Question about Samsung Refrigerators
Hi there! I have a Samsung side by side refridgerator.It has gone on the blink. It tripped the switch on the electric box. Have changed the fuse,have checked the sockets. Everytime i try to plugg it back on it trips the circuit again. HELP!
Seized or overheated compressor or def.circuit breaker?
Posted on May 17, 2009
Samsung dryer will not run
check for power at the outlet and the terminal block then see if the belt tensioner switch has gone bad? located at bottom of motor under the tensioner
Jul 11, 2014 | Samsung DV350AEP Electric Dryers
The refridgerator in my 1994 eldorado motorhome wont work when I am plugged into power does it possibly have a bad fuse?
check the fuse panel/circuit breaker box, i am not an expert with gas/electric refrigerators but i have had experience with the electrical part not working and it was a tripped breaker.
Oct 12, 2012 | Cars & Trucks
When you turn on the drier it trips the electricty. there is power in to the power switch but when you turn the dial it trips the fuse box. the model is TC7103W
an electrical earth leakage will cause the trip. possibly the the heating element. but the motor or wiring fault can do it. you could try disconnecting the heater if the electric stays on. then change the element.
Jul 22, 2010 | Zanussi Dryers
Hi there, we have a Saniflo system for a basement bathroom installed. The system stopped working so we checked the fuse box and it had tripped. We switched it back on and it worked fine for an hour. We had...
The saniflo system uses 2 stages stage one works sorta like a garbage disposal it breakes up waste, stage two is a high flo pump. one fo these has gone bad meaning the motor has burned up and shorted the sparking in the breaker pannel you refered to. As far as I know theese systems are self contained so you will have to have the unit repaced here is a link to the website so you can find a dealer or installer near you
http://www.saniflo.com/Default.aspx
Hope this helps.
Please leave feedback.
Dec 06, 2009 | Kitchen Appliances - Others
Red light keeps blinking. How to stop it?
Hi
It maybe one of the fuse gone.
You have to change the fuse:
The fuse is 250mAh and 3/4" inch long (20 mm) round glass with metal ends. The electrical contacts are not in the cartridge but inside the printer: There is a plastic fuse holder on the cartridge, even the starter cartridge. You just simply pop it into the holder. This will stop the flashing red LED and the system tray will say the cartridge is full.
All The Best: Pineworks
Aug 08, 2009 | Samsung ML-2510 Laser Printer
Change the waterfilter
Hi, I looked up your model and it shows a filter. It appears to be inside a small box. I have never seen one like this. Is there any kind of box inside the refrigerator or underneath?
Let me know if this helps.
Vic
May 10, 2009 | Samsung RS2630SH Side by Side Refrigerator
Recently wired a double oven with isolator switch
Hi, there's definitely a electrical problem.
First, use the bottom oven only for about 15 minutes and check if it doesn't trip.
Second, use just the grill (top oven) for about 15 minutes and check if it doesn't trip.
The reason is sometimes grill elements are corroded and only trip after a few minutes.
Also, if both ovens work ok on their own, then it could be your fuse box not strong enough, or the isolator switch fuse be only 13amp. If your oven is more than 3Kw (check the label on the door for info) then you need a 30amp fuse to hold when both ovens are on.
Cheers
Feb 19, 2009 | Zanussi ZDF490 Electric Double Oven
Dryer trips the fuse box
Hi.
Try running it with the heater disconnected. if it goes o/k then your heater needs replacing
Nov 22, 2008 | Zanussi TC180W Electric Portable Dryer
Electrics not working
sounds like the board on the b ack where the main cable goes in,this happend to mine,very cheap to fix
Nov 03, 2007 | DeLonghi DEFSGG36-SS Gas Kitchen Range
Refrigerators Logo
410 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
