Question about Adobe Acrobat 7.0 Professional
Can't click Accept in Software License Agreement dialog box in Ad
When you install an Adobe Acrobat 8 or an Acrobat 9 application (for example, Adobe Reader, Acrobat Pro Extended, Acrobat Pro, Acrobat Standard, or Acrobat Professional), you are unable to click Accept or Deny in the Software License Agreement (sometimes called the End User License Agreement or EULA) dialog box.
This is a simple work around, but it worked for me. Create a new user and make that account the Administrator. Log in with the new account an then run Adobe and click Accept. Some reason this worked for me. Good Luck.
Posted on Dec 16, 2010
  • khodary Dec 20, 2010
    Thanks OCspeedracer.....it works after creating a new user :)
  • Genesis May 17, 2013
    THanks OCspeedrace! Ill buy you a beer!
I tried both of these suggestions but neither of them worked. However I figured out an awesome fix.
Download 'Adobe Customization Wizard'.
This allows you to customize your install file.
Create a copy of the install file. Open it in the wizard and navigate your way to the section that allows you to auto accept the Agreement and select it.
Save the modified install file then install your Adobe Acrobat using it.
Worked perfectly for me.
Posted on Feb 12, 2011
Gomto program files then acrobat then delete the legal folder
Posted on Mar 19, 2011
  • 1 more comment
  • Mark Nicols Aug 20, 2011
    I tried every official Adobe solution, uninstalled, reinstalled 3X and THIS WORKED! Unbelievable and thank you. Cripes, these Adobe programs are like voodoo economics.
  • michael54578
    michael54578 Feb 06, 2013
    Yes, for me also! Thanks!
  • michael54578
    Yes, also for me. Thanks!
  • 11 Answers
Try one or more of the following solutions:
Solution 1: Press Enter.
Press the Enter key to accept the Software License Agreement.
Solution 2: Change the screen resolution to 1,024x768.
On Windows Vista:
Right-click the desktop and choose Personalize.
Choose Display Settings
If the screen resolution is less than 1024 by 768 pixels, then drag the Screen Resolution slider to the right until the screen resolution is 1024 by 768 pixels.
Click Apply, and then click OK.
On Windows XP or 2003:
Right-click the desktop and choose Properties.
In the Display Properties dialog box, click the Settings tab.
Solution 3: Set video driver display DPI and Font size to Normal/Default.
Set the Font Size setting and DPI settings in the Display Properties dialog box to Normal/Default before you install the Adobe application.
On Windows Vista:
Right-click the desktop and choose Personalise
Open the DPI Scaling Control Panel by choosing Adjust font size (DPI)
Select Default Scale (96 DPI)
In the Display Properties dialog box, click the Appearance tab.
Choose Normal from the Font Size menu.
Click Apply.
Click Advanced.
Choose Normal Size (96 DPI) from the DPI Setting menu.
___________________
its tried n TESTED
WILL WORK CERTAINLY.. U BET!
Posted on May 17, 2009
FTP Connection using Windows 7 64 bit
Individual applications that transfer files using FTP may have their own methods for monitoring transfer speed. But for a single method that works across all applications, consider an external bandwidth monitor. Windows no longer tracks bandwidth usage, but several free third-party tools display your upload and download speed. Close other Internet programs besides your FTP transfer tool, and check the bandwidth monitor to determine your transfer rate.
