Question about HP Designjet 110plus nr InkJet Printer
Color problems My printer seems to have a problem with a printhead because I can print a test page and all is ok, I can print a small picture, and all is ok, but when I try to print a full page (letter size) of photos, the print turns purple about 3/4 of the way through the job. I tried new cartriges, and tried using the front panel buttons to clean the heads, but it still has the problem. I don't have the maintanence utility installed on my computer, nor do I have the setup disk (our IT guy must have kept it). Any suggestions other than contacting the IT guy for the maintanence program disk?
  • architectour Oct 27, 2008
    i have the exact same problem, however, i do have the maintenance utility but it doesn't help. is there any way of calibrating the printer colours maybe ?? Or does anyone have an idea?
    Problem Solver:
  • 12 Answers
Http://h10088.www1.hp.com/cda/gap/display/main/gap_home.jsp?cp=1_4011_100&zn=gap
You can download maintanece programm from here and you need aligin printhead and calibrate color for paper do u use
Posted on Oct 01, 2008
How does one 'colour test' please.
Clean the Printhead & Print a test page by doing the ff:
1. Press the Ink button press the Up or down arrow key to select Test Print, then select Print Quality press OK and press Black or Color START. Check all the colors including the black & check if there are any missing dots and if there are any colors not printing correctly.
2. Press the Ink button on the control panel and select CLEANING press OK.
3. Press the up or down arrow key to select Color press ok and press Black Start.
*After the cleaning process the printer will ask you if the quality is OK, press up or down to select yes or no, and it will ask you whether black or color is ok, once you have selected you're answer press Black or Color START to print another test page. Compare the 1st and 2nd test page if it's improving, you may need to do this 3-5 times or until you get a better quality
Hope this helps Please rate if it worked Thanks!
Apr 03, 2011 | Brother MFC 490cw Color Inkjet...
The documents are faded even after putting in a new cartridge
  • make sure you are using inkjet papers as inkjet printers work on inkjet papers.
  • Lift the printer access door, then remove the ink cartridges from the printhead.
  • Insert the ink cartridges into the printhead, then press down firmly until you hear them click into position.
  • Close the printer access door.
  • Reprint the picture or document that had the quality problem.
  • if still light prints then proceed further
  • Print Test Page
  • Review the printed test page and verify that:
    • the left color blocks are gray, cyan, and black.
    • the right color blocks are magenta, yellow, and black.
    • each block is completely filled with color.
  • If no---> Clean Printhead, the On/Off light flashes during the cleaning procedure.When the On/Off light glows steady, print test page again.
  • If Yes---->The problem could be caused by the type of paper you are using.
May 28, 2010 | Kodak Office Equipment & Supplies
Lines on print. There's are three lines on picture print only. Can't see the line on document. It's about 1/4 inch wide and going throught top to bottom.
Have ou gone into your menus. Into troubleshooting, then image quality.
You will want to run both the eliminate light stripes and eliminate smears procedures. that will purge the print head, blow air through the jets and hopefully resolve the problem. I do believe the 8550 has a Jet Substitutin procedure where you can do a workaround and make other jets make up for the light areas.
here are some directions, Will forward more
  1. Press the [Up] or [Down] arrow button on the Control Panel to select [Troubleshooting] on the Display Screen, and then press the [OK] button.
  2. Press the [Up] or [Down] arrow button to select [Print Quality Problems], and then press the [OK] button.
  3. Press the [Up] or [Down] arrow button to select [Troubleshooting Print Quality Page], and then press the [OK] button.
  4. Evaluate the 'Light Stripes Test' page for missing printhead jets, such as missing Cyan, Magenta, Yellow or Black color bars. The 'Light Stripes Test' page is the last page of the Troubleshooting Print Quality Page that printed.
    WARNING: To avoid injury, do not touch the sharp metal strip attached to the clear rubber wiper blade in the Maintenance Kit.
  5. Use a clean lint-free cloth or a new paper coffee filter to gently clean the maintenance unit's clear rubber wiper blade, use only a wiping motion across the entire length of the wiper blade, and then empty the waste tray. A dirty maintenance kit wiper blade can cause white lines and weak or missing printhead jets.
