PC Laptops
Problem for PC Laptops
Generic problem for all PC Laptops
Problems with wireless and MS Vista
By Furayo on Oct 17, 2007
I recently bought a new Gateway laptop with MS Vista Home premium edition. I am having issues with my wireless connection: very often, the laptop can not connect to the wireless network, or gets disconnected with no reason. When that happens my other computer (a Macbook) is connected flawlessly to the same wireless station.
I updated the wireless card with the last drivers.... still not working. Tried some of the things I found in the web about changing the energy saving profile for the wireless card. No results. I am pretty sure that this is a Vista issue, but i have no idea what to try next, and this thing keeps failing. Any guidance will be appreciated....
Same Problem
Sep 24, 2009
-   please i nead driver of network only .-   noor_ahmadi
Dec 21, 2007
-   I have a ThinkPad T40 and I have the same issue. My laptop will connect to the wireless and then will get disconnected for no reason. Other computers work fine at this router and all drivers are updated. I am going to try an external wifi adapter to see if my wireless card is the issue....-   kkambod
Nov 20, 2007
-   Brand new Toshiba Satellite. Connected to Wireless Linksys 802.11g router and it worked fine. Then without any symptoms, it just disconnected. Checked my other two computers and they are connected just fine. My laptop shows the network adapter is enabled, but will not connect. An error message says the event name was appcrash and the application name was rundll32.exe. The message said "Windows host rundll32 has stopped working. Windows can check online for a sooution to the problem the next time you are online. (Ha. Ha.) If I cannot get online how can it check it?-   Guest
Best Solution
posted on Feb 18, 2008
Helpful)
tom19511
Rank: Guru
Rating: 85%, 2166 votes
Try these first:
change channels to 1-6-or 11. Make sure you change all of your wireless computers.
check is to make sure you are NOT using "IEEE 802.1x authentication for this network."
You can find at setting under "Wireless Network Connection Properties" and then under "Authentication" tab of your network properties.
This particular authentication method is periodically logging you off the network and re-authenticating.
Check the adapter in device manager to make sure that windows is not shutting the adapter down to save power.
Cordless phones and wireless ethernet cards use overlapping frequencies.As a test, you can unplug the AC cords from all the cordless phones in the area and see if it helps.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for PC Laptops
Questions and Unsolved Problems for PC Laptops
Answer
cannot open CD room and cannot start computor to get into operationg system can get into BIOS area... (More)
Answer
what is the problem of my HP laptop is going to blink2x his display in screen?
Answer
Touch pad scrolls , but when I click on something it doesn't pull up what I clicked on
Answer
need to replace acer aspire 5314 hard drive. Where can I find one?
Answer
I have a Sony Vaio VGN-N130G. It crashed and I am trying to get it to reboot from the recovery disc... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For PC Laptops:
Top PC Laptop Experts
Rank: Guru Guru
Solutions: 751
Experience: 30 Years of professional repair and design.
Ask Me
Find more PC Laptop Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
