?
Yes, it must be vented to the outside, even if you're using central AC, too. The reason being is if you don't vent it to the outside, the hot air and humidity that normally goes thru the duct and out the window, will stay in the house and your Central AC will have to run longer and harder to overcome this rise in heat and humidity. In addition, the room that the portable AC is in, will get extremely hot & humid.
Hope this helped you. Please let me know. Thanks.
Jun 15, 2011 | Haier CPN12XH9 Portable Air Conditioner
Only one in the pair of altec lansing speakers is working.....the other one with volume control on it is'nt working ...what should i do ??
try swapping the speakers around if the problem still persists either the speaker is faulty or
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
orbe sure to wear an anti static earth strap before touching anything inside your computer
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
don
Mar 07, 2011 | Altec Lansing Multimedia Computer Speakers
I keep blowing the right satellite speaker. Tried two other satellite speakers and also blew them. The original speaker worked for over a year until problem occured. The other two satellite speakers...
Open up your computer the speakers plug/outlet is usually at the back of the computer
or you might have to clean the dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps hope this helps
don
Mar 04, 2011 | Logitech Z-2300 Computer Speakers
Can not get speakers to work in the rear audio port of my tower..
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
you might check
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
don
Feb 23, 2011 | Cyber Acoustics CA-3080 Computer Speakers
I cant auto tune my yamaha rx v 365 reciver because i get an error saying that i dont have my speakers connected even though i know they are and working just fine.
1.Check you select the good set of speakers according to the connections you made at speakers output.
2.Have the soldering of your power output IC module remaked (by a technician only).
Spider Guy
Mar 15, 2010 | Yamaha Rx-v365 A/V Home Theater Receiver
Trying to hook up 2 Hi Fi speakers to a reciever
Red left to Red left speaker
Black left to Black left speaker
then repeat for right speaker
turn on amp play somthing quite to start, check all is working. To check speakers are in phase play a bit louder and stand exactly in middle, bass should be defined and central, it helps to close eyes and listen. If not central and defined change over Red and Black on one side only then listen again with the same test.
Start flat with eq section adjust as you like when listening to something you know and like.
After all is working ok then make it louder.
Sorted!
Sep 16, 2009 | Audio Players & Recorders
194 people viewed this question
 Grubhead
Grubhead
