SanDisk 4GB microSDHC Memory Card Logo
Posted on May 17, 2009
I can not fint memory card in my PC - SanDisk 4GB microSDHC Memory Card
Anonymous
Level 1:
Problem Solver:
  • Contributor 14 Answers
  • Posted on May 19, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
14
Questions
0
Helped
5845
Points
20
If you have a microSD card, and a miniSD Card slot, you'll need a SD card adapter that the microSD card can fit into, and is the size of a miniSD card. SanDisk makes them.
tip
Memory card corrupted??
hey guys if u get "Memory card corrupted" message in your mobile..relax.. . U get this message because u have formated ur memory card in ur pc and loaded it in your mobile.. My advice is not to format ur memory card in pc unless ur memory card if affected by virus.. so the solution is
*backup all ur data..
*format ur memory card in ur mobile
*connect to pc and load ur contents(images,music,data etc)
Thats it..your memory card is not corrupted anymore..!! cheers :)
on Apr 14, 2010 • Cell Phones
1helpful
2answers
Cannot transfer videos from pc directly to external memory, samsung star
To transfer pictures (via a memory card) to a PC requires a microSD Memory Card, Memory Card Adaptor & Memory Card Reader. The microSD memory card MUST first be formatted, by the phone, in order for the phone to create the destination folders. Please note that the minimum size limit for the microSD memory card is 32MB.
This phone will support the use of a microSDHC 16GB capacity memory card. However, for optimal performance Samsung recommends using a card no larger than 2GB.
To learn how to format the microSD memory card, using the phone,The plug-in microSD memory card and its contents can be easily damaged by scratches or bending. Use caution when inserting or removing the card and keep all memory cards out of reach of children.
Warning: Formatting a memory card will permanently delete all current content.
To format a microSD memory card follow the steps below:
  1. Insert a microSD memory card into the memory card slot, located under the battery cover
  2. From the standby screen, press Menu
  3. Press Settings
  4. Scroll down then press Memory Management
  5. Press Memory Card Details
  6. Press Format
  7. Press Yes to confirm formatting the microSD Memory Card
Caution!: Do not repeatedly format a Memory Card as this shortens it's service lifeWARNING: Formatting the microSD Memory Card will permanently erase all data
To transfer pictures (via a memory card), from the phone, to a PC follow the steps below:
  1. Insert the formatted microSD memory card into the memory card slot, located under the battery cover
    1. When correctly inserted, the memory card icon microsd2.gif is displayed
      1. From the standby screen, press Menu
      2. Press My Stuff
      3. Press Pictures or Videos to view the contents
      4. Press Manage
      5. Press either Move or Copy
      6. Press each image to check their box or press All to check All boxes
      7. Press either Move or Copy
      8. Press Memory Card
      9. Press either Pictures or Videos
      10. Press Paste Here to Move or Copy the Photo(s)/Video(s) to the microSD memory card
      11. Remove the microSD memory card from the memory card slot
      12. Insert the microSD memory card into the memory card adaptor
      13. Insert the memory card adaptor into the memory card reader
      14. Insert the memory card reader into the USB slot on the PC
      15. Navigate to the desired Photo/Video destination location, using Windows Explorer, then paste the Photo(s)/Video(s) into the destination on the PC
Regards.
1helpful
3answers
My Sandisk memory card is not read in any mobile or pc.
hi my dear friend
SORRY my friend your memory card is now corrupted WITH mallware virus
OK
WHERE DO I FINT SERIAL NUMBER FOR DOWNLOAD MANAGER
There is a serial number at the rear of your desktop.
1helpful
Fint driver
download your drivers at Nvidia, choose your model and OS and download. http://www.nvidia.co.uk/Download/index.aspx?lang=en-uk
I need to copy the contact list from Samsung phone memory to the
you need a third party program to do this, look for the application like pim back up, contacts backup and download it from your phone to install, run the program and back up the contacts. but you need to install this program to both phones.
hence if you cannot find one, use your sim card's utility. copy the contacts to your sim, insert it to your blackberry and copy the contacts from your sim to your blackberry.
i am afraid there is still no way you can back up your contact list in your samsung phone to your memory card. even if you use your samsung studio or samsung pc suite, there is no possible way to copy the save phonebook contacts to your blackberry, they have different file extensions. you can save your samsung contacts as npf, csv, or vcard extensions. you can save your contacts to your memory card as csv or vcard, but i just don't know if blackberry has the capability to browse and save the contacts in this file extension from your memory card.
so the only possible way is to back it up using your studio as vcard, and since blackberry can sync to outlook, you can sync your phone book contacts from outlook to your blackberry..
take care..
7helpful
Blue screen arrives ...system not working
At bootup press F9 to restore to factory condition
Looking for a part
Get a blank card, put it in your gps device, connecct to your computer, go to their website and download the maps you need. Mine stores everything inside itself. You might not even need the card. Just load the maps into the gps.
Top SanDisk Computers & Internet Experts
k24674
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
