Question about Electrolux Refrigerators
I need to remove and replace the upper hinge on a Dometic RM8550 refrigerator fitted in our UK 2007 Bailey Senator Arizona caravan. The van was an ex display model and it looks like the hinge has seen more than it's fair share of wear and tear. Consequently the door drops when you open it. Any instructions would be most appreciated. Thanks Steve Kemp
  • 105 Answers
SOURCE: fridge door problem
There probably were spacers. Also be sure that the refrigerator is level, side to side and that it is leaning just slightly back. If not leveled, it can actually throw the cabinet off and it will be out of square.
Posted on Apr 07, 2009
  • 127 Answers
SOURCE: Info on replacing drain hose on dometic model 2652
You will need to remove the fridge and set it on the floor or at least pull it forward enough to reach the top of the drain hose. There is clip that holds the drain tube to a nipple that sticks out of the back of the fridge that will need to be removed. Remove this clip and the drain hose should pull right off. Route the new drain hose down through the cooling unit coils to the door panel. Attach it back to the nipple with the clip and you should be good to go. The part number for the new drain hose is 2932749019.
Hope this helps,
Jeff
Rate me please!!
Posted on Jul 03, 2009
  • 9 Answers
SOURCE: need directions to remove and replace 110 element in Dometic 2652
Get to the back of the fridge. On the right hand side, there is a metal tube about 4" in diameter which starts at the bottom and goes up. This is a piece of thin sheet metal, which holds insulation against the refrigerant line that goes up the right side of the fridge. The 110 volt heater is located inside of that, near the bottom. The heater sits inside of a small tube, welded to the refrigerant line, and is easily replaced. To get to it, remove any flat sheet metal parts that block your view of the 4" tube (you will need to have a clear view of the bottom of it.) Then you can see the heater. It is on the left side of your 4" tube, metal, about 5/16" in diameter, has 2 wires attached, and sticks out an inch or so to the left. Trace the wires back to where they are connected on your fridge, and remove them, (probably with a small straight blade screwdriver.) It may be necessary to remove another cover or 2 to get to that connection, so remember where all your cover plates came from. Digital cameras are great ;-) . Then, on your 4" tube, unsnap and open the "door" (the metal piece which is a couple if inches wide and 7" or so high,) Grab a hold of your old heater, and pull it up. It probably wont come up all the way so you can lift it completely out, so you will have to unsnap some of your 4" tube above the door. When you remove the old heater, note its position relative to the insulation and refrigerant tube, 'cause the new one goes right back in the same spot. Pull the old one out, and put the new one in. You will know you have it installed correctly when it is snug in its own little tube (you wont be able to see that part,) and there is no side to side play. Then reverse the directions, and put everything back together again. When you re-attach the 2 wires to your unit, don't worry about getting it wrong, it doesn't matter which wire goes with what connector.
Posted on Jul 26, 2009
milten1
  • 1304 Answers
SOURCE: Dometic RM6270 Caravan Fridge.Hinges
you should be able to find any part you need
at
pplmotorhomes.com
they have always been able to help me in the past
Posted on Oct 14, 2009
  • 234 Answers
SOURCE: I have a Dometic rm2652 refrigerator the door hinge broke
the hinge is not plastic, only the insert sleeve that goes into the hole atop the door is plastic. If the actual hinge (metal arm) is broke, then you need to order a new part (not difficult if frig is 20 years or less). If you cannot find the part, go to a metal shop and show them the broken part, they usually can repair it or remake a new piece.
If the hole in the door went bad (that is: if the hole tore open and cannot hold the hinge pin) you need to have a metal repair brace added to the door. This will involve the metal shop or a good mechanic that can come to you and do the neccessary repair at the house; otherwise you need to bring the door to the metal shop. macgivor
Posted on Dec 27, 2009
My dometic rm 7501 doesnt work
disconnect thermistor let run over nite if ok replace thermistor being no light check to see if power to board if ok bad board if no power find source issue
Jul 23, 2014 | Dometic Refrigerators
My caravan fridge model number rm8550 will not cool
check fusible link if ok bad board if runs bad cooling unit
Aug 22, 2012 | Dometic Refrigerators
I need to know where to find the child anchor for a 1996 dodge caravan
There are no child anchors on a 96. This was around the time the latch system was under development. Just went through looking into this for my 1996 van. chico car seat fit well
The newer van seats will not fit either( I do have a 2007 seat for sale now ) as I tried to make one fit in my 1996 van with the latch system and it didnt fit. Wheels right spacing too wide for the anchor points.
Tom K. MN
Nov 11, 2011 | 1996 Dodge Caravan
I HAVE A BAILEY SENATOR CARAVAN TITH A FACTORY FITTED SENATOR DVD-7505 THE CONNECTOR FROM THE UNIT TO THE VAN IS SCREWED UP CAN YOU PROVIDE WIRING CONNECTION DETAILS
I HAVE A SENATOR SERIES 6 CARAVAN FITTED WITH THE 7505 SENATOR DVD BUT WE ARE HAVING PROBLEMS THE SOUND KEEPS FADING ON THE RADIO THEN SUDDENLY COMES ON FULL VOLUME WITHOUT BEING TOUCHED ANY IDEAS WHAT THE PROBLEM MIGHT BE
Mar 30, 2011 | Car Audio & Video
Dec 27, 2009 | Dometic RM2652 Refrigerator
at
pplmotorhomes.com
Oct 14, 2009 | Refrigerators
Right door is lower than the left how do i level doors
if the door is slightly off u need a shim that will fit or a couple of small washers over the lower door pin remove food from door and with help from someone -to help in removing door and replacing it - at the top of the door u will c the upper hinge pin remove cover if one remove the 3 hold down screws while supporting the door remove hinge lift door off lower pin place shims or washers on lower pin till desired height not more than 3/8 is advisable place door on if still to low remove door and remove lower hinge and slightly give it a bend or leave on and slightly bend up hinge when desired height reached replace door and reattach top hinge
Sep 24, 2009 | KitchenAid Superba KSRG25FK Side by Side...
Dometic RM2652
If your power supply changes such as shore to gen or any other source change the light will come on Try resetting If it continues you may need a voltage monitor to verify your not having other problems
Aug 18, 2008 | Dometic RM2652 Refrigerator
Electrolux RM 4270 caravan fridge
Thankyou for your assistance, but i found the solution with electrolux direct.
Hope to use your site again sometime.
Aug 04, 2008 | Refrigerators
Refrigerators Logo
Top Electrolux Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
