Question about Linksys WRT54GX2 Wireless-G Broadband Router with SRX200 (LS-WRT54G2)
Step 11 and 12...
I'm trying to setup model wr754gx2 with set-up disc version 1.0 and i get to step 11 when it ask if I want to disable and I'm not sure what to do and then step 12 keeps saying:  the setup utility was unable to locate a wireless-g broadband router on your network. please make sure your wireless-g broadband router is powered on and all cables are properly connected."
everything is connected and powered so i'm not sure what to do.
  • Anonymous May 24, 2008
    i have checked the cables and even replaced them all of them are fine but the setup wont continue what a bunch of ****!!!
  • Tony Leather
    Tony Leather May 11, 2010
    I would check the ip addresses for the modem & the router.You can do
    this by typing a command line from the "Run" entry on the Start menu.
    At the command line type in ipconfig /all & there you will find the
    ip addresses. My hunch is that they are both set to 192.168.1.1 - you
    will need to change one of these to something like 192.168.2.1.
    Scholar:
  • 110 Answers
I would guess you didn't do it in the correct order.
Are you 100% positive th  Ethernet cables are in the right ports?
Check the one that goes from the modem, to the router.
If that doesn't help, would you let me remotely control your PC and see what it looks like?
Posted on Oct 19, 2007
DVD bypass code for Jensen VM9216BT
1: Go into AM/FM mode
2: Hit "setup" on the remote control
3: Enter 543210 on the remote,
listening for the beep for each number
entered
4: A new menu will appear. Touch the button that has the hammer/
screwdriver on it in the upper left-
hand part of the screen.
5: Select Brake bypass to "ON" and hit
the "X" near the bottom of the screen. There is the code.
Jul 16, 2013 | Jensen VM9216BT 7" Touch Screen DVD, MP3,...
Tip
What i have to do if its asking for a PIN Number when connecting a Belkin...
Hi Friends,
When you are connecting the Belkin router in Wireless,if it asks for PIN Number then please follow the below mentioned standard steps,
Step 1:Connect the belkin router to any one of your computer with an enternet cable.
Step 2:Open Internet Explorer and type 192.168.2.1 and click on Enter button in the keyboard.
Step 3:Now you will be able to see the belkin router page
Step 4:On your left side click on Wifi Protected Setup (WPS),now it will ask for password leave it blank and click on Submit.
Stpe 5:Now Change the WPS (Wifi Protected setup) to disable and click on Apply Changes.
Step 6:Now Try to connect the Wireless Networks in your wireless computer,it wont ask for PIN Number.
The above mentioned steps are the standard steps for the this problem.This is done because by default the belkin router's will be enabled with 2 security features so we have to disable any one of this feature.If you disable this then you wont have any Problem in the belkin router.
on Mar 16, 2010 | Computers & Internet
Why scan disk run while login and for what are all it will run
Probably Scandisk/Check Disk is enabled during start up on your PC.
However if it is running automatically then there might be various reasons,
1: IF PC is shut down improperly.
2: Bad Sectors on your Computer.
3: HD might be on the verge of corruption.
You may want to let that run and if you want to disable it then you may want to follow below mentioned steps,
Step 1: Do it with the freeware version of X-Setup: http://linux4.wekanet-team.de/download/390/xqdcxsp-setup-en.exe
Download and install the program, run it, click "Classic," and on the plugins list go to Startup/Shutdown>Startup>Windows NT/2K/XP>01)Bootup Options>Boot-time Autochk Settings. In the plugin options window on the right you can disable chkdsk running on bootup for a couple types of bootups.
Step 2: Go to : my computer ----> right click on the hard drive you have -----> then properties -----> tools
and see if your scan disc feature is enabled.
If it is then when your computer restarts, it will do an automatic hard disk check.
Step 3: HKEY_LOCAL_MACHINE\SYSTEM\CURRENTCONTROLSET\
CONTROL\Session Manager
The default value is BootExecute:REG_MULTI_SZ:autocheck autochk *
NOTE: You mey want to try step 2 first and not try step 3 with proper guidence as a simple mistake can corrupt your OS. I mentioned this as part of knowledge sharing.