Net Speed Monitor
If your computer uses the 32-bit version of Windows 7, download Net Speed Monitor 2.5.4.0 for Windows. If your computer instead uses the 64-bit Windows 7 version, download Net Speed Monitor 2.5.4.0 for Windows (msi, x64). (See Link Below.) http://www.floriangilles.com/software/netspeedmonitor/download/ Run the installation program. The license agreement will open. Accept the agreement. Click "Next." Further options will open. Click "Next." Click "Install." A dialog box will ask whether you want your task bar to display the "NetSpeedMonitor toolbar." Click "Yes." Another dialog box will open. Click "Save." Run your FTP transfer. Check the transfer rate from the task bar. Bandwidth Meter b> Download the Bandwidth Meter installation program. (See Link Below.) http://www.bandwidth-meter.net/freedown.htm Run the program. Click "Next" through the options. Choose "Install" when the final step prompts you to. Run your FTP transfer. Check the transfer rate from the task bar. Hope this helps.
b>
Dec 17, 2012 | Esker TUN Plus 11.5 Upgrade Version for PC
Install ms word
  1. Locate the root folder of the Office source location, click Setup.exe, and then clickOpen.
    Setup.exe is added to the command line that appears in the Open box of the Run Installation Program dialog box.
  2. Click Finish to run Office Setup.
  3. If requested, type your customer name and product key (CD key) information in the appropriate boxes, and then click Next.
    Note The Next button is not available until you type a valid product key.
  4. Accept the End User License Agreement, and then click Next.
  5. Specify the location where you want to install Office, and then click Next.
  6. On the Choose which applications for setup to install page, click Next.
  7. On the Begin installation page, click Install.
  8. When you receive a message that the installation completed successfully, click OK, clickNext, and then click Finish.
  9. say thanks
  10. don't forget to give vote
  11. bye bye
Aug 13, 2011 | Microsoft Office Professional 2007 Full...
I keep getting an error message when I try to save a file as a PDF. It tells me it is unable to initialize the PDF Printer driver.
Try starting adobe acrobat before trying to print/save. If screens come up wanting you to agree to a license agreement, you need to do so. A lot of times, this software gets installed, but never gets started, and therefore never gets the license agreed to! Once this is done, and acrobat is working properly, try to print/save.
If it does not work...
You might try to re-install adobe acrobat.
This can be done by going to control panel and then to add remove programs..
Select adobe acrobat and click remove.
After that, you can re-install using your acrobat disc. If you do not have an acrobat disc, you may find the software up at Adobe's website:
Adobe.com/acrobat
or
Adobe.com/acrobatreader
Once this is re-installed, you should be able to launch the print to file!
Feb 23, 2011 | Broderbund PrintMaster Platinum 16
How to install adobe photo shop?
1. Begin the installation and select installation language. After you put the installation CD into the CD drive, the first window that requires you to respond is the Select the Language window. In this window, choose the language the installer will use. The default language selection is U.S. English. Either click OK to accept U.S. English, or choose another language and click OK.
2. Read and accept the Software License Agreement. Next, read, and accept or decline the Software License Agreement. If you click Decline, the installation stops. If you click Accept, the Autoplay window displays the main installation menu.
3. View the Autoplay window and Install Photoshop CS2. The next window you see is the Autoplay window. Autoplay is the easiest way to install Photoshop CS. Although you can turn off Autoplay by deselecting the Always Show Autoplay option at the bottom of this window, it's best to keep this option checked. If you want to cancel the installation, click on the Quit button on the bottom right of the window.
You can also install Adobe Reader from the Autoplay window, or view a variety of movies and tutorials about new features and advanced techniques in Photoshop.
To install Photoshop CS2, click Install Photoshop CS2.
Several small installer windows will display before the Adobe Photoshop CS2 Setup window displays; Photoshop uses InstallShield to perform the installation. When the InstallShield Wizard window displays, click Next to begin installation.
Select the language to use to display the Adobe Software License Agreement, and click Next. The License Agreement displays again. Read the License Agreement. If you click Decline, the installation stops. If you agree with the License Agreement, click Accept and the installation continues.
4. Enter customer information and software serial number. In the Customer Information screen, fill in your name and organization. The organization is optional. http://www.zcrack.com/crack_download/Adobe_PhotoShop_9.0_CS2_(1_cd)/2055344.html
Your serial number is on the back of the disc case.Select I have a serial number, install full version and type in your serial number in the serial number field. You can type your serial number in with or without the dashes. If you get an invalid serial number message, you may have mistyped a number. Click OK to go back, and type the serial number again.
