Question about Kenwood Car Audio & Video
They are not wanting to play like they should
Ok, i got new kenwood 10" subwoofers and the kac-5204 amplifier. And i have all my wires right.the amp is even powered up. but they not even pushin anything.
  • 655 Answers
Hello again debrahood196,
Your KAC-5204 amp is only rated to put out 60 watts per channel and really cannot push very hard. If your subs are the KFC-W110S, they are 8ohm subs and you will get better power from the amp by using the bridged connections, positive (+) on the left channel and negative (-) on the right channel. Wire both positives and both negatives from both subs to the bridged connections and the output will be 150 watts into 4ohms. Giving each sub 75 watts should make them push a little harder.
Posted on May 18, 2009
My kenwood kac-5204 amp lights up red but no sound???
when the amp lights up red that means proteion , an no sound mean input is gone on the amp . you have to take it apart an fix it
Jul 19, 2011 | Kenwood Car Audio & Video
Red light on no sound
ur amp is in protect mode something is fried or speaker wires are touching
Jun 08, 2011 | Kenwood KAC-5204 350 Watt Max Power Stereo...
Not getting any output from subwoofer, all connections are right,everything is on.
DOUBLE CHECK YOUR RCA CABLES. MAKE SURE THEY R GOOD & THAT THIER IN THE RIGHT SPOT ON THE AMP AND RADIO DECK.IF YOUR LIGHTS COME ON. THEN TRY THIS........ IF THAT DOES NOT WORK. CHECK TO SEE IF YOUR SUBS R CONN IN THE SUB BOX.IT COULD B SOMETHING THAT SMALL
May 21, 2011 | Kenwood KAC-5204 350 Watt Max Power Stereo...
I hooked up everything the right way and for some reason my subs still wont bump at all. what could be the problem?
One of two things:
Either faulty, or not hooked up right.
Double check your grounding point and voltage coming from the head unit (blue wire), make sure you have your "feed" wire (blue) hooked up to the proper place on the head unit. Varify 12v from battery with multimeter. IF all that checks out...your amp is faulty.
Please rate if this helped
Apr 05, 2011 | Kenwood KAC-5204 350 Watt Max Power Stereo...
I have a Kenwood KAC-5204 amp on dual Kenwood W-110S subs, been working fine since I installed it all about a month ago, and I got in my car this morning and noticed no bass. I saw that my red power light...
Check the fuse in the amp. There should also be a fusable link that houses a huge fuse, if that blows it will give the same effect. You will want to check to make sure that the wire that runs from your battery to the amp is secure and free of corrosion as well. If all of the above is fine, then I would recommend that you check to see if the rca cables are plugged in securely in the head unit.
Feb 24, 2011 | Kenwood KAC-5204 350 Watt Max Power Stereo...
Cant get remote wire to turn on amp. it is running from back of kenwood deck to kenwood amp.
OK ! FIRST THINGS FIRST. DID U TEST THE AMP FIST. BEFORE U STARTED INSTALLING RCA CABLES,AND REMOTE WIRES. LETS DO THAT FIRST.GRAB YOUR AMP.SET IT ON YOU WORK BENCH ,TABLE,OR CHAIR.THEN GET (2)PIEACES OF #10 OR #12 WIRE W/1 OF THE WIRES HAVING A 20AMP FUSEABLE LINK ON IT.NOW THE WIRE W/THE FUSEABLE LINK ON IT.CONN THE REMOTE(REM) AND THE 12v + ON THE AMP AND HOOK THEM BOTH TOGETHER ON 1 SIDE OF THAT FUSEABLE LINK WIRE. AND THE OTHER WIRE HOOK IT UP THE - GROUND SIDE OF THE AMP .NOW PICK UP YOUR AMP OPEN UP YOUR HOOD.MAKING SURE THAT NO WIRES OR THE AMP IS TOUCHING THE + 12V OF THE BATTERY. NOW CONN YOUR GROUND TO GROUND AND THE FUSEABLE LINK ON THE +12v SIDE OF THE BATTERY.NOW THE AMP SHOULD HAVE CAME ON. LOOK 4 A SOLID RED LIGHT OR ANY SIGNS OF A SOLID LIGHT THAT HAD CAME ON.
Feb 21, 2011 | Kenwood KAC-5204 350 Watt Max Power Stereo...
How to hook up a kenwood amp.kac-5204
All amps are basicly the same. It should be plain as day where the speakers connect to.
The 12V screw connects to the main power from battery, be sure to fuse that wire and use a proper size wire, thicker is better,I suggest at least 8gauge with 40amp fuse. The GND is ground and should connect to car metal, file paint for soild connection. The REM is remote and connects to the remote of headunit or if you have a stock deck to the acc of car found in wire harness of headunit. Plug in the RCA's to head unit, or get a converter to plug into speaker wires from car if you have a stock headunit.
Mar 22, 2010 | Kenwood KAC-5204 350 Watt Max Power Stereo...
I have a kenwood kac-9152d running a 10 inch rockford fosgate power t1 and the amp keeps going into protect but i have a smaller kenwood kac-8102d running on another t1 and i have no issues with it why...
either the wiring your running is short circuting,or the amp is shot, or the subwoofer is shot, try hooking the same speaker up to the other amp. along with the other speaker to the other amp, see if the same thing happens.
Feb 04, 2010 | Kenwood KAC-9152D Car Audio Amplifier
Connecting subwoofer to kac-7201 kenwood amp
from your sub connect one short piece of cable from + on one side to - on the other side using the same diameter cable as you are running to the sub from amp . this will leave you with + and - on opposite sides of speaker these will then run to the amp +to+ and - to- on the mono side of connetor which is one left + and one - right and the amp switched to bridged
Mar 22, 2009 | Kenwood KAC-7201 Car Audio Amplifier
Car Audio & Video Logo
119 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
