Question about Toshiba Satellite M100-ST5211 Notebook
Black screen on my loptop
When i open my loptop everything is empty
  • Helder Lopes
    Helder Lopes May 11, 2010
    can you explain better?
My hp loptop cant open windows only black out can see on the screen.
Boot the computer. Then preform the folowing key strokes: ctrl alt delete Select task manager. Add a new task called explorer with a lowercase "e"
Nov 15, 2009 | HP Pavilion dv9000z Notebook
Most battery comparments are on the bottom of the laptop. There is usually 2 different "covers" on the back, one is for RAM the other is the battery. It should be relatively easy to remove. Be careful when removing the battery because there is a chance you could get shocked.
May 25, 2009 | Toshiba Satellite A215-S7422 Notebook
Dell loptop wont turn on
take out ur batteries, clean the terminals with spirit or light alcohol, then re-insert it. better u use direct power supply but be sure to check that the power is beig supplied and the terminals/sockets are cleaned.
did this helped u. if not, tell me, when u push the power on button of ur notebook, does anything happens, like the fans start spinning or light went on. does the screen turn on or does something appears on the screen?
if nothing is happenng after pressing the power button, then this is a clear case of problem with ur power recieving section of the notebook. go to your pc dealer.
Jan 03, 2009 | Dell Inspiron 6000 Notebook
Black screen
your loptop is effected the vires please take your hardisk data backup ofter you'll use the DiskManger (DM) Segate  Format the all the drivers reinstalled the Oprating System it will work
Oct 26, 2008 | IBM ThinkPad T23 2647 Notebook
Loptop problem
some laptop have on and off switches right above the mouse pad
Oct 20, 2008 | Computers & Internet
About my loptop
Try right-clicking anywhere on the blackened area of your desktop, a menu might appear. Scroll down to Properties and click. In the Display Properties window click on the Settings Tab and see if you can re-adjust your screen resolution here, if not then read on...
Power off the laptop. Power on the laptop while holding the F8 key or both the SHIFT and F8 key together, if it boots to the Windows start up screen, power off and try again. This will bring up a menu, you will want the BOOT INTO SAFEMODE menu option.
After the safemode boot process, see if your laptop will display graphics (it should default to 640x480 mode and you should be able to view most of your desktop icons). Right click any where in a black area on your desktop, a menu will appear. Scroll to Properties and click. In the Display Properties window, click on the Settings tab and adjust your screen resolution from here.
Let me know if this works or not.
Jul 10, 2008 | IBM Computers & Internet
Compaq presario 700 Black screen
There might be several reasons, hardware nor software/operating system, but most probably from the hardware. Can be the graphic card (if you can notice the hard disk work well - from the sound), can be the hard disk, or even the mother board. We have to go through the symptom.
Since it is still new, the best solution is back to the seller for guarantee.
Feb 27, 2008 | Compaq Presario 700 470024-192 Notebook
Acer Aspire 3610 screen problem
when you first boot up do you get all the screen then windows starts and get part screen if so just reformate hard drive start all over if not then i think you have broken screen
Oct 20, 2007 | Acer Aspire 3610 Notebook
Toshiba Satellite M100-ST5211 Notebook Logo
88 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
