A
Anonymous Posted on Dec 24, 2013
How can I fix error C-3725 ?
The machine shows Trouble code : C-3725 what should i do
Norman Weimar
Level 3:
  • Konica Minolta Master 7,035 Answers
  • Posted on Jul 05, 2016
Norman Weimar
Level 3:
Answers
7035
Questions
Helped
1913472
Points
11960
Well i need a model number
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Konica Minolta bizhub c454e Error Code C-3725? Help please
1. Turn OFF the main power switch.
2. Turn main power switch ON while pressing the Reset key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and it has been reset.
5. After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
If the code comes back replace the fuser unit (HOT PART) Do not continue to reset. Could start a fire that would ruin a perfectly good day! Once the fuser is replace may require to reset the it again
LG front loading washing machine Direct Drive 7 3.5KG Trouble shooting Error OE
go to lg.com, enter your model number and manual will show error codes and fixed for some including OE
Trouble code c-3725
ON what model machine?
3helpful
How to fix error code c-3725
c-3725 -> Fusing abnormal high temperature detection. To get rid of this code, you have to follow the below procedure:
1. Shut down from the main power switch wait for a few seconds and then start it up while keeping the 'Utility/Counter' button pressed;
2. keep it pressed until the reset button appears on the touch screen, release the 'Utility/Counter' button, touch the reset button and an OK message should appear below.
3. Restart it normally and it should work.
If the error is still there, you might need to replace the fusing unit. If you need anything else, just drop us an email at [email protected] also, visit our websites, we're sure you'll find useful things there
Konica Minolta Error Codes & Solutions - http://www.kmcodes.com
Drum, Transfer Belt and Fusing Unit Firmware Reset - http://www.bizhubreset.com
Drum and Toner Chip Reset - http://www.chipreset.eu
Transfer Belt and Fusing Unit Reset Kit - http://www.resetkit.eu
What is Code C-3725 on Konica Minolta Bizhub c451
C3725 Fusing abnormally high
(NS sensor)
• The NC sensor continues to detect a temperature
higher than a predetermined one
for a predetermined period of time.
Procedure for resetting
2. Turn main power switch ON while pressing the Utility/Counter key.
4. Check to make sure that [OK] is displayed and the it has been reset.
C-3725 trouble code
The fusing unit in side machine has reached a very high temp. This is the unit which fuses the toner to the paper the hot part upper right hand side of the machine. to reset follow:
Utility
1.Power off the machine using the main power switch inside front door leave sub power switch on that's the one on the op panel side.
2. Hold down the Utility/counter button.
3. Power on using main power switch and close the door.
4. wait for screen to show trouble reset touch trouble reset chk for OK
5. turn off main power switch, wait 10 seconds then power it up again. it should restart and go ready to copy. if the code comes back do not reset the machine again. It is informing you there is a problem get it looked at.
C-3725 trouble code
Sir/Mam,
Turn off the main power switch located inside front door. Then holding down the utility/counter button turn the main power switch on. Close front door you must keep the utility button down also make sure that the sub power switch is on. This is the switch on the side of the control panel. The screen will show TROUBLE RESET touch it see OK then power off. YOU MUST WAIT TEN SECONDS BEFORE POWERING UP AGAIN!!!!!! If the problem goes away OK. If the code comes back you need a Fusing unit. It will be expensive!!! Sorry:( DO NOT KEEP TRYING TO RESET THE MACHINE THE MACHINE IS TELLING YOU THERE IS A PROBLEM!!!!!
Error message c 3725 konica minolta c 550
Sir/Mam,
Turn off the main power switch located inside front door. Then holding down the utility/counter button turn the main power switch on. Close front door you must keep the utility button down also make sure that the sub power switch is on. This is the switch on the side of the control panel. The screen will show TROUBLE RESET touch it see OK then power off. YOU MUST WAIT TEN SECONDS BEFORE POWERING UP AGAIN!!!!!! If the problem goes away OK. If the code comes back you need a Fusing unit. Which will be expensive!!! Sorry:( DO NOT KEEP TRYING TO RESET THE MACHINE THE MACHINE IS TELLING YOU THERE IS A PROBLEM!!!!!
Error message 3725 on Bizhub C451, how do i reset so I can print
Sir/Mam,
Turn off the main power switch located inside front door. Then holding down the utility/counter button turn the main power switch on. Close front door you must keep the utility button down also make sure that the sub power switch is on. This is the switch on the side of the control panel. The screen will show TROUBLE RESET touch it see OK then power off. YOU MUST WAIT TEN SECONDS BEFORE POWERING UP AGAIN!!!!!! If the problem goes away OK. If the code comes back you need a Fusing unit High Current Device for the fusing unit. Which will be expensive!!! Sorry:( DO NOT KEEP TRYING TO RESET THE MACHINE THE MACHINE IS TELLING YOU THERE IS A PROBLEM!!!!!
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
