File "sscvihost.exe" not exist, after starting my pc
Showing the above said file is not there. and another problem is when i want to open task manager, it is giving your task manager is disabled my your administrator
  • 909 Answers
Try downloading the file via windows update or even googleing the file name to see if you can get it somewhere for free, I had a missing "dll" and found it for free somewhere.
I hope this helps.
Posted on May 17, 2009
I have a computer [AMD athlon(tm)]xp 1800+ 1.50 GHz]. My problem is when I switch on the system,the OS will open and i don't open any application then if i see in 'Task Manager - performance' there the...
Type "msconfig" on search bar there will be bar "startup apps" click that and click on disable all and restart your system...hope it works... Regards: imran
Sep 19, 2014 | Computers & Internet
Tip
Delete An "undeletable" File!
<p><b><u><span>Delete An "undeletable" File</SPAN></U></B><br> <p><b><span> </SPAN></B><br> <p><span>Open a Command Prompt window and leave it open.</SPAN><br> <p><span>Close all open programs.</SPAN><br> <p><span>Click Start, Run and enter TASKMGR.EXE</SPAN><br> <p><span>Go to the Processes tab and End Process on Explorer.exe.</SPAN><br> <p><span>Leave Task Manager open.</SPAN><br> <p><span>Go back to the Command Prompt window and change to the directory the AVI (or other undeletable file) is located in.</SPAN><br> <p><span>At the command prompt type DEL &lt;filename&gt; where &lt;filename&gt; is the file you wish to delete.</SPAN><br> <p><span>Go back to Task Manager, click File, New Task and enter EXPLORER.EXE to restart the GUI shell.</SPAN><br> <p><span>Close Task Manager.</SPAN><br> <p><span>Or you can try this</SPAN><br> <p><span>Open Notepad.exe</SPAN><br> <p><span>Click File&gt;Save As..&gt;</SPAN><br> <p><span>locate the folder where ur undeletable file is</SPAN><br> <p><span>Choose 'All files' from the file type box</SPAN><br> <p><span>click once on the file u wanna delete so its name appears in the 'filename' box</SPAN><br> <p><span>put a " at the start and end of the filename</SPAN><br> <p><span>(the filename should have the extension of the undeletable file so it will overwrite it)</SPAN><br> <p><span>click save,</SPAN><br> <p><span>It should ask u to overwrite the existing file, choose yes and u can delete it as normal</SPAN><br> <p><span>Here's a manual way of doing it. I'll take this off once you put into your first post zain.</SPAN><br> <p><span>1. Start</SPAN><br> <p><span>2. Run</SPAN><br> <p><span>3. Type: command</SPAN><br> <p><span>4. To move into a directory type: cd c:\*** (The stars stand for your folder)</SPAN><br> <p><span>5. If you cannot access the folder because it has spaces for example Program Files or Kazaa Lite folder you have to do the following. instead of typing in the full folder name only take the first 6 letters then put a ~ and then 1 without spaces. Example: cd c:\progra~1\kazaal~1</SPAN><br> <p><span>6. Once your in the folder the non-deletable file it in type in dir - a list will come up with everything inside.</SPAN><br> <p><SPAN style="FONT-FAMILY: 'Tahoma','sans-serif'; FONT-SIZE: 10pt
on Dec 10, 2010 | Computers & Internet
Tip
Delete An undeletable File
At the command prompt type DEL <filename> where <filename> is the file you wish to delete.
Close Task Manager.
Or you can try this
Open Notepad.exe
Click File>Save As..>
click save,
1. Start
2. Run
3. Type: command
4. To move into a directory type: cd c:*** (The stars stand for your folder)
5. If you cannot access the folder because it has spaces for example Program Files or Kazaa Lite folder you have to do the following. instead of typing in the full folder name only take the first 6 letters then put a ~ and then 1 without spaces. Example: cd c:progra~1kazaal~1
7. Now to delete the file type in del ***.bmp, txt, jpg, avi, etc... And if the file name has spaces you would use the special 1st 6 letters followed by a ~ and a 1 rule. Example: if your file name was bad file.bmp you would type once in the specific folder thorugh command, del badfil~1.bmp and your file should be gone. Make sure to type in the correct extension.
on Oct 09, 2010 | Computers & Internet
Stop c0000135
Probably a deleted or corupted file from a malware removal..
run SFC (System File Checker)
run System File Checker sfc /scannow... For more information on this tool see How To Use Sfc.exe To Repair System Files
NOTE for Vista/WIN 7 users..The command needs to be run from an Elevated Command Prompt.Click Start, typecmd into the Start/Search box,
right-click cmd.exe in the list above and select 'Run as Administrator'
You will need your operating system CD handy.
