This problem should be removed because:
Problem with Sharp VCRs
sharp tv, model 20rs100s, how to connect the vcr
i just got a 2nd hand sharp tv, model 20rs100s. I do not see how to connect the vcr. I connected the dvd to the front ok but i cannot get the vcr connected. I have tried both inputs on the back but only get audio??? Also the TV only goes up to channel 11 - it does not connect with the uhf channels.
Suggested Solution (2)
you need to put the antenna cable to the vcr first then connect the vcr to the tv the tv gonna be on the 3 channel, and put on the vcr the channel you wanna record
on alot of vcrs if you already have a set time for one channel to record at a later time if you dant set the earliest first it wont let you change it but im not sure if you already have one set ahead of time or not
Source: Sony SLV-798 HF VCR
Toshiba W607: Problem w/ Channel Numbers
I just bought a Toshiba W-607 VCR, and have a weird problem. I plugged it in, the VCR did its autoscan for available TV channels...
orion model vpdc connection problem
I bought an orion model vpdc recorder on the internet the advertisement did not say anything about the limitations on connections on this...
sharp vcr problem
Hi I have a older vcr, model h813u, I cant get the vcr to record off a cable box, I have put both the cable box and tv on 3, and I then put...
What channel does the vcr
What channel does the vcr need to be on to play a tape?
I want to record a
I want to record a TV program and can't figure out how to do it. I have a Fisher HVD-805 model VCR player and a Sylvania HD TV. I have...
Tips for Helping jmchapmanwar With Their Issue
- Give detailed step-by-step instructions
- A picture or video is helpful
- Use plain language not industry jargon
- Check spelling & punctuation
Add Your Solution
Hi, I have a funai vcr and I can't get any tv
Hi, I have a funai vcr and I can't get any tv channels, i just get a blue screen. The aerial works fine without the...
Mitsubushi VCR = Model HS-U530 -- Tape will...
Tape will NOT go in at all ( Will NOT take tape in autommatically as should and it Only ges in about 1/4 inch,...
how to program to record from AV
I want to to record from channel AV, my tv is set up to record thru AV only
Fix-O-Meter
61
61 people viewed this problem
- 0 people are following this problem. Be the first!
Top Sharp VCR Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
