Question about AEG Lavamat W1450 Front Load Washer
ON off light is ON, but no LCD display, therefore not working.
Hi Guys, We have a AEG Electrolux L14510 VI washer. The power is on ( orange on/off light is fine) but the LCD display does not come up. We have pressed every button, changed the dial to all wash modes, even replaced the fuse..any help. Prod number 914510922/00 Cheers] Keith
SOURCE: AEG LAVA COMBO 1000
check your timer maybe the motors inside is defective, or your wiring is cut by the rats, or your timer itself is defective, the contact is not working properly.
Posted on Apr 14, 2008
ginko
  • 19396 Answers
SOURCE: aeg 76669 washing machine
The only way to reset a washing machine is by unplugging the power cord for half an hour or so, then plug it back.
This will drain power from circuits and reset them completely.
If that does not work, then you will need to have the control assembly replaced.
You get parts and diagrams here or here.
Posted on Oct 25, 2008
SOURCE: Door locked
Same problem, Same machine.. Also used the string (well a shoe lace) and immediately it opened, without much force! Once opened you can see why it opens so well using this method plus also can see the broken piece..
Thank you so much, can look into repairing the catch somehow now and can use machine in mean-time!
If anyone has done this and knows a good place to get the part and which part to get, an email would be much appreciated: andrew at poubelle dot co dot uk :)
Posted on Mar 20, 2009
SOURCE: AEG LAVAMAT 12700 VI turbo washing machine doesn't drain
Hi, You have taken out the strainer of the washer front and cleaned it regularly haven't you?? If that's clear, it's probably just the waste line blocked. Try removing the waste pipe where it joins under the sink, put it in a bucket and see if the washer drains. It's probably full of sh"te. If that doesn't work, then I'm probably full of sh"te and you might need a new pump.
Posted on Jun 15, 2009
  • 42 Answers
SOURCE: aeg electrolux error message E20 has just flashed
it might refer to any blockage in the water supply. So cleaning the pump could primarily resolve this. but it might also be a blockage in the soap tray (when available), the tap or the hose attached to the tap or the air-gap or any water control structure. but most of the times, it is simple blockage of pump. just pull out the manual, remove, clean and replace the pump. this will solve your problem.
cheers
Posted on Jul 26, 2009
Aeg electrolux dishwasher wont wash just keeps beeping
well there are several possibility's. What was the washer doing? Rinse or cleaning? If there is standing water in the tub, then the pump went out or is clogged.
Dec 04, 2012 | Dishwashers
E60 Error Code on converted 60Hz outlet
E60- Fault in washing NTC sensor
-Washing NTC sensor, wiring, main PCB
Unplug your washer for 1 hour and then plug it back.See if this reset helps.
Aug 06, 2008 | AEG L74800 Front Load Washer
AEG Lavamat 16820 turbo Washer/dryer won't start - makes noise
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
dgmj
Apr 18, 2010 | AEG Lavamat 16810 Front Load Washer/Dryer
Feb 10, 2009 | AEG L12700ViT Front Load Washer / Dryer
AEG OKO-Lavamat 1271 VI Turbo (Washer Dryer) 7-8 years old intergrated front loaderSuddenly began clanking during the spin cycle. with no load works normally with a light load, sometimes works on some...
Sounds like the main drum bearings have failed.
At this age , I don't think this is an economical repair to undertake.
Better to replace with a new one.
Dec 13, 2008 | AEG Washing Machines
No display
if your monitor is not connected to a pc, then it cannot find a vga signal input and therefore go into power saving mode, which is indicated by the orange light, but as soon as you connect to the pc and power on the light will go green and the monitor will power up.
May 07, 2007 | BenQ T701 TFT 17" LCD Monitor
AEG Lavamat W1450 Front Load Washer Logo
44 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