Open Windows Task Manager....by pressing CTRL+SHIFT+ESC
Then click File.. then New Task(Run)
In the box that opens type sfc /scannow ......There is a space between c and /
Click OK
Let it run and insert the CD when asked.
Dec 09, 2013 | Computers & Internet
Blank screen
A white blank screen? That sounds like the virus changed your display settings. Click Ctrl+Alt+Del to get to the task manager. Press and hold the Ctrl key plus the Alt Key then hit the Del key. When the task manager opens up Click File at the upper left corner of the window then select New Task RUN. When the create New Task Window opens type: explorer.exe and hit OK. See if it starts populating your desktop icons and shows the start menu and task bar. If so, the virus changed your settings.
To change your display background click Start/Control Panel and look for Display or Appearance and Personalization. When it opens select the Desktop tab and change the desktop background. Hopefully the white will go away.
You may have to get into Safe Mode to do the above if the virus disabled the Task Manager.
Apr 09, 2012 | Computers & Internet
Tip
Desktop Short Cut Missing
Hello,Some times your Desktop shortcuts or Start Menu Disappeared.It is happening due to Error Occurred in Explorer.exe. You can Clear this Error without Formatting.Just Do Following..
  1. Copy "explorer.exe" from other clean computer (from C:WINDOWS)
  2. And Paste it In your computer go to C:WINDOWS
  3. Show hidden files from (Tools - Folder Options - View - Show hidden files and folders)
  4. Delete existing 'explorer.exe' and any other files start with explorer...
  5. Put the new file (explorer.exe)
  6. Log off / Restart
  7. Log on
OR Just try this Solution.Close all your Opened Windows/Programs(OR Restart PC). Just Run this Dos File.It will Restore your Desktop Surely.. I/we need your valuable Feedback...Keep Using FixYa
Check this Link............. "Unable to Open Theme Corrupted" in Nokia 6300 Click here
on Apr 11, 2010 | Computers & Internet
Tip
Delete an undeletable file...
Delete an "undeletable" File.
Close Task Manager.
Or you can try this:
Open Notepad.exe
Click File>Save As..> locate the folder where your undeletable file is Choose 'All files' from the type box
Click once on the file you wanna delete so it's name appears in the 'filename' box.
put a "at the start and end of the filename (the filename should have the extension of the undeletable file to is will overwrite it)
click save,
It should as you to overwrite the existing file, choose yes and you can delete it as normal.
1. Start
2. Run
3. Type: command
on Feb 11, 2010 | Computers & Internet
My pc shows end program-explorer.exe
First thing you need to scan your hard drive for a possible virus infection.
If the anti-virus cannot find and fix the problem, the explorer.exe file is damaged/corrupted and you need to have it replaced by reinstalling Windows.
Regards,
Katharsys
Mar 30, 2011 | Computers & Internet
Tip
Delete an undeletable File
Open a command Prompt window and leave it open.
close all open programs.
click Start, Run and enter TASKMGR. EXE
Go to the Processes tab and End Process on Explorer. exe.
Go back to the command Prompt window and change to the
directory the AVI ( or other undeletable file) is located
in.
Go back to Task Manager. click File, New Task and enter
close Task Manager.
or you can try this
Open NOtepad.exe
click File>Save as..>
choose "All files" from the file type box
in the "filename" box
pur a " at the start and end of the filename
click save,
1. Start
2. Run
3. Type: command
5. If you cannot access the folder because it has to do the following. instead of typing in the full folder name only take the first 6 letters then put a ~ and then 1 without spaces.
7. Now to delete the file type in del ***.bmp, txt,jpg,avi,etc... And if the file name has spaces ypu would use the specific folder throgh command, del badfil~1.bmp and your file should be gone. Make sure the type in the correct extension.
on Jan 31, 2010 | Computers & Internet
Tip
Close Task Manager.
Or you can try this
Open Notepad.exe
click save,
1. Start
2. Run
3. Type: command
on Dec 02, 2009 | Computers & Internet
Computers & Internet Logo
113 people viewed this question
David Payne
David Payne
