Question about Sanyo DS24425 24" TV
Tv screen is tilted
I have digital cable and i just moved to a new house. When the cable man hooked up the cable my picture on the screen looks tilted. I seen this before but not this bad. I also on ocaisons see a small discolerd spot on the screen. the tv is just over a year old.
    Novelist:
  • 127 Answers
First option: find online the TV set remote code to enter the "service menu" where you may have some options to reset or configure the TV tilt you are talking about, almost like a computer monitor, depending on the options in the service menu.
But you may have cold solders in the TV circuits causing these little problems to get worst because of the moving vibrations and bumps, etc. may be also a cracked circuit board,  so I recomend you to take care of that before something worst get damaged.
The technical proccedure is to open the TV set and find broken solder spots caused by thermal stress and resolder them to avoid blown semiconductors. You also may need to replace some dryed capacitors as the tilt seems to be related with that.
Some TV sets have design deficiencies and other have bad solder proccess so thermal stress is common even in the most known brands. As you said the TV set is almost a year old then you may have still a valid warranty so claim for it to the support number.
If not a valid warranty then you may consider to pay a technician or repair it yourself depending on your skills.
Good luck...
Posted on Oct 17, 2007
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
Due to shifting your deflection coil has tilted.
small discolored spot on the screen is also due to same thing.
it is better to call tech to do it right though it is minor work but skill is required.
good luck.
Screen goes blank on Samsung LCD TV. Comes back on if tilt or move screen.
I'm gonna go out on a limb and say you may have a LCD tab(s) that are failing.
Jan 26, 2013 | Samsung LE32R73BD 32 in. HD-Ready LCD...
I just hooked up my Curtis lcd2425a tv and get no picture or sound. Just a white screen.
It might be the cable not the tv... Try hooking up an xbox or ps3... If the picture comes up on that then have someone come over to your house to fix the cable... If it doesn't work then send in your tv for a new one... Best if luck
Apr 02, 2011 | Curtis LCD2425A TV
I have a JVC DVD Player & VCR Model HR-XVC27U. It is hooked up to a Panasonic TV CT-32SL14J. I have Cable. With the JVC, I have lost any audio. If I record a VHS, I get picture, no audio. If I...
Shifting a heavy item, or anything really, can cause damage to either the cable or the port the cable is plugged into very easily.
I recommend replacing the audio cable, or trying an alternate audio output (you may be able to choose between RCA-style stereo audio output, digital PCM and digital optical.)
Similarly, the dvd player may be setup to output audio in a format that isn't matching what your AV receiver is expecting - again a variation of either stereo, digital rca or digital optical.
I hope that helps.
Jul 18, 2010 | JVC HR-XVC27U DVD Player/VCR
New flat screen hdtv has a fuzzy picture
Yes you will get a better picture quality out of a cable box if you get an HD cable box.
The reason you are getting the diminished picture is due to the signal you are feeding the TV is an analog signal. The newer HD TV's are made for digital TV and this older technology shows all its flaws on this type of TV.
When you get the new box understand that the same channels you are getting plugged directly into the tv are still going to have some grainy look to them but the good thing is that a lot of them are starting to be rebroadcast on HD channels and that is where your new toy will truly shine.
Enjoy your new TV...
Good Luck...
Jan 05, 2010 | Philips 23PF5320 23 in. HD-Ready LCD...
Everything works but the picture; even on screen programming
try pluging cable wire directly to the tv to see if you get a picture you may have shorted out the rca connection may need to be repaired good luck.....
Jan 11, 2009 | Emerson EWC1301 Combo
Color problem
is there a speaker ( other than built in ) near the tv? ( if so, move speaker away from tv.
Dec 13, 2007 | Sharp 27DV-S100 27 in. TV/VCR/DVD Combo
Unhooked ps3 from an hd tv and plugged it into an sd tv and it shows no picture.
when in standby mode(redlight) push and hold the power power button until you hear the second beep. This should reset your PS3 to it's standard 480i resolution.
Sep 21, 2007 | Sony Playstation 3 (PS3) Console
Please help snowy/ fuzzy picture
If you can move the TV to a known good working cable feed and connect it there. if the picture looks normal then most likely you have a bad splitter, a bad fitting or even a bad cable box on that TV.
Mar 16, 2007 | Philips 23PF5320 23 in. HD-Ready LCD...
No Picture
As long as you can hook that same cable up to a different TV and get a good picture, you must have somehow damaged the tuner on the APEX - unless the set was mishandled while moving. Those cheaper brands won't take much punishment.
Jan 20, 2007 | Apex Digital AT2008S 20" TV
Sanyo DS24425 24" TV Logo
48 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
