Question about Dell Latitude C600 Pentium III 750MHz, 10GB, 128MB, 14.1 TFT, 56K Modem, 24X CD (C600750128) PC Notebook
Modular bay cannot be indentified - Dell Latitude C600 Pentium III 750MHz, 10GB, 128MB, 14.1 TFT, 56K Modem, 24X CD (C600750128) PC Notebook
Hampton Bay fan Model 524HR4T Remote will not work Tried to replace the reciever and is a modular type which plugs into the fan. Any help on this greatly appreciated.
That's a store brand fan for Home Depot. Hampton Bay fans are made by several different manufactures, so good luck.
Oct 03, 2015 | Hampton Bay Dryers
Hi my dell d610 does not recognise any dvd rom i
insert a good quality dvd in the drive. If no response, go to my computer and select dvd drive and double click, it may open. GL
Aug 19, 2013 | Dell Latitude D610 Notebook
Hi, my problem on dell inspiron 1526 is this: SYSTEM MODULAR BAY cannot be indentified.... problem is that CD/dvd drive show signs of work(when i turn my computer on Green led blinks,motor starts to rotate...
If the drive functions in another system the the issue is either the motherboard contacts or the controller. Flash the BIOS to the most current version and reset the BIOS defaults. If the drive still doesn't detect, then a motherboard replacement is likely in order.
Nov 15, 2009 | Dell Inspiron 1526 Laptop
When I turn on the laptop ...it says the dvice in the system modular bay can not be identified
Did you ever solve the non-recognition problem?
My C840 fails to recognize the/an extra HD in the modular bay, after I "overfilled(??)" it.
What to do to regain access to information stored on HD that the computer no longer recognizes? (Other components, including other HD's continue to work ok in the modular bay).
kcdd30a@aol.com
Nov 07, 2009 | Dell Inspiron 8200 Latitude C840 Laptop...
I need a power supply compatible with Cooler Master CAC-T05-UW. Features are ATX Mid Tower, ATX, Micro ATX compatible form factor, 2 External 5.25'' drive bays, 2 External 3.5'' drive bay, 2 Internal...
The Cooler Master RS-600-AMBA-D3 600W ATX12V V2.3 SLI Certified Crossfire ready 80 PLUS certified modular active PFC.
Cooler Master eXtreme power RS550-PCARE3-US 550W ATX12V V2.3 SLI ready CrossFire ready power supply.
Two models that should fit with that tower. Cheers!
Aug 19, 2009 | Computers & Internet
Either issue with system modular bay or system file removed
remove any cd or floppy disks from the pc...reboot ..if the black screen reaper with the same message about the missing file ..you have to insert the windows instalation cd ...and repair..the missing file
Jan 28, 2009 | Dell Inspiron 2200 Notebook
I need solution
Ok, this is a misworded error message on dells end. this laptop does not have a modular bay instead it has a locked in disc drive. Based on what i have seen on other dell laptops i would have to say the cd drive is going bad. To test this try removing the cd drive. Power the laptop on and push the eject button then power the laptop off. Flip the laptop overand there will be a screw to hold the drive in, this screw will be close to the center and will be the only screw in a square hole, remove this screw. Now if you followed my directions, you should have the drive out. Pull the tray out as far as it will go then grab the two sides closest to the laptop and gently pull it out. If you are having problems you can stick a flat screw driver in the square hole and push the piece of metel to the side to remove.
Now power the laptop on it may say something about there not being a cd drive(optical drive) if it does not say: "the device in the system modular bay cannot be identified" then you need to replace to CD drive.
Dec 04, 2008 | Dell Inspiron 2200 Notebook
It won't boot to the os
The modular bay refers to the optical drive (CD drive). There is a small screw holding it, I've had machines at my shop that this screw fallen out and the drive wasn't making a good connection. Be sure that the drive hasn't slid out a bit. Take it out clean the connection and put it back, making sure it's seated properly. Try this, then let me know, and we'll go from there.
Jul 29, 2008 | Dell Latitude D600 Notebook
Bought second hand c640
Power off even it it takes a battery removal. Now check modular bays and remove then fully insert each device and retry power up. If same results, try repeating above with one of the modular devices removed.
Sep 09, 2007 | Dell Latitude C640 Notebook
Dell Latitude C600 Pentium III 750MHz, 10GB, 128MB, 14.1 TFT, 56K Modem, 24X CD (C600750128) PC Notebook Logo
57 people viewed this question
Alun Cox
