Question about Sony PlayStation Portable (PSP) Slim (PSP-2000) Console
Memory stick does not work
The memory light is blinking like trying to load data but nothing happened, I have tried to format the memory stick several times but Psp doesn't recognized it.
thanks when i first put my new memory stick i was playing vice city stories then i never quit the game so i went and save my game and i first show memorycard is not accessable then i came of the game and see if i will see the memory stick is showing up on the psp then it showed me go to system settings and format memorycard then i went and farmated it it showed up format failed(8022008b).
  • 32 Answers
Connect the memory stick to your PC and format there. If it still fails, it's highly likely that your memory stick needs replacement
Posted on May 17, 2009
All the games of our psp were lost when my son happened to press the format memory stick section and pressed yes
Try this best file recovery called asoftech data recovery.It is a comprehensive data recovery program that support deleted recovery, formatted recovery, partition recovery and Raw recovery.You can use this file recovery to get your files back easily! Here is the link
http://www.asoftech.com/data-recovery-software-download.html
Mar 17, 2011 | Sony PlayStation Portable (PSP) Slim...
Says error on formatting memory card.
The camera may display a FORMAT ERROR if the inserted media is not formatted or if the media was formatted on a computer. This error may also display if the inserted media is not supported by the camera.
Try to remove and re-insert the Memory Stick media several times.
Make sure that the inserted Memory Stick media is compatible with the camera. DSCW310 Camera is compatible with the Memory Stick Pro Duo upto 32 GB.
You may also try formatting the Memory Stick media to resolve the issue. Format the Memory Stick media using the FORMAT option in the camera menu.
Formatting will erase all stored data, images, movies, etc., from the Memory Stick media. FORMAT option is available in the Memory Card Tool Menu of the Camera which is in the Settings Menu. Please back up the data by inserting the Memory Stick in the Computer Memory Card slot.
This may also happen if the terminals on the Memory Stick media are dirty. Remove the Memory Stick media from the camera and use a soft dry cloth or pencil eraser to clean the contacts. Make sure there are no residual particles on the Memory Stick media before re-inserting it into the camera.
The data on the Memory Stick media or the Memory Stick media itself is damaged. Try using a different Memory Stick media in the camera.
This should resolve the issue. If the error continues to display, the media may need to be replaced or the camera may require service.
Jan 23, 2011 | Sony Cybershot DSCW310 Digital Camera
Lost data from samsung memory pen
Hello, sorry to hear of your memory stick problem, I take it that you have used this one lots of times before yes? if not and it was indeed a new one it should have had a format done on it before use.
If it was not formatted the pics you put on it will be lost I am sad to say.
May 24, 2010 | Samsung SC-D23 Mini DV Digital Camcorder
Getting an error code c:13:01 on my sony t900 camera
“Memory Stick Duo” is unformatted.
“Memory Stick Duo” is broken.
“Memory Stick Duo” type error
The camera cannot read or write data
on the “Memory Stick Duo”.
Format the “Memory Stick Duo”.
Replace a new “Memory Stick Duo”.
Insert a supported “Memory Stick Duo”.
All above are solution for your quiry
Jan 21, 2010 | Sony Cyber-shot DSC-T900 Digital Camera
Bootin problem
This could be a number of issues. What you are referring to is known as failing to post. The culprit behind this error is most likely motherboard or memory. If you have 2 sticks of memory, try taking one out. If nothing swap memory again. Still nothing, have motherboard looked at.
Aug 29, 2009 | HP Compaq nc6220 Notebook
I GOT THE PROBLEM IN MY CAMERA FORMAT ERROR C:13:01 MODEL DSC-P31 THE PROBLEM CREATED WHEN I TRYIED TO DOWNLOAD PICTURE
The Error message C:13:XX indicates that the Camera cannot read or write data on the Memory Stick or an unformatted Memory Stick is inserted in the Camera or the inserted Memory Stick cannot be used with your Camera or the data is damaged.
1. Try reinserting the Memory Stick several times.
2. Format the Memory Stick in the Camera.
*Formatting a Memory Stick will delete all the data saved in the Memory Stick.
Insert the Memory Stick in the Camera, Turn ON the Camera. Press MENU -> Memory Stick Tool -> Format -> OK.
Memory Stick compatibility information for you Camera:
http://esupport.sony.com/perl/support-info.pl?&info_id=12&mdl=DSCP43
3. Try with different Memory Stick.
Good Luck!!!!!!!!!!!!!!!!!!!!
Aug 28, 2009 | Sony Cyber-Shot DSC-P43 Digital Camera
Psp wont boot up with pandora battery
u should probly get a hack data on the memory stick and insert the memory stick with the battery make sure that only the hack data is on the memory stick
Jul 17, 2009 | Sony PlayStation Portable (PSP) Console
Use a Card reader to format your Memory stick and then put it back to your PSP and again format. Some times the PSP wont recognise memory stick and contents in it.
Jul 26, 2008 | Sony PlayStation Portable (PSP) Console
Power does not come on. Light below memory stick slot blinks. Battery is not problem. Nothing else but that light will come on. The camera will not come on. I have tried various batteries and even the
Your laptap MS card reader might not be properly installed. It might have been uninstalled or corrupted, which can always happen. Try going to your control panel, device manager, then uninstall the device, and install it again. It shoudl work this time. Good luck.
Jun 20, 2008 | Sony Handycam DCR-SR200 Camcorder
Formatting
SOUNDS LIKE A ERROR IN MEMORY STICK .. TRY A NEW STICK THIS SHOULD FIX YOUR PROBLEM
Sep 30, 2007 | Samsung SC-D353 Mini DV Digital Camcorder
Sony PlayStation Portable (PSP) Slim (PSP-2000) Console Logo
538 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
