Question about Goldstar DH504EL Dehumidifier
Trips the circuit breaker on start up
The 2.5 year old dehumidifier trips the circuit breaker every time it starts up.  This has only recently started happening.
  • hummhumm May 20, 2008
    My dehumidifier trips the breaker. I reset the breaker and the same thing happens. I tried other outlets and It won't run. One outlet popped when I plugged it in. Is there any way to fix it?
  • Anonymous Jul 25, 2008
    Had the same problem and tried another circuit/outlet. One article talked about a "heat-sink" chip on the PC board as maybe over-heating, so I took the covers off and vaccumed. It has been running OK for 20 minutes now, where it used to trip in about a minute, but I still suspect there is a bigger issue such as the compressor..... (Mine is a Kenmore unit).
I would try to find an outlet on another circuit to see if maybe the problem is definately your dehumidifier, if it trips again then you know it is...If not then call an electrician..
Posted on Apr 27, 2008
Starting tripping circuit breaker
Good Afternoon Dennis - Often when this occurs, it is because there are too many appliances on the circuit or something may have a weak or poor breaker. Try plugging the unit in a different location or on its own circuit. If the issue continues, then it could also be possible that something shorted within the unit. So in this case, because it is a smaller appliance, repairs are often more costly than the actual unit replacement. You may want to check and see if your dehumidifier is still under warranty and if so, reach out to the manufacturer to determine the exact warranty coverage. Thanks for allowing me to help you.
Jul 28, 2013 | Frigidaire FAD504TDD Dehumidifier
When dehumidifier is turned on the circuit breaker trips. everytime the dehumidifier is started model LHD65EBL
Hi, Compressor is bad... tripping the breaker...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Sep 06, 2011 | LG LHD459EL Dehumidifier
Have a Goldstar Dehumidifier GHD30. Approximately 2 years old refurbished. The fan will run on the lowest setting but the compressor does not start. When I turn the dial to a higher setting the breaker...
doesn't sound good sounds , the compressor is bad .. you might want to check if it has a gfic. i could be bad, i would cut it out and try it without before i replaced a gfic
Jul 25, 2011 | LG DH30 GoldStar Dehumidifier
Demudifier worked great, all a sudden it just stopped. No power. Now it won't start up. What should I try?
First, check the outlet that it's plugged into, to make sure that there's still power to the outlet. If there isn't, then the circuit breaker for that outlet has been tripped, in your home's circuit breaker panel. Leave the dehumidifier unplugged and reset the circuit breaker. If it trips again, without the dehumidifier unplugged, then the outlet is at fault. Perhaps there's a loose wire connection or the interior of the outlet is cracked.
If it didn't trip without the dehumidifier plugged in, plug the unit it in,. But, before you do, make sure the dehumidifier's Master ON/OFF Switch is OFF. Once it's plugged in, turn the Master ON/OFF Switch to ON and set your controls. If it runs now, GREAT! If it trips the circuit breaker again, there's either a short in the power cord or an internal electrical short. Which will require extensive troubleshooting to find.
Hope this helps you solve the problem. Please let me know. Thanks.
May 05, 2011 | Fedders A7DH45B2A Dehumidifier
I have two Haier HDN655E dehumidifier's. One works fine and the other wont come on. I have tried unplugging and plugged back in, hit the start button and nothing happens. Is there a reset switch or a...
Have you tested the outlet it's plugged into, to make sure it still has power? If it doesn't, check the circuit breaker panel in you home for a tripped circuit breaker. If there is one, unplug the dehumidifier, before resetting it. Then plug the dehumidifier back in. If the circuit breaker trips again, the problem is within the dehumidifier or the outlet is faulty (i.e. Loose wire, burned wire, broken outlet). If the outlet is not faulty, you should contact Haier America Parts and Repair 877-337-3639.
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
Apr 28, 2011 | Dehumidifiers
Dehumidifier is tripping circuit breaker.
The compressor is bad and is causing the circuits to trip....
Here is a tip that I wrote about that problem...
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Apr 16, 2010 | DeLonghi DE500P Dehumidifier
Why does my dehumidifer suddenly starting tripping
either the compressor is locked up or the motor start capacitor on the compressor is shorted
Apr 14, 2010 | Ebac HD880 Dehumidifier
Unit trips out circuit after a few minutes (20Amp stand alone circuit)
make sure that the circuit breaker for the electrical plug is not faulty, cause after a long lifetime of high amperage flowing through it, the springs will start to get weak. If this is the case then you need to replace the electrial breaker. Otherwise, make sure that the power system on the system is not pulling too much current, Or that there is not a faulty breaker inside the printer itself, which has become weak.
Aug 22, 2008 | Whirlpool AD65USL / AD65USM Dehumidifier
Help me fix my dehumidifier
What else is on the same circuit? Have you added any other appliances on that same circuit that were not on it before?
If no>>>you probably have a short in the unit, and it is grounding out>>>tripping the breaker before it starts a fire.
Also, check the breaker, they can go bad.
Jul 23, 2008 | Kenmore 53509 Dehumidifier
Compressor won't run
the over-current relay is tripping out the compressor motor to prevent excessive current through motor windings. To prove this theory, open unit, find motor wires, disconnect wires from unit, and apply 120VAC to motor using external circuit-breaker source. Run 2 minutes max. If motor continuously turns, then relay is failing. Find it by tracing wires back to source and finding a small rectangular item. If motor again quits after 2 seconds, then this motor has an internal over-current self-resetting fuse that may be doing its job of preventing an electrical overload from a dead (shorted) motor.
Jul 07, 2007 | Whirlpool AD40USR Dehumidifier
Goldstar DH504EL Dehumidifier Logo
1,232 people viewed this question
Top Goldstar Dehumidifiers Experts
Gil Shultz
Michael Youngman
Michael Youngman
Jerry Greenberg
Jerry Greenberg
Are you a Goldstar Dehumidifier Expert? Answer questions, earn points and help others
