Question about Panasonic TH-50PHD5UY 50 in. HDTV-Ready Plasma Television
Screen not working!.....
Power-on (green)signal shuts off after 10 seconds and standby goes to flashing red.....
4 Suggested Answers
  • 558 Answers
SOURCE: funai 32 inch plasma tv
bad components on the power board needs to have service tech look into blown capacitors or transformer on the power board inside the tv.
Posted on May 28, 2008
  • 3 Answers
SOURCE: tv shuts off after 10-20 minutes
its not the problem with ur electron gun tube or with any picture ic or sound ic. Every t.v. is microcontoller switched machine.
any damage to microcontroller ic that controls the switching will lead to this kind of problem.
0.01% chance of residue EHT voltage would have affected the microcontroller.
Posted on Jun 06, 2009
  • 4234 Answers
SOURCE: When I power on the tv, the light goes to green
When a set is powered up, there are internal checks that are performed. The initial green light indicates that power has been applied. The flashing red light indicates that a problem was found that is preventing the set from functioning properly and it has shutdown to prevent further damaeg. If you can supply the model number, I may be able to provide additional details. Also, check to see if the flashing red light has a pattern. Quite often the pattern will indicate what problem was detected.
Posted on Aug 07, 2009
  • 49 Answers
SOURCE: TV shuts off and has a red flashing light
This is standyby mode problem.remove stand by transistor and on the tv through series cvonnection and find the problem
Posted on Jul 31, 2010
0 characters
1 Points
My TV randomly switches itself off and the red light flashes continously and i have to pull out the plug. its getting more frequent
Samsung TV Keeps Shutting Down - Forums - CNET > Forums > Samsung
CNETJun 11, 2015 - When I turn the TV on for the first time each day it shuts itself off within 30 seconds. ... green light flashing red light is [standby term] green light is [lamp]flashing. samsung plasma 850 picks up other remote signals?
Jun 12, 2015
Samsung LED UN55B7100 turns off on its own.
Jun 11, 2015
Volume goes automatically to 0 on my Samsung LCD TV
Jun 10, 2015
Why TV turns off by itself?
Jul 12, 2012
More results from
Easy fix for new Samsung TV switching on and off power ...
? 4:41
Sep 15, 2012 - Uploaded by alwaysafix
My tv turns on and off by itself the minute I plug in the cable. .... Samsung E6030 led tv hv blinkin red light ...
Dec 25, 2015 | Flat Panel Televisions
PDP-4340HD keeps turning off.
Continuous blinks of standby light indicates a fault in the IIC data bus. The main board is likely to be faulty. If you wish to know more Check this link.
Feb 03, 2013 | Pioneer PureVision PDP-4340HD 43 in....
Panasonic TX-P42X10B wont turn on - goes into standby
Hard to troubleshoot with just this info, the red light can be helpful if its 10 blinks repeating over and over replace the power supply first then the A board. Voltages check on the power supply would narrow down the culprit.
Post again if you measure the power supply voltages
May 03, 2012 | Flat Panel Televisions
TV won't turn on. flashes a series of 5 red lights instead of turning green
Usually Sony and LG Blinking Codes are the same. Here is what I have.
  • Unit is dead, No blinks - Problem in the standby power section. Might check fuse,
  • Continuous blink once a second, no pausing - No reply from the jungle IC301 (data bus is busy, shorted to ground, or held high), IK video path is defective.
  • One blink - not used for the self-diagnosis
  • Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
  • Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit,
  • Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted.
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. In addition, unit could be in IK blanking, try turning up screen slightly.
  • Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately.
  • Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
  • Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code.
  • Nine blinks - Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing Make sure the regulator is -12 or -13 (negitive).
  • Ten blinks - Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board.
Nov 26, 2011 | LG 42LC2D 42 in. LCD HDTV
Panasonic PTL500 LCD HIDEF projector - Unit occasionally powered up briefly, lamp lit, then shut down, standby LED flashed orange/red. Sometimes lamp lit and sometimes not. Technician diagnosed bad ballast...
The bulb is a discharge type - it needs a very high tension to work. The role of the ballast board is to convert the low voltage DC current coming from the power source in a high tension DC current for the bulb. Unfortunately you were truly unlucky : when the ballast board died it sent a high tension surge thru the power source and from there at the other components on the mainboard - the processor couldn't handle it and got fried. So now when you try to start the projector this is what happens: the power source starts normally - the status light goes to green as it should; it functions normally so it powers the ballast board and the rest of the mainboard - the ballast works so the bulb lights up; the mainboard on the other hand remains dead because the processor is dead so no sustain signal is sent to the power source; without the sustain signal the power source goes, as it should , in an very normal stand-by - the status light goes to red.
The entire mainboard will have to be replaced - you can't replace just the processor, it's glued in there. This is going to be expensive so ask a quote before doing it.
Dec 23, 2010 | Flat Panel Televisions
Returns to standby
Green flashing 3 times = digital DC - DC converter fault
Red flashing 3 times = scan circuit fault
Oct 31, 2007 | Pioneer PureVision PDP-5040HD 50 in....
42" Plasma TV Problem
same frustrating symptoms on brand new 42inch here! tv just turns itself off sometimes without warning or if changing to certain channels. leaves red light flashing for a while then red light goes away. any attempts with remote gives flashing green liht on tv. manual power off and on restarts tv but auto off again. found while manual power on keep changing channel on remote till stable picture appears. then use remote to shut down tv - solid red light indicates standby mode. then use remote to turn on again... till next time it happens. but what is technical fault??
Aug 18, 2007 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Panasonic TH-50PHD5UY 50 in. HDTV-Ready Plasma Television Logo
35 people viewed this question
Top Panasonic Flat Panel Televisions Experts
charlie rodriguez
charlie rodriguez
Are you a Panasonic Flat Panel Television Expert? Answer questions, earn points and help others
