Question about Kitchen Appliances - Others
Need seal for Briel MPS Prestige espresso machine
I need a new o-ring seal for a Briel MPS Prestige. Its the one the filter handle tightens against
  • 37 Answers
You can get that at:
Electra-Craft
41 Woodbine St
Bergenfield NJ 07621
phone 201-439-1700
fax 201-439-1701
info@electra-craft.com
www.electra-craft.com
Posted on Jan 14, 2010
Where do I find the schematics/drawing of internal parts for Briel Cadiz Espresso maker
I just bought a new Briel Cadiz and it doesn't make crema. I tried my old Briel crema filter and it works fine making good cream. I was told to untighten the screw in the new crema filter but the screw just goes round and round, even with an electric drill. Can't tighten it or loosen it. Anyone got any suggestions?
Feb 04, 2011 | Briel Cadiz ES-62ABPG Espresso Machine
Briel ES 200 AP machine no water for coffee but yes for steam
This post is REALLY old, so you probably already fixed or discarded your machine. But for others with similar problem....
You may have a blocked top filter screen. If the machine is not cleaned regularly this screen can become so dirty and clogged that the water cannot get through.
Easy way to tell is run a shot without the portafilter basket in place. Water should flow out of the top screen. If you see it spurting out in small streams it needs to be cleaned.
On the ES200AP MPS machines you simply need to remove the screw in the middle of the screen, clean well, then replace.
Dec 29, 2009 | Briel Coffee Makers & Espresso Machines
Water forced out around seal when making espresso.
1- Try cleaning the seal with a group brush if you do not have one you can get a hard toothbrush this will clean the coffee grounds on the seal, if the problem still occurs then the seal needs to be replaced.
Apr 26, 2009 | Briel Multi-Pro ES-200A Espresso Machine
Briel Versatile Due Coffee Machine
You can get it at the Briel service/distribution center at:
Electra-Craft
41 Woodbine St
phone 201-439-1700
fax 201-439-1701
Sep 05, 2008 | Briel Domus Due Espresso Machine & Coffee...
Briel filter
You can get any Briel part you need at:
Electra-Craft
41 Woodbine St
phone 201-439-1700
fax 201-439-1701
Jun 29, 2008 | Briel Chamonix ES-35 Espresso Machine
Need to find replacement parts for Briel Chamonix
HI,
You can order any Briel part you need at:
Electra-Craft
41 Woodbine St
phone 201-439-1700
thank you.
May 05, 2008 | Briel Chamonix ES-35 Espresso Machine
Breville ESP8XL Espresso Machine Cafe Roma leaking.. help please..
We had that happen and it was a crack in the black ring that holds the filter. Breville could not supply us with one but we found an OEM part in aluminum from http://www.vancouverwireedm.com/caferomadiyt.htm. We received it 1 week after ordering. It was pretty easy to replace. Our machine works fine now.
Mar 06, 2008 | Breville ESP8XL Espresso Machine
Breville Die Cast 800ESXL
BrevilleUSA.com has a silicon seal (steam ring) to replace faulty or worn ones. There is no shipping charge, and they are $4 each. To replace the steam ring you'll need to remove the stainless spray disk on the brew head with a phillips screwdriver (one screw) and pull off the old ring (pay attention to the direction and placement of the stainless disk).  Takes about 2 minutes to do.
Part # .800ESXL/192
Also, on mine I noticed that the filter holder was ground down at the factory a bit too much on one side, which causes a slight leak down one side (coffee, not water).  You might check the holder (with the filter removed) for imperfections that could lead to your leak. Good luck.
Feb 17, 2008 | Breville Die Cast 800ESXL Espresso Machine
Espresso Machine
Possibly, if it is leaking from the bottom only, and if you have a Domus Due model, you might just need a new water reservoir as the water reservoirs are a different system than all of the other briel machines and a new reservoir will usually fix the problem of leaking on the bottom in the Domus Due machines. Something with the seal on the reservoir.
You can order just a water reservoir by contacting the service center at:
Electra-Craft
41 Woodbine St
ph 201-439-1700
If your machine is leaking over the filter handle, brew head etc, that could be the coffee oils have built up in the Brew Head Screen and/or filter basket itself. For that, remove the Brew Head Screen and soak along with the Filter Basket in a coffee oil remover (not descaler) you can get the Cafiza powder at www.urnex.com or any other brand and then use a brush to clean it after soaking. If you have the Briel filter basket with a screw in the middle, please remove the screw and clean in there as it tends to get clogged. Then just be sure not to screw it too tight again as this can cause leaking.
I hope the info was helpful.
Apr 16, 2007 | Briel Domus Due Espresso Machine & Coffee...
Kitchen Appliances - Others Logo
69 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