  7. Repeat step 3 to reprint the Troubleshooting Print Quality Pages. If there are no missing or partially missing color bars then the print quality problem has been resolved. If there are missing or partially missing color bars then the printhead cleaning procedure will need to be performed. Continue with the next section.
To clean the printhead using the basic eliminate light stripes procedure:
  3. Press the [Up] or [Down] arrow button to select [Eliminate Light Stripes], and then press the [OK] button.
  4. Press the [Up] or [Down] arrow button to select [Basic], and then press the [OK] button. The printer will perform a head cleaning, which will take about five minutes. The printer will then print a cleaning page and a light stripes test page.
  5. Repeat steps 1 - 4 one more time. If there are no weak or missing jets then the print quality problem has been resolved. If there are still weak or missing jets after two basic light stripe cleanings, continue with step 6.
    NOTE: Do not try the Advanced Eliminate Light Stripes Cleaning mode without performing two basic cleanings first.
    To clean the printhead using the advanced eliminate light stripes procedure:
  6. Press the [Up] or [Down] arrow button to select [Advanced], and then press the [OK] button.
  7. Select the missing jet color and number. If necessary, check the light stripes test page to determine the color and jet number of the missing jet.
    NOTE: Only perform the advanced light stripe cleaning once. If weak or missing jets still persist, continue with step 8.
  8. Print the Troubleshooting Print Quality Page. Evaluate the Light Stripes Test page for missing printhead jets, such as missing Cyan, Magenta, Yellow or Black color bars. If necessary, perform the basic eliminate light stripes procedure one more time. If the Advanced Eliminate Light Stripes procedure does not resolve the weak or missing jets, perform the Enable Jet Substitution Mode. See the Related Items below.
Feb 05, 2010 | Xerox Phaser 8550DP Printer
I gave my dauther a kodak 5500 printer for christmas, it prints the test sheet ok but then does not print anyother pages. it has new ink both black and colored. thank you in advance for your help kelly c
This can be the issue with printhead if you are printing documents (black color can be missing from the print)
Try to print a picture from the computer, if it works then the issue is with black color (printhead needs replacement)
If nothing prints from computer then call kodak tech support (drivers will be re-istalled, delete the printer icon from Conntrol Panel > Printer and Faxes > Restart the computer > Connect the printer USB cable again.
Jan 26, 2010 | Kodak EASYSHARE 5500 All-In-One InkJet...
On my Test Pattern 2 the blue/light blue and green/yeallow have steeks in it. The documents that I print have streaks going across the page. I've cleaned everythign I can clean. The printer has 6,251...
SolutionFollow the given steps in the order presented to resolve the issue: Step one: Retry the print jobThe problem may occur only rarely. If you have not seen it in other printouts, try again. Step two: Increase the print quality modeIf reprinting did not help, try increasing the print quality mode.
  1. In the application you are printing from, click File , and then click Print .
  2. Make sure the printer is selected, and then click Properties .
  3. Select the Paper/Quality tab.
  4. In the Print Quality area, choose the next higher quality setting. If the current setting is Draft, choose Normal. If the current setting is Normal, choose Best.
Step three: Print in grayscale (black area streaking only) If the streaks are in a black area of a black and white printout, change to grayscale printing.
NOTE: This step does not apply to color printouts.
  2. Make sure the printer is selected and click Properties .
  3. Click the Color tab, and select Print Grayscale and High Quality .
Step four: Clean the printheadsIf the print quality is still bad, clean the printheads.
  1. Make sure the printer is loaded with unused white paper.
  2. Open HP Solution Center .
  3. Click Settings , Print Settings , and then select Printer Toolbox .
  4. Click the Service Tab .
  5. Click Clean Printhead , and then click Clean .
Step five: Align the printheads If the print quality is still bad, align the printheads.
  2. Open the printer Toolbox , and select the Printer Services tab.
  3. Click Align Printheads . The Align Printheads window opens. Click Align .
  4. The printer prints an alignment page. The lines in the patterns should appear to be straight. Click OK when the page finishes printing.
Step six: Calibrate the linefeed If the print quality is still bad, calibrate the linefeed:
  2. Open the printer Toolbox and select the Printer Services tab.
  3. Click Calibrate Advanced Linefeed . The Advanced Linefeed Calibration window opens. Click OK .
Step seven: Replace one or both printheads If the print quality is still bad after performing all the above steps, one or both of the printheads will have to be replaced. Print a PQ Diagnostic page to see which printhead should be replaced.
