Question about Texas Instruments TI-84 Plus Calculator
Functions not in pi
How  can i get  the Trigonometricas  functions  ( not in mradianes  )
Example  sin(30 ) = 1
The only way I can think of having sin(30) = 1 would be to press [MODE], set the mode to Radians and set decimal places from 'FLOAT' to '0'.
Posted on Oct 27, 2007
Polar rectangular
There is nothing to convert, because if T is a real number so is 40sin(4000T).
40sin(4000T)=40abs(sin(4000T))*sign(sin(4000T))
where abs() is the absolute value of it argument, and sign(sin(4000T)) is positive or negative.
So in (radius, angle) polar coordinates
r= 40 abs(sin(4000T)),
theta =(0, or PI), depending on sign(sin(4000T))
If you are trying to graph parametric functions, this calculator does not do graphs, and you need another function of T
Dec 26, 2013 | Casio FX991ES Scientific Calculator
Sinus function in graph mode is wrong.
What make and model calculator? Can you give us the exact keystrokes you're using?
Apr 18, 2013 | Office Equipment & Supplies
Find the trig function given its period cos 5 pi
cos(5PI)=cos(4PI+PI)=cos(PI)=-1
sin(19PI/6)=sin(18PI/6+ PI/6)=sin(3PI +Pi/6)=sin(2PI+PI+PI/6)=sin(PI+PI/6)=sin(-PI/6)=-sin(PI/6)=-1/2
Dec 12, 2011 | Super Tutor Trigonometry (ESDTRIG) for PC
How to draw a trig function (y=sin(theta)) on a Casio 9750 gii
The variable theta is reserved for polar plots. So if you want to graph functions of the form y= expression, you must use the default variable x. Thus draw y=sin(X). Make sure your calculator is configured with the correct angle unit (degree or radian).
If you use degrees the window dimensions for x must cover an interval of 360 degrees, to have a full period. If angle unit is radian, then choose an x-interval between [-pi and pi] or between [0 and 2pi]
Sep 18, 2011 | Casio FX-9750GPlus Calculator
How to use calculator on how to evaluate trigonometric functions
The FX-115ES is somewhat different to other calculators you might know. The sequence of keys is more like writing up a calculation in a textbook, whereas for "normal" calculators operations are reversed in some places.
For example, with most calculators you would type 30 [sin] to calculate the sine function of 30 degrees, with the 115ES its [sin] 30 [=].
The 115ES has all the standard trigonometric functions:
  • Standard functions (sin, cos, tan), type the [sin], [cos] or [tan] key followed by the argument.
  • Inverse trigonometric (sin?¹, cos?¹, tan?¹), type [SHIFT][sin], [SHIFT][cos] or [SHIFT][tan] followed by the argument.
  • Hyperbolic functions (sinh, cosh, tanh), type [HYP][sin], [HYP][cos], or [HYP][tan] followed by the argument.
  • and finally inverse hyperbolic (sinh?¹, cosh?¹, tanh?¹), its [SHIFT][HYP][sin], [SHIFT][HYP][cos], or [SHIFT][HYP][tan] followed by the argument.
Arguments can be given as numbers with mantissa (2.718), as fractions (use the fraction key below [CALC]) or as degree, minute, second (30°12'45") using the [°'"] key for input. To switch between degrees (1 circle = 360°), radians (1 circle = 2?), or grad (1 circle = 400 gon), use [SHIFT][DRG>].
Jan 06, 2011 | Casio FX-115ES Scientific Calculator
I get ERR:DOMAIN every time I enter an inverse trig function
Is your Ti83 plus in degree mode. You can change to radians by pressing the MODE key, and sliding down 2 more positions, and press the ENTER key. Because you got this error your principle value for x and y should be examined. Generally you really should be in radian mode when working with arcsin (aka. sin^-1), and arccos. You probably weren't using arctan because, you would have never gotten this error message due to the fact it goes on forever. And this way your answers for y= arcsin(x), or arccos(x) will be on the x axis, and domains at 0, pi/2, and pi.
You can work in degree mode but, if the number you place in the brackets of your arc sin or arc cos function is larger than 1 or smaller than -1 you will get a ERR:DOMAIN. Using the arctan or (aka. inverse tan) function in the degree mode can be used for computing endless waves, or as an angles that are usually in brackets of cosine or sine. Example: cos(arctan(Beta). This functions that y to never be greater than 1 or, less than 0. Example: sin(arctan(angle). This functions that y to never be less than -1 or, greater than 1.
I hope this answers your question to why you got this error and, helps you to decide on what the correct mode setting should be.
Dec 17, 2010 | Texas Instruments TI-83 Plus Calculator
How do you use the sin-1
You would press on the SIN key, "sin(" should come on the display, then enter the value, for example 3.5 or -1 so that the display shows
sin(3,5) or sin(-1) for example.
remember to close the sin with the ) on the end.
sin(-1) = -0.841470985
Feb 16, 2010 | Texas Instruments TI-30XA Calculator
I am getting the wrong answers with the tan -1 function
That habit of TI, Casio, and Sharp to label the inverse trigonometric functions with the -1 superscript can cause confusions.
  1. The inverse trigonometric functions arcosine, arcsine, and arctangent (labeled by manufacturers as cos^-1, sin^-1, and tan^-1) should not be confused with the other trigonometric functions known as secant(x) =1/cos(x), cosecant(x)=1/sin(x) and cotangent(x) = 1/tan(x).
  2. To avoid errors in the use of the inverse trigonometric functions, one must be careful and set the angle unit to the one required by the problem at hand (degrees, or radians)
  3. To make the trigonometric functions really functions, their range is restricted.
  4. In this calculator arcosine (x) gives results between 0 and 180 degrees (if angle MODE is Degree) or between 0 and Pi radians (if angle MODE is Radian).
  5. The range of results for arcsine(x) and arctangent(x) is between -90 degrees and +90 degrees (if angle MODE Degree) or -Pi/2 and Pi/2 (if angle MODE is Radian)
With this information you should be able to set the angle unit correctly ([MODE][Radian] or [MODE][Degree] ) and interpret the results. If you want to extend the angle to other values, use the periodicity of the trigonometric functions.
Hope it helps
Nov 06, 2009 | Texas Instruments TI-83 Plus Calculator
TI-84 Plus silver edition sin/cos/tan
for function = (sin,cos,tan,sec,cosec,cotan)
arc(function) = function^-1, calculated in the first quadrant for simplicity(0-pi/2) (0-90deg), as all functions repeat circularly
just another method of notation
http://www.mathwords.com/t/tangent_inverse.htm
Jun 19, 2008 | Texas Instruments TI-84 Plus Silver...
Trig functions of the TI-30XA
if the sides of a triangle are 15cm ,16cm, and 17 cm ,then the area of the triangle is what ?
May 09, 2008 | Texas Instruments TI-30XA Calculator
Texas Instruments TI-84 Plus Calculator Logo
129 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