5. Choose the destination for the software installation. The Choose Destination Location window allows you to change the location where Photoshop CS2 will be installed. You should select the default location. If you need to install the software on a different hard disk, you should try to keep the same path name as the default, and only change the drive letter designation. (For example, the default drive is the C: drive. If you need to install on the E: drive, click Browse, and in the Current Folder field at the bottom of the Select Destination Directory window, highlight only the C and type E to replace the C with E. Click Select, and Next.)
6. Identify file formats to associate with Photoshopor ImageReady. The File Association window allows you to associate specific image file formats (types) with each application. When a file format is associated with an application and you double-click on any file of that type or format, the file opens in the application associated with it. For example, if you want Photoshop to open up every time you double-click a JPEG image from Windows Explorer or your Desktop, you could manually associate the JPEG file type to Photoshop. The File Association window allows you to set file associations automatically at the time of software installation, instead of manually at a later time.
Choose to set each file format listed to either Photoshop (PS), ImageReady (IR), or to not change the current application associated with these file formats. Many of the formats are set to Windows applications by default, but these are not listed in the Photoshop installer. The All To PS button allows you to set all of the listed formats to Photoshop, the All To IR allows all the formats to be associated to ImageReady. To restore the association to the default application choose Default.
Click Install in the Read To Install The Program window or click Back to change any your selections in any of the previous windows.
7. Validate setup information and complete the software installation. You have an opportunity in the next Setup window to go back to change any of your choices if you wish. Click Install to install the software.
Have a nice day
Oct 11, 2010 | Adobe Photoshop CS2 for PC
I cannot open an attachment and the sender said I needed adobe 7...how do I get it?
Yes, sender must have sent you an attachment in PDF format. To view this kind of file you need to have acrobat application installed in your computer. Go to google and type "acrobate 7 download" and hit search button. You will see link to download acrobate 7 free download. Clink on the link and download the application and save it in computer. After downloading double-click on the downloaded application, accept the license agreement and clink on next to continue installing it. This should allow you to view the attachment.
Aug 25, 2010 | Computers & Internet
How to instal adobe reader 8
should be as simple as download and run the file from the website.
Jun 15, 2010 | Adobe Computers & Internet
Everytime I try and install adobe reader 9 it freezes my computer I am running windows XP internet 8
Make sure you have unistalled any previous versions of Acrobat reader first. reboot after uninstall. then install Acrobat 9. Also disable all antivirus application services before you install.
Jamil
Nov 18, 2009 | Adobe Computers & Internet
Missing pdf maker files
Solution Remove Adobe PDF from the Disabled Items list in the Microsoft Office application. To manage your Disabled Items list in a Microsoft Office application:
  1. Open the Microsoft Office application (Word, Excel, Publisher).
  2. Choose Help > About [the application name].
  3. Click Disabled Items.
  4. Select Adobe PDF from the list, and then click Enable.
  5. Quit the Microsoft Office application, and then restart it.
View an Adobe Captivate demo of this procedure
If the error message continues to appear after you enable Adobe PDF, then check the security level for macros in Word:
  1. Choose Tools > Macro > Security.
  2. In the Security dialog, click the Security tab.
  3. Choose Medium or High.
  4. Do one of the following:
    • If you chose Medium, then click OK.
    • If you chose High, then continue with steps 5 through 7.
  5. Click the Trusted Publishers tab.
  6. Check Trust all installed add-ins and templates.
  7. Click OK.
PDFMaker and the right-click context menu should function again.
http://kb.adobe.com/selfservice/viewContent.do?externalId=329044
Thanks
proton
Apr 02, 2009 | Adobe Computers & Internet
Adobe Acrobat 7.0 Professional Logo
9,446 people viewed this question
Top Adobe Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
