Question about Canon NP 6050 Copier
Canon 6050 thermoswitch
I already change the thermofuse still not functioning.
    Sergeant:
  • 199 Answers
Check helogen lamp with a conitinuity tester.
Posted on May 22, 2009
Where is thermofuse and thermistor located
The thermofuse and the thermistor is located in the fusing unit.Open the front cover,remove 1 screw and pull out the fusing unit(the left exit cover must open).Remove 2 screws and the unit front cover.Remove 2 screws and the upper cover,remove the harness from the harness guide,unplug the connectors of the two thermistors.Remove one screw,shoulder screw and the harness guide,remove one screw and the thermoswitch cord,remove 2 screws and the temperature detector assy.Using a soft cloth dampened with alcohol or oil,wipe clean the 2 thermistors.Verify a continuity of the thermoswitch and clean using a soft cloth dampened with alcohol,wipe clean the thermoswitch.99% the problem is a thermofuse.
Dec 17, 2012 | Minolta EP4000/5000 CS/PRO Copier
Error code E004
According to the copier error code this is the problem of abnormal fuser temp. First check the electric outlet, where you have plugged the copier and also check the dc controller. Then fix the heater & ac driver also.
Jun 17, 2011 | Canon NP 6050 Copier
E0002
check the heater lamp ,thermistor and thermoswitch
Jan 20, 2011 | Canon NP 6050 Copier
Error Code E000001-0004
The main thermistor TH1 has poor contact or open circuit.The thermal switch TP1 has an open circuit.The fixing heater has an open circuit.The SSR is faulty or the DC controller PCB.After the main power switch is turned ON the temperature detected by the main thermistor does not reach 70 C.The error must be reset in service mode :COPIER - FUNCTION - CLEAR - ERR
Jan 19, 2010 | Canon imageRUNNER C3200 Copier
CANON NP 6220 ERROR "E000"
replace the fuser lamp or the thermofuse.
E000 fuser problem.
Dec 12, 2008 | Canon NP 6050 Copier
Canon NP 6050 Copy Machine
The most like ly problem is the fuser, it probably has a blown lamp or thermofuse.
Nov 19, 2008 | Canon NP 6050 Copier
I have the 6050 but I cannot get the colater to function.
not sure by what you mean "can't get it to function"?????
Nov 12, 2008 | Canon NP 6050 Copier
Error code E004
the error has nthing to do with the drum!!!!!!!!!!!!!!!!!
I can tell you how to change it,but it will still have the code.
You have either a blown fuser lamp or thermofuse, you should change that before the drum since you still won't be able to use it?
Oct 28, 2008 | Canon NP 6050 Copier
NP 6050 Languge
how to fixed canon np 6050 copier because i dont have manual book
May 03, 2008 | Canon NP 6050 Copier
An error in NP 6050
E030 Does pertain to the total copy counter.If you have changed the dc controller & copy counter & still get the E030 error, you may have to enter the service mode to release the error. In service mode under *4* (function) advance to the error screen & press the star button. If you do not know how to get into service mode you can email me at bspier@carlsonsupplies.com or call Bill @ 315-701-1279 Please put canon 6050 E030 in subject line in case my email dumps it into the junk folder.
Aug 13, 2007 | Canon NP 6050 Copier
Canon NP 6050 Copier Logo
old marine
old marine
