Question about MagLite Mag-Lite& Flashlight
Changing the batteries
I took the batteries out because the light was going dim and I dont remember the order that the batteries are supposed to go in.
    Scholar:
  • 152 Answers
Ok the batteries almost alway go in with the positive (+) in first on all the batteries and then the end cap and thats it,  the positive side of the battery is the end of the battery that has a bump in the middle , the flat side is the negative(-)
Hope this helps you,
Posted on May 17, 2009
98 v6 mustang gauge lights dim and gauges flicker?
sound like a poor ground connection to your battery or electrical system
Feb 04, 2013 | 1998 Ford Mustang
Battery volts goes up and down and dims the lights
go get ur battery check at a parts house like napa or autozone that what it sounds like to me
Jan 25, 2013 | 1999 Chevrolet Silverado 1500
2005 Dodge Caravan with Dead Battery. Replaced and new battery died. Took it in for service. Alternator checked out ok and Drain was within tolerance. Will still die if I let it sit for more than a...
Disconnect battery from vehicle overnight to check for internal battery drain.......just take one of the cables off.
If the battery is still up and starting the vehicle after being disconnected after a day or two......the drain IS in the vehicle and will have to be checked again.
Do it yourself.
Buy a cheap 12 volt test light.
Place it between the cable you removed before.
One end on the battery post and the other on the cable end.
Now....with the key off......
If the light glows brightly....you have TOO MUCH drain.
We want a dim glowing light.
The dim light is just the memory circuits in the electronics and OK.
With the doors closed....take out one fuse at a time until the light glows dim.......the fuse that dims the light is the problem circuit.
If no fuse dims the light...remove relays one at a time.
Remember....some fuses and relays could be in the engine compartment and under the dash.
If no relay dims the light disconnect ALL alternator wires.
Remember....anything that uses power will make the light glow ....keep those doors closed (we do not want interior light drain affecting the test ) and if you have a under hood light check it first by removing the bulb.
We do not want false readings.
Sep 22, 2009 | 2005 Dodge Caravan
The battery keeps going dead in my 03 z71, only thing out of place is i cannot shut off the headlights manually anymore,it's stuck in auto. Alternato is fine and so is the battery, drains iin about 7...
Well if lights are not staying on then you have a draw of power somewhere. Easy way to find out is volt meter. You take off negative cable and put one end of meter to battery post and other to wire dont let the wire touch post or anyother metal of vehicle. Then go through your fuse box and pull fuse's one at a time until you see voltage on meter drop. Meter should should a (-)negative voltage at start and get smaller when right fuse is pulled take notes and pull all one at a time and replace back in orginal spot. If you find one that really lowers the negative voltage draw on meter good chance you found where problem is. Id start by checking all interior lights first, including glovebox.
Sep 12, 2009 | 2003 GMC Sierra 1500
The wireing 2 my headlights and running lighs dont work properly the head lights bealy come on and my running lights jest dont work whats the problom and if u have the wiring code put it down plz
How's your battery? If you need to jump your car off, looks like your alternator is going out... it's not charging your battery or supplying power to work all the electricals (The dim lights are a give-away of this problem to me).
Alternators aren't a bear to replace on your model. Just remember to disconnect the battery before you start. Good luck!
Aug 26, 2009 | 1986 Dodge Ramcharger
Very dim interior lights
There may be a bad ground for the interior lights.
Mar 03, 2009 | 1998 Buick LeSabre
1987 F150 302 ci. EFI, Automatic, Was running good. Next morning NOTHING! Wouldn't start or crank over? Just clicking and buzzing, Headlights OKAY. Tried jump starting... NO GOOD. Took battery in... Was...
try over riding the starter relay on the fender ,it has one there right?. dont go to a mechanic yet. the engine aint seized. if it doesnt have this relay then i would get the alternator tested. if you want to test it yourself it can be costly for the right equip. autozone usually tests for free. i dont know were you live so if theres not an autozone. let me know if you cant get it tested.
Feb 22, 2009 | 1987 Ford F 150
Dell C640 LCD dims when on battery power
When you turn your laptop on press F2 to go to the system settings Continue to press alt+p till you get to a page about battery usage then turn everything up to max. hope this helps
Aug 14, 2007 | Dell Latitude C640 Notebook
Kenwood KAC 7502 Amp trouble
Exchange the amp it is going into Protect. But your sub may be causing this problem if it is shorted. Make sure your subs are wired to at least a 4 ohms. Only a shop can tell you for certain if your sub is shorted or not. But if you are smelling smoke then that amp is already toast.
Jun 26, 2007 | Kenwood KAC-7202 Car Audio Amplifier
MagLite Mag-Lite& Flashlight Logo
294 people viewed this question
Top MagLite Electrical Supplies Experts
ken skalski
Karl Kittsteiner
ray gallant
Are you a MagLite Electrical Supply Expert? Answer questions, earn points and help others