  2. Press the Setup button.
  3. Press 1 and * simultaneously.
  4. Look at the color blocks labeled Test Pattern 2. Some or all of them could show white horizontal streaks. If none of the blocks are streaked, the printheads are okay.
    • If the Black block has lines – replace the KY printhead.
    • If the Cyan block has lines – replace the MC printhead.
    • If the Magenta block has lines – replace the MC printhead.
    • If the Red block has lines – replace the KY printhead.
    • If the Green block has lines – replace the KY printhead.
Dec 21, 2009 | HP OfficeJet Pro L7580 InkJet Printer
It is printing the wrong colors. My reds are
Step one: Check the ink cartridges HP doesn't guarantee the quality or reliability of non-HP ink. If the ink cartridges have been refilled, try replacing them with genuine HP ink cartridges.If you have checked the ink cartridges and are still experiencing a problem, proceed to Step two. Step two: Print a test page
  1. Verify that there is plain white paper in the input tray.
  2. Press the OK and Help buttons simultaneously. A two-page Extended Self Test Diagnostic Page prints. Figure 1: Extended Self Test Diagnostic Pagec00728269.gif
  3. In the Print Quality Pattern section on the second page of the test page, look at the color blocks for any lines. Figure 2: Print Quality Patternc00728270.gif
  4. If the colors are still wrong in the Print Quality Pattern color blocks, print a document to determine if the issue has been resolved.
If you have completed all of the steps above and are still experiencing a problem, proceed to Step three. Step three: Check the printer settings
  1. In the software application you are trying to print from, click File and then clickPrint . The Print dialog box opens.
  2. Verify that your printer is selected and then click Preferences . The Printing Preferences dialog box opens.
  3. Click the Printing Shortcuts tab.
  4. The Printing Shortcuts tab lists most printing needs, but you might need to modify some of the options. Options on the Printing Shortcuts tab include:
    • General Everyday Printing
    • Photo Printing Borderless
    • Photo Printing with white borders
    • Two Sided (Duplex) Printing
    • Presentation Printing
    • Fast/Economical Printing
    • Postcard Printing
    • Hagaki Printing
    NOTE: These are general printing shortcuts with pre-selected settings.
  5. To change the settings from those available on the Printing Shortcuts tab, click the Features or Color tab. Options on the Features or Color tab include:
    • Print quality : If you are unhappy with the quality of your printouts, try increasing the print quality. To print more quickly, try decreasing the print quality.
    • Paper type : If one of the options matches your paper type exactly, choose it rather than Automatic.
    • Paper size : Make sure this matches your paper.
    • Print in Grayscale : Print a document in shades of gray.
    • Orientation : Specify how the document is positioned on the page.
    • Paper Source : Select the tray that you want to use for printing.
    • Two sided printing : Print on both sides of the paper.
    • Color Management : Specify the color space that the printer will use to interpret image data.
    • Pages per Sheet : Specify the number of pages in the document that will be printed on each sheet.
If you have completed all of the steps above and are still experiencing a problem, proceed to Step four.
Nov 07, 2009 | HP Photosmart C6280 Printer
Not printing in color but color cartridges are going empty
I suggest you first verify activate a CLEAN PRINTHEAD routine from the TOOLS/MAINTENANCE menu to see if you can blow ink thru the PRINTHEAD nozzle plate. You many need to place a damp cloth under the printhead to help 'wet' the nozzle plate in an effort to remove residual black ink buildup...you can find some youtube videos on how to do this. For additional HP02 support information, please visit our HP02 system support page which includes videos of everything mentioned below: http://inkjet411.com/?page_id=1372
To bypass INK SYSTEM FAILURE message please see the HP Printer Diagnostics Tests file (pdf) for instructions: http://inkjet411.com/?page_id=1813
Verify the permanent built-in PRINTHEADs electrical performance inside this legacy printer model by running the TAP 43 diagnostic test (either one of the procedures below applies to all printers which use HP02 or HP363 ink cartridges): For additional HP02 support information, please visit our HP02 system support page which includes videos of everything mentioned below: http://inkjet411.com/?page_id=1372
A. HP02 ink-series printers with KEYPAD (i.e. keypad numbers 1-9)
Tap 43 PRINTHEAD Health Diagnostics:
Video Procedure: http://inkjet411.com/?page_id=2391
1. Press * and # keys simultaneously.
2. "Enter Special Key Combo" will be displayed.
