Question about Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker
After cleaning, thawing, I have another small problem. The funnel that collects the water into the pipe inside of the fridge, leaks from around the ring. What si the best selant i can apply? Can someone sent the answet o nav_jewel@yahoo.com
    Scholar:
  • 152 Answers
The best sealant to use is BOSTIK or MASTIK ( i'm not shouting it ok just stopping the spellchecker) Both these products will seal the leak and will allow you to break the seal if you ever need to take it out again, don't use silicon because once it cures in there, you will have a cow of a time getting it out and probably hurt yourself or even break the drain and then you will be really pissed, if you can't find either one of these products, check with your local hardware and ask for a sealer that don't set but seals unless disturbed.
Good luck
Posted on May 17, 2009
Water is leaking from front part still making ice we checked water connection part no leaking from there.
Unplug the fridge first step, loosen the leveling screws in the front by turning them counterclock wise, slide out the fridge & remove the panel from the back ( 1/4" Hex Head screw extractor for an electric drill - small one - ) the panel on most is at the bottom. Be sure to save all screws for replacement !
Using a Vacuum sweeper, clean all of the dust & dirt from all the coils ( VERY CAREFULLY ) there is also a small fan with plastic blades that should be cleaned off with the vacuum first, then use Windex or similar cleaner & wipe them off ( VERY CAREFULLY ) these blades will break very easy. Now plug in the fridge ( be sure all cleaning tools & rags are out first before plugging in the fridge ) check to see if the fan is turning very fast. If all looks good be sure to check the small drip pan that catches the condensation or other water dripping from above. there may be a small funnel that catches the water & directs it to the small pan, it may be loose & slipped into the pan. FIX IT, with what ever you can. I used Tie-Raps on mine to secure the funnel to the copper pipe running through the small catch pan.
GOOD LUCK- Don't forget to replace the pan on the back of the fridge, don't overtighten the small screws, they will strip out easely.
Feb 01, 2018 | Refrigerators
Hi there, have a Hisense fridge model hr6tff526(s) which is leaking water from the inside,looks like its coming from the top where the fan is located.thx
Hi Kassem
It's probably just condensation water like what you get under an air conditioned car in the summer.
Usually in a Fridge they collect the condensed water and run it down a clear hose pipe to a plastic container at the bottom rear of a fridge.
This pipe can become blocked with food & junk & mould, mice etc.
Find one end and clear the obstruction. A flexible rod or wire or air burst.
Cheers
Example Repairs:
DIY troubleshooting and repair for RV refrigerator condensation drain tube...
How To Clean Air Conditioner Drain Water in Drain Pan
Fridge Leaking Inside Refrigerator Drips From Ceiling Defrost Clogged...
Sep 14, 2016 | Refrigerators
RF261BEAESP
Check the pipe that drains the water from the avaperator (the thing that gets cold inside on the fridge)
periodically your fridge will defrost and the water should drip through a tube and collect at the rear of the fridge
If the pipe is blocked the water collects inside at the bottom ( under the crisper)
Apr 15, 2014 | Samsung RF261BEAESP 25.5 cu. ft. French...
Water is leaking into the fridge from the freezer.It is a top freezer with ice maker
It's likely due to a problem in the defrost drain or a leak in the ice maker. You may be able to solve such problems quite quickly, possibly in just a few steps. Have the owner's manual available to help you find
Some models have a selector switch to allow for a manual defrost cycle. If your freezer has this setting (check your owner's manual), ensure that the switch wasn't set to defrost accidentally. If the freezer was in a defrost cycle, check it in about an hour to ensure it is working.
When the defrost system kicks in, frost buildup on the evaporator coils melts and water is collected in a trough beneath it-more than usual. It is funneled through a defrost drain tube or channel down the back of your refrigerator and collected in a drain pan, where it is then left to evaporate.
Often, the defrost cycle turns off before the water can finish draining, and the refrigerator continues to cool. Ice buildup then forms along the system, and eventually water collects and puddles in the bottom of the refrigerator as melted ice continues to drip from the evaporator coils.
If there is ice buildup, allow the unit to thaw:
1. Remove food from the entire unit, storing it in coolers packed with ice, and remove the freezer shelves. Unplug the unit.
2. Using a screwdriver, remove the panel inside the freezer at the back to access the evaporator coils and trough.
3. Leave open the doors and allow the ice in the trough and along the defrost drain system to thaw by itself. This should take several hours. Note: Keep plenty of towels around and be prepared for the drain pan to fill quickly.
4. When thawing is complete, replace the panel and restore power to the unit. When it is cooling again, replace the food.
For more troubleshooting steps and simple solutions, read Freezer leaking water. I hope this helps!
Sep 28, 2012 | Westinghouse 5303281154 Fridgedaire/wci...
Water is leaking into my fridge from defrost.
