Question about Kitchen Ranges
How to replace radiant heat element
How do you get to the elements on the GE Profile Cooktop - Model # JP989BK1BB. Does someone have a repair manual with the proper breakdown of replacing the heat element or insructions. I work on appliances but have not had to work on these glass cooktops yet.
    President:
  • 1,136 Answers
HI, on most models, there are three to four screws that hold the top to the cabinet. Look at the flange above the door to locate them. If this is the right nodel, the top should just raise up after the screws are removed. Be very careful not to twist or drop the top after it has been raised.
I hope this helps
Vic
Posted on May 17, 2009
Ge cooktop radiant
I have never seen any that have fuses for the individual elements . did you spill liquid on the top , like boil something over . that shorst them out and need replaced .
Jun 28, 2016 | GE PROFILE PP912TMWW 30" CERAMIC COOKTOP -...
Inner burner-- front right burner - does not heat up
you have either a bad switch or a bad element. If you plan on repairing this yourself, turn off the power to the unit BEFORE removing it from countertop. A continuity tester will be needed to properly test components. Nice Saturday morning homeowner project.
Mar 07, 2016 | GE Profile 30" Electric Self-Clean Drop-In...
Someone heated a wet pan on my radiant cook top range and now the burner doesn't work
don't think this is related. the heating element is under to glass cooktop. water cannot get to it.
Aug 26, 2015 | GE Kitchen Ranges
How to replace a radiant burner element wb30t10062 on a cook top not a combo, oven and cooktop
Search for my solution for a replacing the element on a JP939/JP969. That should help for similar GE models.
Sep 10, 2011 | GE 30 in. Profile JP939 Electric Cooktop
3 of 4 heating elements on Kenmore glass cooktop do not heat properly. They come on and then cycle off and on and never reach a cooking temperature. Only one of the 4 works properly. I believe the...
this might be normal behavior is the unit still heating and boiling items? has the unit worked differently in the past?
see below
Why the smoothtop radiant cooktop element cycles on and off
  1. Save as PDF
  2. Share
Table of contents
Does the radiant heating element cycle on and off?
  • The surface cooking area may glow red when a heating element is ON.
  • Some parts of the surface cooking area may not glow red when a heating element is ON.
  • The warming zone element (on certain models) will not glow red.
  • Radiant elements have a limiter that allows the element to cycle ON and OFF, even at the HI setting, to prevent damage to the ceramic cooktop. This is normal operation.
  • The radiant heating element retains enough heat when off to provide a uniform and consistent heat. The surface will still be hot even though the element has cycled OFF.
  • Cycling at the HI setting is normal and can occu
Feb 26, 2018 | Kenmore Kitchen Ranges
Right front (large) burner indicates hot, won't work, flashes F153
I hade a code 153 also. Changed the element(costly-$200) and had to recalibrate the pan sensors(in the manual). All works fine now.
May 21, 2009 | GE Cooktops
Radiant cooktop blew a fuse?
Call the service tech it;s under warranty and, this model is notorious for this fault
Apr 21, 2009 | General Electric 36 in. Profile PP962...
GE Cooktop radiant heat element problem
Sounds like you need to replace the burner control (part # WB23K5053)
Mar 02, 2009 | GE Cooktops
Ge jp340 radiant cooktop
Hello
I have the manual for your stove in PDF format, I will gladly email it to you.
Eddie Rentas
Tupper Lake NY
Jul 06, 2008 | GE 30 in. JP340 Electric Cooktop
Kitchen Ranges Logo
453 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
