Question about Acer Aspire 1703SC Notebook
ACER APIRE 1700 FAN ALWAYS RUNNING
Hi. I have an Acer Aspire 1700 (1703SC to be exact). The fan is running on maximum all the time. Can anyone explain why this is and how to fix it? Thanks
  • Acer Master
  • 32,281 Answers
You could have dust blocking the heatsink fins and or the fan.
Loosen the dust etc. clean and vacuum the dust off.
Did you overclock your system? If so you need to restore it back to the original settings.
Posted on May 17, 2009
Acer aspire overheating fix
What model of acer apire ?
When a laptop gets hot physically hot, to the touch you know something isn\'t quite right. It\'s normal for a computer to get a bit warm as it runs, which is why computers have a built-in cooling fan in addition to a heatsink and cooling vents. Excessive heat, however, is almost always an indication that something is malfunctioning. This is no different with the Acer Aspire 5000.
What\'s Happened If you\'ve ever looked inside of a computer or seen an "exploded view" of a laptop, you will know that thousands of components work together to ensure your computer\'s best performance. The cooling fan is activated by temperature readings from the central processing unit, which heats up and cools down depending on what it is being used for. Sitting idle, the temperature of the CPU will be low and the fan won\'t come on. When the computer is performing a few tasks simultaneously, the CPU is taxed and the fan kicks in. When you hear the fan whirling excessively, the computer is overheating which can damage the CPU. Thermal compound is a sticky paste that is placed directly onto the CPU. http://www.hardwaresecrets.com/article/Thermal-Compound-Roundup-February-2012/1490 Allowing for a more direct heat transfer between the CPU and HEAT SINK and preventing air gaps from forming between the CPU and heat sink. b> Checking Temperatures You can download programs to monitor the core temperature of your CPU. Programs like Core Temp, Speed Fan or Motherboard Monitor use the hardware monitoring devices built into your Aspire notebook to track its core temperature. Different sources suggest that the Aspire 5000 can run at a different maximum temperatures. Users on Tech Support Forum say 50 to 60 degrees Celsius is normal even optimal and that above 75 degrees is a problem. Acer\'s technical manual for the Aspire talks about external temperatures for running the computer efficiently (between minus 20 and 30 degrees), but it says nothing of internal temperatures. A few different users reported overheating to the point of 90 degrees, at which point the computer freezes and shuts off. Warranty Fix Computer original equipment manufacturers like Acer sell every computer with a limited warranty. Overheating is usually covered by this warranty. If your computer is repeatedly reaching high temperatures, and you\'ve recorded the temperatures with software, contact Acer for a replacement or a repair. Out-of-Warranty Fix The simplest way to address an overheating problem is to let the computer breathe a little. Make sure that you use it on a flat, hard surface so that air can pass to the fan easily and without interruption. You can buy laptop cooling pads at most computer stores that are designed with this in mind. As a complex fix for an out-of-warranty system, you can follow a picture tutorial from MPS Computers to replace the sealant around the heatsink with a new glue called Arctic MX-2. This glue allows more heat to escape and brings the core temperatures down about 10 degrees. Acer Aspire Overheating issues http://www.techsupportforum.com/forums/f108/acer-aspire-overheating-issues-214199.html 257 software downloads results for "temperature"
b> Acer Support - ASP Login http://support.acer.com/acerpanam/manuals/acer/0000/servicemanuals/S.G_AS3000_3500_5000_BOOK.pdf
Feb 26, 2013 | Acer Aspire Computers & Internet
I want to install a pci sound card in my acer aspire 1700. Is this possible
Yes you can. You should two expansion slots in that machine that take PCI express cards. I looked on my favorite website, newegg, and found a sound card that should work well in your machine.
http://www.newegg.com/Product/Product.aspx?Item=N82E16829132006
Dec 30, 2010 | Acer Aspire 1700 1702 1702SC 1703 1703ESC...
Hi, my Acer 772g, has some overheat problems, specially while gaming. Fan is clean, drivers up to date, i have a cooling pad and all that. I felt that sometimes the Fan just shuts down at certain temps, (i...
restart your system press DEL and enter the bios you will see hardware monitor in the cpu fan click enable this will keep your fan working when you start you system
Nov 29, 2010 | Acer Aspire 7720 Notebook
Acer Aspire X1301 is excessively loud, runs one speed always.
Are all the vents clear from obstructions, fluff etc?
Jan 15, 2010 | Acer Aspire T135 PC Desktop
Acer aspire 5000 unexpected shutdowns, random, fan running.
Hello
Thank you for using FixYa.
Have you cleaned out the airvents and fan area. these build up with dust and if the unit gets too hot it will shut down unexpected
Also always use on a hard surface so the airvents are kept clear
thanks
Richard
Nov 17, 2009 | Acer Aspire 5100-3357 Notebook
Unit Always Shuts Down While In Use
all the laptops on the world have warm problem. if you use your notebook dirty place your fan could get dirty and not working well and not makes cool anymore. in warm system can shut down itself. it is often does. if you open your laptop back case you will see the fan. there are olny 4 screw. clean the fan and screw again. try it.
sorry for my enghlish.
May 17, 2009 | Acer Aspire 7720 Notebook
Cuts off unexpectively
In the control panel, there is an icon for power settings. Set the fan for maximum cooling. Make sure the exhaust ports on the computer are blown out. Don't use the computer on a soft surface.
Feb 20, 2009 | Acer Aspire 9410 Notebook
Acer Aspire One shuts off
Mine did the same thing -- noticed the fan wasn't running at all during bootup when the shutdown problem was occurring. Tapping the bottom ofthe case near the fan got the fan running and it booted fine after that. It happened twice in about a year's time and both times this fix worked. I'll probably take it apart soon and clean out the fan.
Jan 14, 2009 | Acer Aspire One Netbook 8.9" Notebook
Over Heating Problem In Acer Aspire L100
There are two solutions to this problem. First set the fan in the PC Bios to rub at full speed all the time. This was too noisy for me.
Second, If you are running Windows Vista, you can adjust the Maximum Porcessor Utilization. From the Windows Control Panel select the Power Options icon. Then select "Change plan settings" for which ever power plan the PC is set to use. Then select "Change advanced power settings". Expand the "Processor power managment" by clicking on the "+" symbol. Finally click on the "+" for "Maximum processor state". I would try changing this setting to "90 %". This worked fine on my ACER L100 and it no longer overheats.
Jun 08, 2008 | AcerPower F1 PC Desktop
Acer Aspire 1703SC Notebook Logo
267 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
