Dehumidifiers
Problem for Dehumidifiers
Generic problem for all Dehumidifiers
Humidifier in basement freezes up after sev...
By n437 on May 17, 2009
Humidifier in basement freezes up after several hours, ie coils are one big ice block.
I have put it on a timer with 4 hours on 4 hours off. Seems to work OK.
What causes this problem and is there a way to fix the unit itself?
Comments:
May 17, 2009
- Thanks for the replys.
I already checked and the unit is not clogged, it's actually pretty clean whoch was a surprise.
I originally suspected the basement was too cold, it's usually about 60 (+/- 5), but no one expersseed that as a concern.
Assuming it is low refrigerant, I have some R12 (from by-gone days and gagues. Do these units R12 and what would be the upper and lower pressures to charge to?
Best Solution
posted on May 17, 2009
Very Helpful)
roadrunning1
Rank: Guru
Rating: 91%, 42 votes
Hi there, Yes this problem has been asked before by other users, Firstly, there are several things to look for be you go crazy calling in a technician,
1. check the systems coils and make sure that they are not blocked with either , dirt or dust preventing the air flow or make sure the condenser fan is operating ,if both these things are clear or operating when the compressor starts then the system could be under charged or leaking in which case a technician would be advisable unless you understand and or have the necessary tools to carry out  its repair. The only other thing that could be causing it is , if the humidi-thermostat is faulty and is causing to stay on too long (with could be why the system appears to work properly if you turn it off once and a while )
I hope this information helps you..
Also, Please remember if you feel like opening the machine up to check the can if its not running, make sure that the machine is totally un-plugged from the power supply to prevent any chance of electric shock , please be safe :)
Comments:
May 18, 2009
- Hi , Yes if thats 60 Dg Fahrenheit (15.5 C) it can be a problem cause of the lack of heat the humidifier will be over condensing which will cause that too , (wish you would of mentioned that ) , best thing is to ventilate the area or move the system,
Thanks
Roadrunning1
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
Helpful)
ASK HANK
Rank: Wiz  Air Conditioners  Expert
Rating: 85%, 129 votes
Problem could be caused by lack of air flow (dirty coils and/or filter) or by low refrigerant (not worth repairing).
Comments:
May 17, 2009
- The unit rating plate should list the type of refrigerant. No, it's probably not R12. It probably does not have access ports. The pressures will vary due to ambient, and refrigerant. It is probably not worth having it repaired especially since any repairs would probably be temporary at best. I think you've already found the best solution/fix.
Was this helpful?
Yes
No
Popular Solutions for Dehumidifiers
Questions and Unsolved Problems for Dehumidifiers
Answer
I am looking to purchase an everstar airconditioner/dehumidifier. I was looking to see the value if... (More)
Answer
small basement efficiency that is not occupied during cold months, and accumulates mold and paint... (More)
Answer
Humidity will not collect in bin, always dry when machine is left on for hours
Answer
water is not going into receptacle, going on floor. Yes, the receptacle is secure.
Answer
Do you stock replacement 5Ltr tanks for an Amcor TC120 ?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Dehumidifiers:
Top Dehumidifier Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Dehumidifier Experts
Top Air Conditioner Repair
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
