Question about Fellowes Office Equipment & Supplies
Aluminum key stuck in teeth of shredder
This a residence. I accidentallly shredded a paper that had an aluminum key in brochure and did not know. Now it is stuck and cannot get the key out of teeth help.
  • lknerem May 17, 2009
    aluminum key stuck in teeth of shredder. Can you help
    on how to get it out?
  • 328 Answers
If you can get the top cover off by removing the 4 screws, you can manually turn the motor in reverse and pull the key out.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Posted on Jun 05, 2009
Makes grinding noise and does not pull the paper in or shred. I have pulled out all bits of paper stuck between the teeth. I'm afraid this thing is toast
This type of shredder can get clogged so badly, the material has to be removed with a utility knife. This is especially true if someone has tried to shred coated stock or, worse yet, credit cards. The noise you are hearing is the mechanism bouncing over clumps of residue jammed in-between the grinding "teeth".
Apr 18, 2015 | Royal 1200MX 12 Sheet Strip Cut Paper...
My shredder won't shred
If the motor will not run, then probably there's paper clogged in the shredder. Turn over the shredder, after unplugging the power cord, and remove the papers.
If the motor will run but not shredding any paper, then the drive gear has broken teeth. This is not usually worth fixing.
Hope this helps.
Mar 27, 2015 | Shredder Office Equipment & Supplies
Tried to clean some shredded paper in the shred area that was stuck, and now shredder won't work.
Disconnect the shredder Turn the top unit over to reveal the 'teeth' With a pair of needle-pointed pliers or cosmetic tweezers gently pick out the pieces of paper that you can see. You'll probably notice that there was some self-adhesive label material included (that seems to cause jamming more than staples!
Hope this helps.
Peter
Apr 20, 2011 | Dynex Cross-cut Shredder
How do I unclog my shredder? The papers keep getting stuck in the teeth and the shredder keeps stopping. I've tried pulling it out with my hands but it's not working. Bummer!
Have you ever "oiled" the cutting blades...all cross-cut shredders should be oiled regularly otherwise they clog up with the paper and debris generated by the cutting of the paper...the oil helps feed this material on thro into the shredding bin.
Mar 27, 2011 | Royal VF1012mx Shredder
Royal 85x paper shredder: The shredder will start to shred but stops shortly after "grabbing" the paper. In order to get it shredding again, I have to put the machine in reverse, remove the...
Sometimes spraying shredder oil on the cutting teeth wil work.
You should shred paper with a light weight machine oil poured on the paper to keep the cutting teeth working freely.
Good luck.
P.S. If this doesn't work then just take the head off and cleanj/lubricate any bearings you find.
Mar 23, 2011 | Royal 85X Shredder
There is paper stuck in the shredder. I've tried shredder oil and a tweezer.
Alternate reverse and forward several times. Graphite powder or pencil lead along the engaged gear teeth may help. There is probably a "wad of paper" underneath where you can't see it. Be brave and take the shred head apart - pay careful attention so you'll know how to put it back together.
Sep 02, 2010 | Royal 150MX Cross-Cut Shredder
My shredder won't continuously shred a piece of paper. I have to reverse it then turn it on again multiple times to shred just one piece of paper. Can I fix this?
If it is a x-cut shredder try oiling ( with a lightweight shredder oil ) onto a sheet of paper then shredding the sheet of paper to get the oil down into the cutting teeth....also try cleaning the "eyes" which are in the middle were you insert the paper..( they may be dirty.)
Nov 19, 2009 | Office Equipment & Supplies
My shredder keeps running and won't stop in on/auto mode
UNPLUG THE SHREDDER.
If this model has electronic eyes (optics) to control the auto-start/stop function and you oil the cutters, chances are the optics are contaminated with shredder oil. Take a cotton swab with a little alchohol and clean and dry the optics.
If you removed the top cover, it is a possibility that you disconnected the wires from the PC Board.
Mar 01, 2009 | Royal VF1012mx Shredder
Does the shredder have the electronic eye to sense paper? Sometimes dust will collect on the sensor causing it to keep running.
Apr 07, 2007 | Tech Solution TS-4500 Shredder
154 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
quennie732
Charles T Nevin
Charles T Nevin
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
