Question about Lexmark X7170 All-In-One InkJet Printer
Printer installed fine, won't print. Error code 0x0000007e?????
I installed my Lexmark X7170 on my new laptop,and it won't even print a test page. It comes up with error code 0x0000007E? Any ideas?? (laptop is an EMachines D620 w/ Windows Vista) Installed fine, but printer won't print.?????
  • pclinvestmen May 17, 2009
    This printer works on USB port. Any other ideas???
  • 30 Answers
Maybe you didn't configure the port.
To do this you must go to properties of the printer then try to locate the port output. LPT1, LPT2... the default value is LPT1.
Posted on May 17, 2009
  • Rhegie Cañete
    Rhegie Cañete May 18, 2009
    Click Start -> Control Panel -> Click Printers and Hardware then click printers. U will see the installed printer then right click, choose properties then you will see the information of your printer then check the preferences of that then check if it is settled to port LPT1 and that is the default value if you installed a printer. U can also use the other ports but there is many configuration to do. I hope that I solved your problems.
  • 323 Answers
First make certain a USB cable is attached to your printer and to your USB. The windows install device will tell you it has located new equipment and ask if you want Windows to install it. If you didn't go through this before, allow Windows to install it. Use the disk that came with the printer if you have it. (Make sure the drivers on the disk will run on Vista. The disk should tell you. Lexmark 7100 series was introduced a ways back).
If you've gone through this, and you know it is installed correctly, with the proper drivers, go to "Control Panel". Choose Device manager, and click open "Ports (Com &LPT).
Choose Communications Port (Com 1). Opening that will give you the Properties page. Click Resources at the top of the page. About halfway down the page will be a small box that says "Use Automatic Settings". Make sure this is clicked. It gives Window permission to find and use the best generic drivers for your printer, among other things.
At the bottom should be another box entitled Conclicting Device List.
It should say in the box "No Conflicts." Click OK to exit that box if all is well. Next, go back to Control Panel again. Look for and choose "Printers". Among other selections, you should see an icon of a printer that says Lexmark 7100 series. That should have a big green checkmark by it in a circle. If it doesn't, click on the icon and a small box will open in the upper left hand corner.
It should say "Lexmark 7100 Series". If it does, click on Printer, then click add as default printer. Then when you close the box you shouls see the icon marked Lexmark 7100 series, with the green checkmark inside a circle.
If you don't see all these things wirite back and we will take the next step.
Sirwriter
Lexmark X7170 will not print in grayscale
i have cannon 3530 xerox machine ... it shows error code 350 ?? any solution ??
Jul 28, 2013 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
This has been addressed a lot but my problem isn't solved. I have a brand new Black 32 toner for a Lexmark x7170 all in one printer. It won't accept the toner - gives me the message "left...
It could be a faulty cartridge. Have you already tried inserting a different known working cartridge? If error continues to pop-up even with a different new or a known working cartridge, then it could be a hardware problem. Try to contact Lexmark technical support on the phone for additional assistance.
May 10, 2011 | Lexmark X7170 All-In-One InkJet Printer
I have a Lexmark x7170. After installing ink cartridge printer says incorrect left cartridge.If you try to print you get unsupportive cartridge.We had just changed the cartridges and it printed fine till...
Some older print cartridges are not compatible even if your model is listed on label. I'm talking a few years difference. The printer knows this and that is what the error is telling you. Make sure you have the right number in the right slot.
Jan 06, 2011 | Lexmark Office Equipment & Supplies
I installed a new color cartridge in my printer but it comes up with cartridge missing and i can't get to print in color
Power off the All-In-One and remove the power adapter (brick) from the back of the unit. Wait 20 seconds, reinsert the adapter, and power the unit on.
Did the error message return?
Yes: Continue to step 2.
No: Print a test page. If the test page prints, the error is resolved. 2
Reset the All-In-One's factory defaults (click here for instructions).
Yes: Continue to Checking the Cartridges.
Open the top cover of the All-In-One. Remove both cartridges. Close the top cover. 2 Power off the All-In-One and remove the power supply brick from the back of the unit. 3
Reinsert the power supply brick into the back of the All-In-One and power the unit back on.
Does the error message reappear?
Yes: Skip to Contacting Lexmark below. There is a hardware issue with your printer and you need to contact our technical support center.
No: Continue to step 4. 4
Clean the cartridge contacts (click here for instructions) and the AIO carrier contacts
(click here for instructions). Continue to step 5. 5
Power the AIO on, reinsert the black/photo cartridge, and close the top cover. Power the All-In-One off and then on again.
Yes: Power the unit off and try step 5 with another black/photo cartridge. If the error persists with the new cartridge, proceed to Contacting Lexmark.
No: Continue to step 6. 6
Power the AIO on, reinsert the color cartridge, and close the top cover. Power the All-In-One off and then on again.
Yes: Power the unit off and try step 6 with another color cartridge. If the error persists with the new cartridge, proceed to Contacting Lexmark.
No: Try printing a test page. If the test page prints, the error is resolved
Oct 28, 2010 | Lexmark X7170 All-In-One InkJet Printer
I just installed new ink cartridges. Getting an error code 1270 when i install the color cartridge
NOTE: The embedded links lead to specific troubleshooting documents.
Step Action 1 Open the top cover of the All-In-One. Remove both cartridges. Close the top cover. 2 Power off the All-In-One and remove the power supply brick from the back of the unit. 3
Error:2200
“Lexmark does not support the refilling of its ink cartridges. Refilling the ink cartridges can cause them to leak, thus clogging or even damaging the print head. Any damage to your printer caused by refilled ink cartridges may not be covered under warranty”. Please use genuine Lexmark cartridges for best results.
May 13, 2009 | Lexmark X7170 All-In-One InkJet Printer
I have the lexmark x7170 all in one. I am getting error message 1203..."cartridge error". HELP!!!
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
Apr 27, 2009 | Lexmark X7170 All-In-One InkJet Printer
Only prints last page or least few pages of a ulti page document
if your taskbar displays printer icon on system tray double click on that & delete all privious prints.
select the text or area which you want to print. & give print command, & Click on print selection button & then Print.
Jan 17, 2008 | Lexmark X7170 All-In-One InkJet Printer
Right cartridge incorrect
This solution (RESET the BRICK - solution 1 above) worked for me!
I had a brand new out of the box Lexmark X4580 and after one or two prints I was suddenly getting a "Left Cartridge Incorrect" error showing on the Printer Control Panel and the printer would now all me to print anything.
After about an hour of trying this and that (cartridges in, out and shalen all about!) ; no avail, I tried this and hey presto, it worked.
When I removed the "Brick" power supply I left it until the Green LED had faded right out though, I dont know if that was significant or not. Fingers crossed all is sorted now!
Mar 14, 2007 | Lexmark X7170 All-In-One InkJet Printer
Lexmark X7170 All-In-One InkJet Printer Logo
719 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