Most times this is a plugged defrost drain system. The defrost heater in the freezer section melts the frost and changes it to water, this water is suppose to flow down a drain system. If this drain system is restricted or plugged the water will leak inside the refrigerator. The drain system starts in the freezer section with a tray built under the evaporator coil. The water is funneled through a small hose into a cup in the top middle of the fresh food section ( not on all models, but this is the most common way ), from there, the water is directed out the back wall to a drain hose that runs down the back of the refrigerator into a condensing tray. The heat created under the fridge makes the water evaporate and disappear. Some of the cups ( in the top back of the fresh food section ) can be removed for cleaning. A turkey baster can be used to help clean out the drain system. Fill the baster with hot water and "blast" it into the drain hose to help flush it out. A piece of wire or pipe cleaner can also be pushed into the drain hoses to help clean then out. On a S x S style of fridge the drain system is in the bottom back of the freezer section and often you will have to remove the evaporator cover to access the drain hole. You can clean this out in the same manner as previously mentioned, but because of the water leaking into the freezer instead of the fresh food section you will have to remove the ice build up to clean out the drain system.
If in case the water is leaking on the floor then:--
There are several things to check for. The condensing defrost tray under the fridge can crack or develop a hole and leak onto the floor. A door gasket not closing properly may cause sweating and leak onto the floor. If your fridge has developed a frost free failure problem, often the frost will travel down the suction line at the back of the fridge and drip water on the floor. The heat exchanger tubing can separate and also sweat and drip on the floor. Ice maker and chilled water fill lines can crack and leak as well, this is fairly common with the plastic lines as they can dry out and crack.
Unplug the unit from main power outlet and empty whole unit and keep both the doors open and then connect the power after 24 hours and recheck.This procedure is called manual defrost reset.If this helps then its OK,but if this procedure not helping then its the faulty defrost unit and it needs to be replaced.
You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 30, 2010 | GE Refrigerators
Bottom of fridge collects water
Hello there:
I have written a few steps for you to follow and try ok?
  1. Manufacturers have different ways to dispose of the water created during automatic defrost cycles. The most common design routes the water down a rubber tube on the back of the fridge to a tray beneath. This tube often gets plugged with breadcrumbs, peas etc. and can generally easily be removed and cleaned.
  2. Make sure the end of the hose is sitting in the defrost tray.
  3. If your hose was not plugged and you have found water running down the back wall inside the fridge or a pool under the bottom crisper has formed. Check if there is a small funnel located on the back wall near the top inside the fridge. It can also get plugged; you can use a small wire and work it in and out of the hole.
  4. Some designs do run the water down the back wall and have a drain hole under the crisper, make sure it is not plugged.
I hope that this has been verry helpfull for you
best regards michael
Nov 06, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Collecting water at bottom of frig inside under drawers.
begin by removing the grill on the front at floor level. look under there and you will see the evaporation pan. next pull the fridge out from the wall so you can get behind it. there you will see the tube. to unclog it you will have to disconnect it at the top and force hot water into it using a turkey baster.
Aug 22, 2009 | Refrigerators
Freezer leaking on Kitchen Floor
the pipe which is located at the back of the fridge/ freezer may be blocked or hanging outside of the designated collection chamber designed for this purpose. Unplug from the mains and pull the appliance away from the wall so you can see and get to the back of it. At the back of it you will see a pipe coming out from the bottom of the cooling fins and will go down and the end of it will be sitting inside a shallow plastic collection unit - not covered but open. Itusually is sitting on top of the condenser unit. (this is a large sealed metal structure whic has pipes coming out of it and is the largest item in that area at the back bottom end of appliance). If there is some liquid in it then either move the pipe end into the dry area or emty it out. Sometimes there isnt a collection chamber but the pipe just drips onto the condenser and evaporates - usually on self defrosting certain brand named products but dont know much about that. Use a pipe cleaner to clear out the pipes from inside the fridge out toward the back using that pipe. the drainage hole is inside the fridge at the back and may have some sort of cover or plug in it. remove that and clean it and use the wire or pipe cleaner to shove doen the hold and clear the entrance and exit. Test pipe functionability by pouring a small ammount of water down the drain hole and see it coming out of the back via pipe. If still leaking make sure the vent areas in the back of fridge and freezr are not covered expecially in the self defrosting models. basically dont overload the fridge or freezer coz this causes blocked vents, difficulty derfosting on self defrosters, water builds up and gets out via the tube as it should, but more water than can be evaporated will cause puddles on the floor
Jul 03, 2009 | Zanussi ZX99 / 5 Bottom Freezer...
Frigidaire refrigerator leaking water inside refrigerator
There is a plastic panel inside the frigidaire looking at the underside of the freezer inside the refrigerator compartment which holds the thermostate dial and the light fixture. remove the four 1/4 in hex head screws holding the assembly. pull the panel toward the front. you will expose the drain hose connection you can let it dangle from the plug wires or remove the panel completely, I worked with mine in place. look at the back funnel shape drain. just in front of that see a rectangular styroform collar which should be snug fit to match the underside. clean and dry all. there is a divider between the two funnel compartments, mine was separated between the plastic and the styroform. I used kitchen and bath tub caulking to seal the gap. and a little around the rectangle shape that fits to the underside. plug the wire back in if disconnected. reassemble the panel. that may fix it. good luck.
May 25, 2008 | Refrigerators
Kelvinator fridge
The freezer defrosts every day. the puddle is from that. It is supposed to go into a pan at the bottom and evaporate. You need to look at the pan and determine if it has a hole or the drain hose is leaking somewhere.
Feb 09, 2008 | Kelvinator 12 cu. ft. / 340 liter Chest...
Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker Logo
66 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
