Question about Pioneer Audio Players & Recorders
Pioneer Receiver SX-750: Getting a loud hum through the speakers
Purchased 1976. Getting loud hum through the speakers. When the speakers are disconnected I can hear a faint hum coming from inside the receiver. Thinking it may be the transformer? but not an expert. Would like to keep the unit (after cleaning an inch of dust from internals, and fixing the hum) but if I can't fix myself for less than 50 bucks or so will probably pass it on to Goodwill. Thanks for the help.
    Problem Solver:
  • 13 Answers
I had a similar problem when my Plazma TV + DVD Player + Receiver all interconnected. Some time later, I realized that the hum was leaking from CATV connecton to my TV antenna input which was indirectly reaching to my Pioneer receiver. When I disconnected the CATV cable, the sound was perfectly clean.
I guess mains power was interfering to CATV signal somewhere.
I.Kostak from Turkey.
Posted on Mar 20, 2010
    Brigadier General:
  • 8,546 Answers
The hum you hear from the speakers and from the unit itself originate with 60hz AC power. They may not actually be related. Sometimes a transformer will hum slightly and unnoticeably. That you're getting a loud speaker hum says there is an electrical leak or a grounding issue somewhere.
Do all sources produce the hum or, say, just the phono? How about on headphones? Try rotating the AC plug. In those days they weren't keyed with one large blade as they are now.
Posted on May 17, 2009
Humming and buzzing from my speakers, no sound out of left rear speaker
Look likes a connector is ground loose or only a cable is crushed
if no other parts are connected a capacitor problem somewhere
Apr 23, 2016 | Pioneer Sx-316 Audio Multi-channel...
Pioneer elite sx-a6 keeps going to standby
I had a receiver that would shut off when I had the volume too loud. It was caused because the speakers were using too much juice. Does it work with less speakers or at low low volumes? Then this may be the case.
I solved it by getting a different receiver.
if it has nothing to do with volume then check your manual and settings for a auto standby feature that may be just putting the receiver to standby after a set time.
Apr 14, 2014 | Pioneer ELite SX-A9 HI-FI Audio Receiver...
1976 pioneer sx 1250 receiver has no sound from receiver to speakers
for
1976 pioneer sx 1250 receiverhas no sound from receiver to speakers
check the integrity of speaker systems,
check the receiver internal components, pay close attention to the
capacitors, possibly have dried up or swollen (age)
Check for continuity to the speaker outputs.
These may take some time, but I hope you will make it.
Sep 09, 2012 | Audio Players & Recorders
Pioneer sx-255r can i connect 6 - 8 ohms
Yes, you can use them but be careful. These are not necessarily robust speakers. If they sound strained, back off.
Mar 07, 2011 | Pioneer SX-255R Receiver
Pioneer receiver sx-315
With persistence, I was able to program the Universal Remote Control provided with the cable box to control my new used Pioneer SX-315 receiver. I now can control the tv volume, cable box, auxiliary stereo receiver with speaker system with one remote. Thank goodness I did not have to resort to buying a Pioneer remote control.
I was able to program another previously unused universal remote which I purchased several years ago. However, since the other remote control did not list the Vizio TV. That brand is too new for the remote.
Dec 06, 2008 | Pioneer SX-315
Pioneer SX-750 Old School Need Help
It could be a dirty control or switch, working them back and forth could prove that. Other than that, It's likely bad outputs. A unit that old may have transistors for outputs but might be IC's. Transistors can be tested with an ohm meter to see if they're good or not. Also if it has transistor outputs, they may have a small value resistor on the Emitters, check those as well.
Hope that helps...
Geno
Mar 07, 2008 | Audio Players & Recorders
Have a B&O RX-2 with mcc4 and loud hum
Possibly check the wires on the cartridge, make sure none of them are touching and are not bent to badly, are all the connections tight? some cartridges require plastic sleeves over the connections, this insure they don't touch and
avoids resistances between them. Also some cartridges are not compatible with certain model turn tables.Is it universal? Also you my need a mixer most turntables don't work with amps alone. Mine don't. Usually most models you attach the ground wire to the mixer. A mixer boosts table power and take stress off the amp. Hope this helped! good luck!
Jan 31, 2008 | Sony PS-LX350H Turntable
Pioneer SX-203
a little bit foolish thing: see if you have both the speaker channels (A and B) down. if you have both down it doesn't work - didn't for me.. and obviously make sure you have the right letter down - same outpout as your boxes
Dec 06, 2007 | Pioneer SX-205 Receiver
1,141 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
