Question about Canon Cameras
I have a new Canon 1000D. Battery is fully charged but when I turn it on the screen does not light and when I depress the shutter all I see is the ISO number and 'Busy'
  • 432 Answers
Check the manuals and see if there is a way to do a full reset / restore on it - maybe remove the battery for a while and also check the memory card ( assuming it is a digital one ) to make sure the memory card is not locked and try it again.
If it still does not work then I would contact the place where you purchased it and take it back and they can either look at it in store or replace it.
Posted on May 17, 2009
I have err 99 any solution?
.1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the "ERR 99' message appear? If it does, then the camera should be
serviced. If it does not, then please proceed to the next set of steps:
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the "ERR 99' message appear? If so, then the CF card is the most
likely source of the issue. Try using a different card.
If the message does not appear, please complete the following steps:
2. Clean the lens contacts by gently rubbing them with a pencil eraser
or soft cloth. Be careful that you do not let any debris fall into the
camera body.
3. Reattach your lens.
4. Turn on the camera.
If the "ERR 99' message only appears when one particular lens is
attached, then that lens should be examined by a service technician.
If you see the "ERR 99' with a different Canon lens attached, then the
camera should be serviced.
Jun 08, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
Screen wont work and when you shoot it says its "Busy"
I can help you fix the BUSY Error or Error 99 of your Canon EOS Rebel XS.
Installation of this Canon EOS Rebel XS firmware version 1.06 update will solve these problems:
  1. Some cameras may exhibit a phenomenon in which the LCD monitor does not display, the shutter does not release, and the BUSY indication remains lit in the viewfinder.
  2. The message, "Err 99 Shooting is not possible. Turn the power switch to<OFF> and <ON> again or re-install the battery", appears on the camera's LCD monitor, and after the above operation is carried out,the LCD monitor displays in a language that is different from the actual language setting.
See the firmware instructions and download the firmware upgrade by following these Fixya Tips :
  1. Follow this link to download a pdf version of the firmware installation instruction guide.
  2. Follow this link to download the Windows Version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  3. Follow this link to download the MAC version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  4. Follow this link to download the Canon EOS Rebel XS / Canon EOS 1000D Instruction Manual.
I hope that helps.
Jan 21, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
Canon 100 d screen is blank seems to be frozen when trying to take a pitcure flash will pop but will get busy sign battery fully charged
I can help you fix the BUSY Error or Error 99 of your Canon EOS Rebel XS / Canon EOS 1000D.
Installation of this Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update will solve these problems:
I hope that helps.
Oct 10, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
Canon Rebel XT wont fully come on
Hi
Error 99 is usually a lense error and gives the only real clue as to what is going on with your camera. You can try this simple fix which comes straight from Canon. Follow the steps to help isolate the issue. Note the fact that you are currently not getting the Error 99 is probably a good sign according to the troubleshoot.
To isolate the cause of the issue, we suggest that you do the following:
Does the “ERR 99′ message appear? If it does, then the camera should be serviced. If it does not, then please proceed to the next set of steps:
Does the “ERR 99′ message appear? If so, then the CF card is the most likely source of the issue. Try using a different card.
camera body.
If the “ERR 99′ message only appears when one particular lens is
If you see the “ERR 99′ with a different Canon lens attached, then the
Hope this helps. Please do rate my answer. Thanks.
Aug 09, 2009 | Canon Rebel XT / EOS 350D Digital Camera
My 9 month old camera will power up, focus and flash however it will not take the picture. When looking through the view finder, "busy" flashes when trying to take the picture. The battery is fully charged...
I hope that helps.
Jul 31, 2009 | Canon EOS Rebel XS 35mm SLR Camera
Err 99in my canon 1000D
camera body.
Jul 18, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
Camera turns off when pressing shutter button
Sounds like a compatability problem. If available, try a genuine Canon battery new and fully charged.
Jun 09, 2009 | Canon EOS 40D Digital Camera
Codee error 99 ??
hi,
I do not know if this is going to be of any help. I was actually reading about this error code 99 in canon, and bumped into a forum, where people had share their experiences. You can give it a try. But if your camera is still under warranty, it is best to ring technical support.
"ERR 99" is a general error code displayed by the camera when the camera knows that something is not working properly, but not exactly what.
This error is typically associated with lens communication or shutter mechanism issues. To isolate the cause of the issue, we suggest that
Does the "ERR 99" message appear? If it does, then the camera should be serviced. If it does not, then please proceed to the next set of steps:
Does the "ERR 99" message appear? If so, then the CF card is the most likely source of the issue. Try using a different card.
2. Clean the lens contacts by gently rubbing them with a pencil eraser or soft cloth. Be careful that you do not let any debris fall into the
camera body.
If the "ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the "ERR 99" with a different Canon lens attached, then the
Hope this helps !!!
Apr 17, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
Keep getting ERR99 when i take my first shot after switching on.
ERR99 means the camera is not communicating with the lens - probably just dirty contacts.
To isolate the cause of the issue, do the following: -
4. Insert only a fully charged battery, and turn on the camera.
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
If the “ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
Jan 23, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
Cameras Logo
37 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