3. Press 123 to display the 'Support/Service' menu.
4. At 'Support/Service' menu, click the Right Arrow 3 times until Special Reports menu is displayed.
5. Select Ok, then click Right Arrow 2 times until the 'print-mech button tap' menu is displayed.
6. Select Ok ('code = 0' will be displayed); click and hold Right Arrow until 'code = 43' is displayed. Use the Left Arrow if you need to decrease numerical count.
7. Select Ok. The test page prints.
8. Check the 4th line at the top of the printed report; an electrically good/stable PRINTHEAD 'Pen Status' will state "Pen Status: Pen OK".........if any other message is displayed then the PRINTHEAD may have failed and may need to be replaced (if part is still available). It is suggested to perform the 'Printer Reset' procedure below to first rule out printer firmware related problem.
B. HP02 ink-series printer models that DO NOT HAVE a KEYPAD:
Internal Test Print:
1. Press the Menu button, press the Right Arrow button to select 'Tools', and then press 'OK'.
2. Press the Right Arrow button several times to select 'Print Test Page', and then press 'OK'. The test page prints.
Tap 43 PRINTHEAD Health Diagnostics - See Video Procedure: http://inkjet411.com/?page_id=2377
1. Turn ON the printer.
2. Press and Hold the "Print Photos" & "Red Eye Removal" buttons.
3. Release both buttons.
4. You will see a new screen that says, "Enter Special Key Combo"... The Key combo is: press and release in sequence the "Red Eye Removal", "Print Photos", and then "Red Eye Removal"
5. Scroll through the menu by pressing the right arrow button until the display says 'Special Reports'.
6. Select Ok, then press the arrow button until the 'print-mech button tap' menu is displayed.
7. Select Ok ('code = 0' will be displayed); click and hold Right Arrow until 'code = 43' is displayed.
8. Select Ok. The test page prints.
9. Check the 4th line at the top of the printed report; an electrically good/stable PRINTHEAD 'Pen Status' will state "Pen Status: Pen OK".........if any other message is displayed then the PRINTHEAD may have failed (unfortunately the PRINTHEAD is not replaceable). It is suggested to perform the 'Printer Reset' procedure below to first rule out printer firmware related problem.
For additional and advanced HP printer diagnostics, please visit: http://inkjet411.com/?page_id=1813
To help solve other HP02 ink-series printer/printing related issues please visit http://www.inkjet411.com
Jul 10, 2009 | HP Photosmart C5180 All-In-One InkJet...
Printer won't print in black ink.
Plunger needs to be cleaned, print head also would need to be looked at on this one.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 21, 2009 | HP Photosmart D7160 InkJet Printer
Pages printing blank
Resolving white, light lines or streaks (eliminate light stripes)
From the printer, print the Troubleshooting Print Quality Pages.
With Troubleshooting highlighted, press the OK button.
Scroll to Print Quality Problems by pressing the Up or Down Arrow button. Press OK.
Scroll to Troubleshooting Print Quality Page. Press OK.
Evaluate the Light Stripes Test page for missing printhead jets (missing cyan, magenta, yellow or black color bars).
Clean the maintenance unit's wiper blade and empty the waste tray. A dirty maintenance drawer wiper blade can cause white lines and weak or missing printhead jets. Using a clean lint-free cloth or a paper coffee filter, gently clean the blade with a wiping motion across the entire length of the wiper blade.
Dec 20, 2008 | Xerox Phaser 8400 Laser Printer
Problems with Color printing
Click Start - All programs - HP - HP Solution center.
Click Settings - Print settings - Printer settings
Click on the Features tab. Set the print quality to best. Click on the Colors tab. Under color management - Enable the option Managed by Application. Click OK . close solution center. Try to print.
Dec 22, 2007 | HP Photosmart C3180 All-In-One InkJet...
HP Designjet 110plus nr InkJet Printer Logo
428 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
