1999 Olds Alero, runs on unleaded gas. Am having problems with pumping gas into tank. I removed two lines from the gas spout to the tank - both were clear no obstructions found there. I still can't get more than a few cents of gas at a time to pump into tank. Does the tank have something else I need to check?
Have your evaporative purge valve solenoid check. because its controls the gas vapors going to canister purge or vent valve.take it to dealers have the evap system scan because its not venting or controling gas vapor.it suppose vent gas vapor to intake to be burn.if it dont work it causes excess gas vapor pressure built up in tank. make it hard to pump gas into it.
