Question about Ruud UAKA030 Air Conditioner
Goodman 90% gas heater condensation build up
I have a new Goodman gas furnace with the exhaust going vertically out to my roof. After the heater fires up and runs for a few minutes, the housing gets about 4 oz. of water in it and will not fire up again until I remove the pressure tube and drain it. Why is the system getting condensation in it, and how can I stop it?
  • Bobusa Oct 17, 2007
    Thanks! I actually figured out that the installer did not connect a drain line at all. The drain nipple was capped off from the factory and this is exactly why it was filling up with water. The installer should have known but did not. I guess these newer high efficiency furnaces create water vapor. My vertical exhaust is also dripping a little bit of condensation. When the installer comes out today, I'll have him look at that too after he runs a line to my drain pipe. Problem solved!
    Thanks for your help!!!!!
  • 1,420 Answers
If the exhaust comes off the top of the furnace, you will need to make sure the condensation will drain all the way back to the condensate outlet found at the base of the inducer blower. If you are having to remove the tube from the pressure switch, there must be a blockage from the inducer down to where ever it drains to. Check to see if all tubes are free of blockages and if there is a condensate trap, clean it out. If the pressure tube you mentioned is facing up toward the blower allowing water to flow into it, reposition it so water will not enter the tube.
Posted on Oct 17, 2007
New goodman 80% gas furnace leaking condesation down exhaust vent
it could be condensation. or poor seal at roof. probably the seal at roof. also check the larger copper line is it sealed good? if any spot is not this will cause leaking when in cooling mode. maybe dripping from line onto vent.
Jan 28, 2014 | Goodman Manufacturing Goodman 60,000 btu...
Tip
80%, 90%, and 95% Gas Furnace Manual
http://johnstonesupply9.com/TechDocs/Goodman/Furnaces/GMV9%20Variable%202-Stage%20Upflow%20Gas%20Furnace/GMV9%20Service%20Man.pdf
After giving up on Yahoo, I found this on Google. It's the detailed manual for 80%, 90%, and 95% gas furnaces. Hope this helps!
on Oct 04, 2009 | Goodman GMS90703BXA Heater
My high efficiency furnace has water (possibly condensation) running down the air intake pvc pipe into the furnace and all over the burner, gas valve, and wiring.
First, check the drainline from the furnace. You have a 90% gas fired furnace. Where 80% furnace has 1 heat exchanger, yours has 2 heat exchangers. And the second heat exchanger will cool the exhaust enough, that it ends up below the dew point, and your furnace outlet/exhaust will condensate. This drain is probably stopped up. Now, I've installed and service many of these systems and I've only seen the piping at the roof you described once. And that was when the roofers replaced the roof, damaged the furnace flue pipe, and tried to repair it themselves. Normally, and this may not apply to yours, we tie in the exhaust/supply lines about 2-3 ft. above the furnace. Then 1 pipe goes through the roof. Thus 1 pipe is a kit that has an inner liner & outer pipe(2 pipes in 1). Now I'm not sure if this is a problem or normal for your system, but it may be worth looking into. You should be able to find it in the installation manual, or call a local parts house that sells your brand, or as your tech. And if it's just your drain, forget all about the piping I mentioned. Hope this helps!
Mar 08, 2017 | Goodman Heating & Cooling
We have a Goodman GSK9 gas furnace. There is a weep hole on the PVC outside of the house, that in the winter develops a vry large icicle against the house and has damaged our wood siding. When we plugged...
Hello Jmranes,
It sound to me like your getting alot of condensation on your exhuast pipe and a weep hole was drilled to "BAND AID" the issue. These is not how 90% plus furnaces are installed. If you are referring to the outside intake and exhaust PVC piping, then there shouldn't be any weep holes. When the furnace is properly installed, the furnace comes with a condensate kit (refer to owners manual) that is mounted on the side of the furnace and all the condensation that collects overflows and should be piped directly into a floor drain. As for the intake and Exhaust for side discharge application, the Exhaust PVC pipe should come out through the side of house and immediate goose neck up (90 degree) with a straight piece of PVC pipe about 2' to 3' or so in length, then a final 90 degree PVC fitting on that so the exhaust blows out. As for the intake, that also comes out the side of the house about 2" to 3" inches parallel to the Exhaust but should only be a 90 degree PVC fitting facing down. The idea here is making sure the furnace doesn't suck in exhaust air. Also, making sure proper size pipe was used. Both outside pipes should be open to atmosphere. I hope this helps.
Nov 12, 2017 | Goodman Heating & Cooling
Sounds normal at first. Runs till first 1/2 segment of burner status lights come on then lights go off and unit runs for several minutes with all burner lights flashing and shuts off. Also has had an...
Sounds like a blockage in the exhaust line and a pressure safety switch is shutting it down. If its an 80% efficient furnace check the exhaust line and the roof vent cover for damage or blockage. If there's ice on the roof, take all necessary safety precautions!!!! If its a 90% efficient furnace, make sure that all the condensate lines are free of any blockage. Remove power to the furnace and remove and clean these lines. Also check the condensate drain lines to make sure that there is no blockage in the line. A water and clorox solution with help to remove any algea build-up.
Jan 27, 2011 | Heating & Cooling
Condensation building up in lower compartment of goodman 45btuh furnace in counterflow position 95%a.f.u.
Make sure all drains and hoses are connected to the lowest positions and that they are free of any blockage or debris. If there is not a vent or stand pipe on the drain line as it exits the furnace cabinet, put one in. A stand pipe is a Tee with a vertical pipe going up approximately 5" and allows the water to drain easily by breaking the vacuum normally experienced by the inducer blower.
Feb 03, 2010 | Goodman Heating & Cooling
Black dust
When the unit is off get up on the roof and look down the vetilation pipe. Sometimes birds or wildlife tend to think they can build a nest in there.
May 05, 2009 | Goodman GMS90703BXA Heater
Condensation running down old vent pipe running to roof.
This is a condensing furnace and is ment to condense. You will need to pipe away the condensate using a hose and maybe a condensation pump. It is unclear where the combustion air pipe is going? Are you using room air? or do you have a second pipe going up the old vent as well?
Jan 05, 2009 | Goodman GMS90703BXA Heater
Gmh950904cxac burner on for a few sec.
sounds like a problem with the flame rod. small silver rod that sits by end burner and detects a flame.
Sep 11, 2008 | Goodman GMS90703BXA Heater
Ignitor glows, but no gas
Most likely either a bad board or no gas to gas valve. Bleed out all air in the gas line. Check for 24 volts at both gas valve and circuit board terminals leading to gas valve. No voltage = bad board.
Jul 23, 2008 | Goodman GMS90703BXA Heater
Ruud UAKA030 Air Conditioner Logo
1,206 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Dennis Boxerman
John Tripp
John Tripp
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
