Question about GE 27831GE2 Phone
Phone stopped working
I just got the phone not even a month ago, and it completely stopped working.
0 characters
1 Points
What caused caller ID to stop working?
Contact your service provider. The data comes from them and it is unlikely your phone is the cause of it not displaying.
Unplug your phone overnight to reset it as a check.
Jan 22, 2016 | Panasonic KX-TG5673 Trio Cordless Phone
Using home phone causes comcast wireless internet to disconnect
Wireless internet runs at 2.4ghz. Your portable phone is probably also 2.4ghz and is knocking out your internet connection when in use. Look for an 800mhz or 5.8ghz phone as a replacement.
Oct 09, 2009 | Panasonic KX-TG2357 Cordless Phone
Phones stopped working. They only read
first step is to unplug all power and phone connections from the wall for all Vtech phones and bases.
Second,plug each set and base in the wall for power one at a time.
Go back to the basics and pair the handset with the base of the unit.
Do this for all sets one at a time.
May 29, 2009 | Vtech 5.8GHz Cordless Phone with Digital...
I'm not familar with the Vtech but I would suspect that all 4 units work off of the answering machine base. It sounds like it is seeing a dial tone.
Take a working phones like the wall phone, if it is easily removed, and use a known good connecting cable between the good wall phone and the jack that the Vtech is plugged into.
If that works, take the connecting cable loose and replace it with the Vtech connecting cable. If that works check the jack on the Vtech for crossed wire. If non found, connect it to the jack the wall phone was plugged into. If this doesn't provide satisfaction, let me know exactly what you did and what happened and we will go from there.
May 28, 2009 | Vtech 5.8GHz Cordless Phone with Digital...
Callers can't hear me when I answer the phone My Plantronics phone started this about 1 month ago. No one can hear me, I hear them fine. I have even ordered a new battery and installed it and the same...
Went to Plantronics website and did the chat support. Was told to take the battery out and leave it out for 10 seconds so the phone would reset. It then worked for about 10 minutes and did it again midcall. So it kinda works, but not a reliable fix.
May 01, 2009 | Plantronics CT 12 Cordless Phone (CT12)
Base Unit does not work
Turns out the A/C adaptor was bad. Replaced it and all is good!!
Dec 17, 2008 | Panasonic KX-TG4500B Phone
Hand piece has gone bezerk
I had a problem with not being able to dial out... some digits came up as bizarre symbols and it didn't even take all 10 digits before beeping out. What I did to fix the problem was to remove the battery from the phone - actually pull the battery plug out, leave it for a minute then plug it back in. Then the phone started working again. You might want to try this... sort of like a hard reboot of the phone.
Nov 30, 2008 | GE 2.4GHz Cordless Bedroom Phone
CD135 phone answerphone function has stopped working
Hello, I have the opposite problem. I'm trying stop the answering machine so I can use the one that comes default with my phone line.
If anyone can help, please email me on
Dec 28, 2007 | Philips Zenia Voice Cordless Phone
GE 27831GE2 Phone Logo
43 people viewed this question
Top GE Phones Experts
Are you a GE Phone Expert? Answer questions, earn points and help others
