Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
Transmission or clutch prob
92 FLHS tanny problem. Grinding noise when clutch lets out, not much forward motion. When shut off and pushing, makes clunking noise, acts same in gear or neutral.
For $9.95 I will tell you>
Posted on May 18, 2009
Toyota Rav 4. 2002 reg Makes a grinding noise when driven until clutch is pressed to floor the noise disappears
clutch ,slave ,throw out bearing going bad --transmission shaft bearing --bad gear --but would look into clutch since you have o push to floor to have noise stop
Oct 27, 2016 | Toyota Cars & Trucks
My 2002 Jeep cherokee is making a grinding noise when put in 4wd. What can be wrong?
if only into 4WD =transfer box failure or low on oil
if still there in forward 4X4 motion
could be clutch or gearbox driveshaft diff related
Oct 19, 2016 | Jeep Cars & Trucks
New tiller makes grinding noise when trying to run tillers
if it has a clutch
most small units just run a dog that you engage with a swift motion at low idle speed of the motor
have the tillers free above the dirt so they can turn with out any load to inhibit the dog engagement
May 20, 2015 | Garden
92 mightymax with manual transmission that has been I guess converted to cable since the 92 is supposed to have hydraulic I heard after I start it and press the clutch it's still not going to gear a...
down a spacewagon a few years back and it as it was a rear wheel drive it wasnt difficult too do ,now i suspect that the clutch plate is bent where someone didnt aligh the clutch properly with home made broom handle alignment tool ,given the gearboxa good yank or used to big long bolts to pull it in and damaged the plate .i could be wrong but if the operating arm is touching the clutch and it has the right distance for the arm to push it in then this is problem
Oct 26, 2014 | 1992 Mitsubishi Mighty Max
Car makes a metalic grinding noise when in neutral
You need a new throwout bearing in your clutch assembly.
Sep 10, 2009 | 1994 Pontiac Bonneville
NOISE WHEN LETTING OUT CLUTCH WHILE IN GEAR
Clutch plate springs brocken.Thats where your noise is comming from.The only solution is to change the clutch.Hope that was helpfull.
Jul 24, 2009 | 1993 Toyota 4Runner
Tranny problems
did you change the bearing in the flywheel the center one or throw out bearing that pushes out on to the presserplate
Jan 18, 2009 | 1992 Isuzu Rodeo
2003 toyota mr2 spyder 5 speed transmission grinding noise
Here is what is going on. When you push in the clutch pedal you remove the connection between the engine and the transmission. At this time all the parts in the transmission stop rotating.Since the only parts in the transmission that can rotate without moving the car are the input parts we can safely assume that the noise can only be from there.This can be a transmission input bearing. Worn Synchro mechanism (allows the transmission to shift without grinding the gears)Low fluid in the tranny. Or a bad clutch component. Top off or change the fluid. If it still makes the noise you need to take it to a tranny shop.
Nov 30, 2008 | 2002 Toyota MR2 Spyder
Lands Phones Logo
197 people viewed this question
Top Harley Davidson Lands Phones Experts
ted dux
WTF Chuck.....
WTF Chuck.....
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