Nov 18, 2010 | Computers & Internet
How do I disable DHCP server of the wrt160n so my d-link router is the main router?
you need to open a browser and enter the numbers 192.168.0.1 in the address bar. it will ask for a user name and password. the default user name and password is "admin". if you have entered a different password while setting up the wireless connectivity, please use that password. once you entered the credentials, you can disable the DHCP server in the setup page of the linksys router. i have attached a screen shot for your reference. if you have any difficulties in doing this process, please reply to this message. hope it helps you. glvenu.jpg
Nov 04, 2010 | Linksys WRT160N Wireless Router
How do I adjust my DMZ and NAT settings without the setup disc?
PS3 And XBOX :: BELKIN
Step 1:Connect Modem - Router - Computer (Wired)
Step 2:Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3:On the Left click firewall
Step 4:Leave the Password blank and click submit
Step 5:Disable it and click apply changes
Step 6:Scan and connect in the Xbox/PS3/Wii
Step 7: Get the IP Address of the Xbox/PS3/Wii
Step 8:Open Router Setup in the Computer
Step 9:On the left under Firewall Click DMZ
Step 10:Enable the IP Address of the Xbox/PS3/Wii in it
Step 11:Click Apply Changes
Step 13:On the left Under Utilities click System settings
Step 14:Scroll down to the bottom
Step 15:Enable UPnP
Step 16:Click apply changes
Step 17:Test the connection ,Check the NAT
If working then let me know
If it is still not working
Open Router setup
At the middle Under internet settings check the WAN IP
IF it starts with 192.168. or 172.16 Then you will have to contact your internet service and ask them to bridge the modem
Oct 24, 2010 | Belkin My Essential (ME1004-R) Wireless...
I have a linksys wusb54gsc ver 2 wireless network adapter
Thank you for posting your question.
You will be able to re-install the software without the disc, all you have to do is download the driver software by following the steps below.
Step 1. Go the Linksys website.
Step 2. Hover over the Support tab and click on Linksys.
Step 3. Type in WUSB54GSC in the product field.
Step 4. Click on the first entry that is presented and this will take you to the product page.
Step 5. Click on the Downloads tab
Step 6. Select your Version, which is Ver 2 and you will be presented with options.
Step 7. Click on the Driver Download option which will allow you to download the driver program as a zip file.
Step 8. After the file is downloaded, right click and extract the files.
Step 9. Open up the extracted files folder and double-click on the Setup.exe file to start the Setup Wizard.
That is how you can re-install without access to the disc. If you need assistance with walking through the actual setup, feel free to ask another question.
Apr 29, 2010 | Linksys WUSB54GSC Compact Wireless-G USB...
Change NAT type from strick to open FOR XBOX
1)NAT STRICT
Step 10:Enable the IP Address of the Xbox in it
Step 15:Enable UPnP
Goto : my blog for more information about belkin routers (Page is still under construction )
Open Router setup
Apr 24, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Step 11 and 12...
Hii , Some time what happens we are not able to install the router using the setup disk .So in that case we have another option to install the router...
For Cable Internet connections :--
http://linksys.custhelp.com/cgi-bin/linksys.cfg/php/enduser/std_adp.php?p_faqid=3686
For DSL 9Phoneline) Internet connections:-
http://linksys.custhelp.com/cgi-bin/linksys.cfg/php/enduser/std_adp.php?p_faqid=3687
If you find this information helpful . Pease rate information
May 31, 2009 | Linksys WRT54GX2 Wireless-G Broadband...
Remove Vista OS and Replace With XP Pro
1. make sure your laptop is set to startup from a cd
2. after laptop finds the bootinfo from the cd and asks you to press any key to start from cd, press any key and xp setup will start.
3. in xp setup your going to need to delete your vista partitions, preferably all partitions and then proseed to install xp into a new partition.
4. proseed with the windows setup follow the instructions and configure your settings as you wish.
Mar 17, 2008 | Acer Aspire 5100 Notebook
Linksys WRT54GX2 Wireless-G Broadband Router with SRX200 (LS-WRT54G2) Logo
360 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
