Question about LG Prada KE850 Cellular Phone
The charger is not connecting with the phone to charge it, the phone is out of battery but still has a white screen and makes some noises every so often, WTF is wrong with the thing? it was working the day before, just unusually stopped working properly!!
I had the same thing with a sony, so I'll tell you what I did with that hopefully it works. I cleaned the charger connection on the phone(sometimes grime gets in the slots). then switch the phone off and take out the battery and sim for at least a minute or so. Put everything back together and plug in the charger. If this doesn't work I would suggest you take it to the manufacturer or the shop where you got it.
Posted on May 17, 2009
Why won't the battery charge?
3 logical possibilities comes to mind: 1) Battery is faulty. 2) Charger is bad, not connected to an active wall outlet or not making good connection with the tablet. 3) There is a software issue, possibly with the application that shows the battery status.
Nov 21, 2013 | Vizio Tablet VTAB1008
Unlocked Nokia 5310 doesn't turn on. I just gave up my iPhone (got a blackberry from work) and started using this phone again. Worked fine the first day; the next morning I noticed the battery was dead. It...
Maybe its your battery or charger port.Try to use another battery, if did'nt work then it's charger port.To avoid this kind of error please do not overcharged your phone.
Aug 02, 2009 | Nokia 5310 Cellular Phone
Basically. My phone isn't connecting with a computer / charging.
You may need a new battery. If a phone does not hold a charge, or does not charge at all often the problem is the battery and not the phone.
Jun 21, 2009 | Sony Ericsson V630i Cellular Phone
Phone is not working
My phone had the same problem and it was a battery charge problem. I bought an external charger and another battery and now everything works fine but I have two batteries and an external charger, the phone doesn't charge the batties.
Aug 13, 2008 | HTC P3300 Smartphone
Motorola A1200 Problem
Easy step by step solution!
Hey guys had the same, Try this solution before buying a new battery/charging cable (it might not be the problem):
I did these steps after playing around with it for awhile and am at the stage where my phone turns on fully and says "Battery Charging" when plugged into the charger. It is now charging normally again... Finally! (I had the flashing moto logo too when charger plugged in) I believe this problem occurs because the battery is completely drained and is unable to turn on to charge bcuz the phone needs to be on to be charged, happened to me because i left it in a jacket pocket and forgot about it for weeks. Anyways...
1. You need a USB data cable for it, it should have come with the phone, if not than any USB data cable that fits the phone's charging slot should work (charge cable for the ps3 controller will work or maybe a cable from a digital camera with the same end)
2. Connect the phone to your computer via the USB cable and a USB port that works. Make sure it's plugged in and leave it (even if nothing happens and the screen on the phone is still blank). Although the screen is black, the phone is still charging via your computer (it's just too low on battery to produce the light on the display screen to load up your phone).
3. This might take anywhere between 15 and 45 minutes so be patient and leave it plugged in, beats buying a battery of charger with your money for something that can be solved for free.
4. At some point your computer will make the usual processing noises signalling that it is finally recognizing the phone as a usb device and shortly after your ming's screen will turn on stating that the battery is charging. Success! One of two things will happen, if you have previously installed the ming's drivers to your pc it will just recognize the phone. If you are like me and do not have the drivers installed, you may choose to do so via the cd that came with the phone or just not do it at all.
5. If you want to just charge it via the computer then congrats, your job is done, just leave it plugged in and wait until it is fully charged. If you wish to switch to your regular outlet charger please proceed to step 6.
6. At this point drivers installed or not, either safely remove device from the computer or just unplugg it. Now return your phone to your usual outlet charger making sure its connected. When plugged in you'll notice the moto logo appear (no longer flashing). After about 5 seconds that logo will disappear. At this time flip open the phone. The usual turn on sequence will play out and it will now load up with the battery charging screen similar to the screen from when it was plugged into the computer. Congratulations your phone should be back to normal now.
NOTE: This charge will take longer than your normal charging time but that's just for this time since your battery is super low it will be back to normal after that. Also if this did not work for your phone then now is the time to see if the charger/phone/battery is the problem.
So I hope this helps you out and eases your state of panic. I hope I saved you guys some money with this solution and that your mings are up and running again. I know i was pretty content when the problem was fixed. Please reply with any comments, questions or concerns you may have. Enjoy your once again working mings.
Jan 24, 2008 | Motorola Mobility MING A1200
My iphone doesnt charge
Hi there!
There have been some reports of iPhone chargers going bad prematurely.  The test:
  1. Connect your iPhone to your computer via the USB cable.  Does it make a little beeping noise when you connect it, and then charge up?  If so, the issue is not with your iPhone or USB cable.
  2. Next, using that same USB cable, connect it to your iPhone charger.  Do you get the same connection noise and then does it charge up?  If not, the issue is probably with the charger.
Assuming you have a faulty charger, you are still well within your 1 year warranty from Apple.  Visit an Apple store (www.apple.com/retail) Genius Bar (make your reservation online before you go, to avoid waiting around), explain the issue and how you tested it out, and they will almost certainly replace the charger for you at no cost.
Oct 11, 2007 | Apple iPhone Smartphone
White screen
your screen is out you can buy a scree of ebay or if you have insureance on your phone you can get a new one free of charge
Oct 03, 2007 | LG CHOCOLATE VX8500 Cellular Phone
Battery won't charge
I have the same phone and it flashs every now and then when its charging but it charges and works fine. Is yours charging?
Jun 25, 2007 | Motorola Mobility MOTOKRZR K1 Cellular...
Phone hangs when connected to charger
Sounds like a problem with the battery. Is it a problem to make a telephone call and do you have a humming noise?(gsm sound)?
Jan 03, 2007 | Palm Treo 600 Handheld
LG Prada KE850 Cellular Phone Logo
29 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
